Thanks. I already pressed out the pivots, but don't remember the inner sleeve of the bushing coming out with them. I'll check this weekend.
I already removed/installed the UCA bushings using hand tools made for that purpose (you can get them at Mancini). I will use them to install the LCA bushings, too. Getting the old ones out is the problem.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
