I do BOTH! I have an AED prepped 750DP.......AND a TQ for my mild 360. I have to say honestly that I don't know which one I like better. I am currently using the Holley right now and it has great performance, as well as great street manners..... of course it is prepped by the engineers at AED. I like both carbs REALLY WELL, and I try to find reasons to pick one over the other, and then I finally agreed to just like them both and take turns running each one.
I will be going soon to the strip this September and I will log both times between the two carbs during several 1/4 runs. I will be doing runs in extreme elevation however and not sure if one carb suffers more than the other one (due to elevation alone), but I will have the times listed for both carbs in equal conditions. I also plan on switching to the TQ for street use (either before and/or after the track) but will be doing this for mileage reasons primarily. I've not measured between the two yet but now I wanna find out....
