Quote: TQ vs DP? 2 different animals. TQ makes for a better street driver if MPG is factored in(usually) but doesn't offer near the tuneability of a Holley DP. A Holley VS would be a better comparision.
I tend to agree. Doing recently(because i like to get a new carb and intake set up myself on a mostly stock car) I think a TQ and a Holley Vac Secondary would be a closer comparison like say a TQ and a 3310 for instance.
The TQ or QJ will still win over a squarebore carb, smaller primary bores get better mileage if the AFR is the same on both carbs. & you can make a 750dp get right at the same mileage as a 3310.
75 Duster, 451 10.87 @ 123.58 NA
97 Z28 6sp., 12.01 @ 115 on a 100 shot
71 Swinger. 360 magnum. 12.58 @ 105
78 cutlass, 469 BBC. 12.70 @ 108 on street tires.
http://www.youtube.com/watch?v=Z2kqNmMfheU
