Page 4 of 5 1 2 3 4 5
Re: Heater Box resto? [Re: hemi70se] #901484
01/13/11 01:05 PM
01/13/11 01:05 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Find a can of the correct color in spray can. Spray it on a flat metal surface that you can dip the stamp into. The trick is to get just the right amount to pick up on the stamp surface. Too much and your stamp will look smudgy, too dry and you'll not get a nice transfer. Practice some before doing your box because you only have one shot at it.
The OP's original is kinda smudgey - I think I would do his the same way. Do it like you don't care - just like the person who put it on originally....
Re: Heater Box resto? [Re: hemi70se] #901485
01/13/11 01:14 PM
01/13/11 01:14 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
There is also an ink that works on metal surfaces.
I believe it's a silk screeners ink. Bottle I have is labeled Ultimate Ink
Last time I needed it I bought it thru a local print / sign shop called sign-o-rama, unfortunately there are none of these near me anymore. but I did find it at one in Evansville In that said she could get it
Re: Heater Box resto? [Re: hemi70se] #901486
01/13/11 01:14 PM
01/13/11 01:14 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Why would mine show 2936681.... ?
70 B-body Non-AC boxes had both the 2936681 and 2936680 inked part numbers. I had stamps made for both. The difference being an early/late year thing or St. Louis car or Lynch Road car thing. If everyone would chime in we could likely figure it out.
2936681 number on my 12/69 built Lynch rd car.
Re: Heater Box resto? [Re: JMCFAN] #901487
01/13/11 01:31 PM
01/13/11 01:31 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
What were the diminsions/font on your stamps? Same as above?
I could not find the correct font anywhere on the computer. I actually put a LOT of time into making these. I made correctly looking font numbers by hand 8 inches tall and shunk them on my copier until they were sized perfectly to an original, then I copied all the numbers together in a group spacing them identically to an original stamping.
Re: Heater Box resto? [Re: LimeliteAero] #901488
01/13/11 01:36 PM
01/13/11 01:36 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
As I recall a late build St. Louis car I had had the 2936680 box I'm going to venture to say it is a late/early build thing. Cars built prior to Jan 1st had a #681 and cars after had a #680.
Re: Heater Box resto? [Re: hemi70se] #901489
01/13/11 09:25 PM
01/13/11 09:25 PM
Canada
thb401 Offline
thb401  Offline
Canada
My 1970 Canadian shipped Road Runner has 2936681 stamped on it's non a/c heater box. Car was built at lynch Rd. Sept 8th, 1969.
Re: Heater Box resto? [Re: macmic87] #901490
01/14/11 01:39 PM
01/14/11 01:39 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
usually lightly, and i mean lightly blast the fiberglass box. it will turn a lighter gray color. blow it off good and clear with a poly satin finish. the satin poly will bring the color back. i had a stamp company make my stamps for the part numbers.
Hey what paint and gloss did you use for the metal plate with the stamp on it...?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Heater Box resto? [Re: JMCFAN] #901491
01/14/11 02:01 PM
01/14/11 02:01 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
The front metal cover should have black phosp. screws and not clear zinc ones like in the pic shown above. I have noticed that the screw head markings on them are different between the #680 and #681 boxes also. I paint the black metal cover plate with a gloss black enamel with a little bit of flattening agent mixed in so it isn't overly glossy.
Re: Heater Box resto? [Re: hemi70se] #901492
01/14/11 03:02 PM
01/14/11 03:02 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
So if you were to use "Chassie Black" would you use 60-70% gloss( satin) or 85%....
Re: Heater Box resto? [Re: JMCFAN] #901493
01/14/11 03:11 PM
01/14/11 03:11 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
It is fairly glossy - I would put it at 10-12% flattened - or 88-90 gloss - depending on which way you look at it.
Re: Heater Box resto? [Re: FJ5_Fish] #901494
01/14/11 03:52 PM
01/14/11 03:52 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I would not use "Chassis black" on anything. I concur with Jim, about 90% gloss. Remember that today's paints have had 40 years of refinements to make them glossier. The "gloss black" you will get at the paint store is formulated for maximum shine because they assume you are using it on the exterior of a car. If you want it to get just the right sheen of gloss you need to SLIGHTLY dull it down some with some flattening agent.
Re: Heater Box resto? [Re: hemi70se] #901495
01/14/11 04:33 PM
01/14/11 04:33 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
ok.... so the inside of my RR doors ( exposed area) is also black. same gloss... or same paint anway..?
Re: Heater Box resto? [Re: JMCFAN] #901496
01/14/11 05:41 PM
01/14/11 05:41 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
You mean the UDF (upper door frame) color that is on the doors of the car? If they are coded black (should be on your fender tag) that is exterior gloss enamel.....same stuff they would paint the car with. The UDF color was applied before the body color then masked off. The attached is a pic of the original black off of my Daytona. The Chargers had a pad covering the UDF so it wasn't painted there...A Bee, Runner etc. would be.
Re: Heater Box resto? [Re: FJ5_Fish] #901497
01/15/11 11:05 AM
01/15/11 11:05 AM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
You know this has ended up being a very good topic with some excellent posts guys.
Re: Heater Box resto? [Re: gomangoRTSE] #901498
01/15/11 11:18 AM
01/15/11 11:18 AM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I was thinking the same thing ! And good timing since I am in the middle of doing a 68 B box
Re: Heater Box resto? [Re: belv2vert66] #901499
01/15/11 11:25 AM
01/15/11 11:25 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
The guys on the board have helped me with many projects!! Many thanks!!!
Re: Heater Box resto? [Re: rayztoy] #901500
01/30/11 04:46 PM
01/30/11 04:46 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Update Got the kit the rubberstamp, and went to work. Just waiting on the new heater core.
Re: Heater Box resto? [Re: JMCFAN] #901501
01/30/11 05:04 PM
01/30/11 05:04 PM
I am getting ready to do mine for my 69 Coronet R/T. I need the 2837500 stamp, does anyone have one collecting dust?
Re: Heater Box resto? [Re: ] #901502
01/30/11 05:12 PM
01/30/11 05:12 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Rubberstamp.com... was $8 $13 with shipping
Re: Heater Box resto? [Re: JMCFAN] #901503
11/25/11 03:08 PM
11/25/11 03:08 PM
It's a dry heat
It's a dry heat
Bumping this one back live.
anyone figure out why the differences between the 680 versus 681 stamp # ?
