Re: Heater Box resto?
[Re: hemi70se]
#901485
01/13/11 01:14 PM
01/13/11 01:14 PM
Posts: 21,513 It's a dry heat
gtx6970
It's a dry heat
There is also an ink that works on metal surfaces. I believe it's a silk screeners ink. Bottle I have is labeled Ultimate Ink
Last time I needed it I bought it thru a local print / sign shop called sign-o-rama, unfortunately there are none of these near me anymore. but I did find it at one in Evansville In that said she could get it
[Re: hemi70se]
#901486
01/13/11 01:14 PM
01/13/11 01:14 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Why would mine show 2936681.... ?
70 B-body Non-AC boxes had both the 2936681 and 2936680 inked part numbers. I had stamps made for both. The difference being an early/late year thing or St. Louis car or Lynch Road car thing. If everyone would chime in we could likely figure it out.
2936681 number on my 12/69 built Lynch rd car.
[Re: JMCFAN]
#901487
01/13/11 01:31 PM
01/13/11 01:31 PM
Posts: 2,484 Minneapolis, MN
hemi70se
Minneapolis, MN
What were the diminsions/font on your stamps? Same as above?
I could not find the correct font anywhere on the computer. I actually put a LOT of time into making these. I made correctly looking font numbers by hand 8 inches tall and shunk them on my copier until they were sized perfectly to an original, then I copied all the numbers together in a group spacing them identically to an original stamping.
[Re: LimeliteAero]
#901488
01/13/11 01:36 PM
01/13/11 01:36 PM
hemi70se
Minneapolis, MN
As I recall a late build St. Louis car I had had the 2936680 box I'm going to venture to say it is a late/early build thing. Cars built prior to Jan 1st had a #681 and cars after had a #680.
[Re: hemi70se]
#901495
01/14/11 04:33 PM
01/14/11 04:33 PM
Posts: 2,106 New Mexico
JMCFAN
New Mexico
ok.... so the inside of my RR doors ( exposed area) is also black. same gloss... or same paint anway..?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: gomangoRTSE]
#901498
01/15/11 11:18 AM
01/15/11 11:18 AM
Posts: 1,380 Back In Iowa
belv2vert66
Back In Iowa
You know this has ended up being a very good topic with some excellent posts guys.
I was thinking the same thing ! And good timing since I am in the middle of doing a 68 B box
[Re: JMCFAN]
#901501
01/30/11 05:04 PM
01/30/11 05:04 PM
I am getting ready to do mine for my 69 Coronet R/T. I need the 2837500 stamp, does anyone have one collecting dust?
