Whats up with the Pro Systems SV1 Carb ? #771609
08/11/10 06:46 PM
08/11/10 06:46 PM
western pennsylvania
b1dartsport Offline OP
All we heard is that this carb was the next best thing to sliced bread a few months ago. I have not heard I thing about it since. Anybody try it yet? Results?
Re: Whats up with the Pro Systems SV1 Carb ? [Re: b1dartsport] #771610
08/11/10 06:59 PM
08/11/10 06:59 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
if it was that good there would have been more news.simple.
Re: Whats up with the Pro Systems SV1 Carb ? [Re: blownzoom440] #771611
08/11/10 07:43 PM
08/11/10 07:43 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
it's still realitively new and it's an expensive piece. not many people in the general public have the cash to shell out for it. the two people i know that have used it have noticed better throttle response, idle, vacuum and a little more mph. neither can really say if it was the carb. or if the other carb not tuned properly. the added expense wasn't really justified but did notice an increase over their existing carbs. might be a bigger increase in a different type of application then either one of them were using it for. ie: pump gas,540 cid and 512 cid. might be better for a bigger cid,higher compression, etc.
Re: Whats up with the Pro Systems SV1 Carb ? [Re: 9secondsatellite] #771612
08/11/10 08:26 PM
08/11/10 08:26 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
The reason the throttle response is better is because that with one big blade, when you open that carb versus a regular carb the same amount, the SV-1 is letting a lot more air in.........You could do the same with a progressive linkage on a regular 4 barrel.........Just set it up to where the carb opens a lot with very little throttle cable movement......
There's NO WAY that carb will make your motor make more vacuum.........Vacuum is what it is.......
If you can't handle the truth, you're living a lie.......
Re: Whats up with the Pro Systems SV1 Carb ? [Re: Big Squeeze] #771613
08/11/10 08:41 PM
08/11/10 08:41 PM
Az
Crizila Offline
Crizila  Offline
Az
Kinda like putting a gear drive and extra set of squirters on the old 950 3 barrel I know, I'm dating myself
Fastest 300
Re: Whats up with the Pro Systems SV1 Carb ? [Re: Big Squeeze] #771614
08/11/10 09:08 PM
08/11/10 09:08 PM
alaska,usa
9
alaska,usa
the wording was "better" not "more". a poorly tuned carb at idle in gear will yield less vacuum then a well tuned one.
Re: Whats up with the Pro Systems SV1 Carb ? [Re: 9secondsatellite] #771615
08/11/10 09:27 PM
08/11/10 09:27 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
When I Talked to Patrick at pro systems he said the SV1 was designed for power levels over 700 HP. That takes alot of people out of it. He did mention alot of interest for lower powered applications and he is looking into that.
Re: Whats up with the Pro Systems SV1 Carb ? [Re: DJVCuda] #771616
08/11/10 10:42 PM
08/11/10 10:42 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You guys outta change over to a flying toilet if you like throttle response...there is nothing that can even compare a alky injection setup..
Reason I say this that you can pickup a toilet setup for the price of the SV1
Re: Whats up with the Pro Systems SV1 Carb ? [Re: Bob_Coomer] #771617
08/11/10 10:49 PM
08/11/10 10:49 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I really like my SV1. idles good and worked great only time at the track! never messed with it at the track at all (3300DA) did some wideband street tuning but I need to get back out! sorry didnt compare it to anything but it worked good first shot down the 1320! mine is over 1200cfm!
just wanted to see how low I could get it to idle here.
http://youtube.com/watch?v=V74cnr_Xjl4
http://www.youtube.com/watch?v=hxv4SvuYOes
http://www.youtube.com/watch?v=MCEkp811YTs
Mopar Performance
Re: Whats up with the Pro Systems SV1 Carb ? [Re: moparniac] #771618
08/11/10 10:54 PM
08/11/10 10:54 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Sounds good man...really...good job
How much was that carb if you dont mid saying...Im gonna guess.....hmm.....
$1575??
Did I win a prize LOL?
Re: Whats up with the Pro Systems SV1 Carb ? [Re: Bob_Coomer] #771619
08/11/10 10:58 PM
08/11/10 10:58 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I paid $1125 and came with the bracket for air cleaner! He told me they were going up $100 My last custom dominator was more than that!
Mopar Performance
Re: Whats up with the Pro Systems SV1 Carb ? [Re: moparniac] #771620
08/12/10 06:01 PM
08/12/10 06:01 PM
I'm using a 4150 1050 race demon & was thinking of playing around with a custom domy. $1125 would not be out of the ordinary to pay for a custom dominator. Thanks for the onfo
Re: Whats up with the Pro Systems SV1 Carb ? [Re: b1dartsport] #771621
08/16/10 08:54 AM
08/16/10 08:54 AM
an8sec70cuda Offline
The Pro Systems dominator I have on my hemi cost $1000.
I was quoted $1150 for a custom SV1.
I think the jury is still out as to just how much better the SV1 is than a regular dominator. Glad I waited to see some results before buying one myself. I'll be sticking with my current carb for now.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Whats up with the Pro Systems SV1 Carb ? [Re: an8sec70cuda] #771622
08/16/10 10:20 AM
08/16/10 10:20 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Well i have been waiting for more folks to comment on the SV-1 but it seems the cost for most is the factor, which even Patrick points out in his writting.I for one think the design is perfect for me as a foot-brake car due to the quicker response and Iam not a professional tuner so I cant get a dominator to respond as fast as the SV1.I have looked at the toilet but for me its alot more to add on a simple car.My partner and i are going E-85 due to its here now and makes sence and due to I have a 1050 Holley now and would have to change it over for E85 plus the fact I wanted more CFM anyway and its pretty
Re: Whats up with the Pro Systems SV1 Carb ? [Re: poisondart2] #771623
08/16/10 11:42 AM
08/16/10 11:42 AM
PA
moparacer Online content
moparacer  Online Content
PA
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Whats up with the Pro Systems SV1 Carb ? [Re: an8sec70cuda] #771624
08/16/10 12:06 PM
08/16/10 12:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
whens the next time you are going to the track?
Mopar Performance
Re: Whats up with the Pro Systems SV1 Carb ? [Re: moparniac] #771625
08/16/10 12:26 PM
08/16/10 12:26 PM
Ozark Mountains
Chevy454 Offline
I Love Mopars
Chevy454  Offline
I Love Mopars
Ozark Mountains
FWIW from a GM guy, the engine builders I've dealt with in this part of the world have nothing but love for these things...my dad watched them dyno an engine with an SV-1, and the engine guy told him a simple carb swap from his worked Dominator picked up 25hp...
Rob Clary Fat, yellow Yenko Camaro 11.75 @ 118, Pure Stock!
Re: Whats up with the Pro Systems SV1 Carb ? [Re: Chevy454] #771626
08/16/10 01:53 PM
08/16/10 01:53 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
This is what I keep reading and i doubt that Jon Kaase and David Reher are wrong on what the have seen and used.
Re: Whats up with the Pro Systems SV1 Carb ? *DELETED* [Re: Chevy454] #771627
08/16/10 01:57 PM
08/16/10 01:57 PM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
Post deleted by jb15
Re: Whats up with the Pro Systems SV1 Carb ? [Re: moparniac] #771628
08/16/10 01:58 PM
08/16/10 01:58 PM
I'm up for going anytime.
CHIP
