Re: Whats up with the Pro Systems SV1 Carb ?
[Re: 9secondsatellite]
#771612
08/11/10 08:26 PM
08/11/10 08:26 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
The reason the throttle response is better is because that with one big blade, when you open that carb versus a regular carb the same amount, the SV-1 is letting a lot more air in.........You could do the same with a progressive linkage on a regular 4 barrel.........Just set it up to where the carb opens a lot with very little throttle cable movement...... There's NO WAY that carb will make your motor make more vacuum.........Vacuum is what it is....... ![](/ubbthreads/images/graemlins/Twocents.gif)
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#771614
08/11/10 09:08 PM
08/11/10 09:08 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
the wording was "better" not "more". a poorly tuned carb at idle in gear will yield less vacuum then a well tuned one.
[Re: DJVCuda]
#771616
08/11/10 10:42 PM
08/11/10 10:42 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
You guys outta change over to a flying toilet if you like throttle response...there is nothing that can even compare a alky injection setup.. Reason I say this that you can pickup a toilet setup for the price of the SV1 ![](/ubbthreads/images/graemlins/blush.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: b1dartsport]
#771621
08/16/10 08:54 AM
08/16/10 08:54 AM
Posts: 13,406 Marion, South Carolina [><]
an8sec70cuda
The Pro Systems dominator I have on my hemi cost $1000. I was quoted $1150 for a custom SV1.
I think the jury is still out as to just how much better the SV1 is than a regular dominator. Glad I waited to see some results before buying one myself. I'll be sticking with my current carb for now.
[Re: moparniac]
#771625
08/16/10 12:26 PM
08/16/10 12:26 PM
Posts: 105 Ozark Mountains
Chevy454
I Love Mopars
I Love Mopars
Ozark Mountains
FWIW from a GM guy, the engine builders I've dealt with in this part of the world have nothing but love for these things...my dad watched them dyno an engine with an SV-1, and the engine guy told him a simple carb swap from his worked Dominator picked up 25hp...
Rob Clary
Fat, yellow Yenko Camaro
11.75 @ 118, Pure Stock!
[Re: Chevy454]
#771626
08/16/10 01:53 PM
08/16/10 01:53 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
This is what I keep reading and i doubt that Jon Kaase and David Reher are wrong on what the have seen and used.
Re: Whats up with the Pro Systems SV1 Carb ? *DELETED*
[Re: Chevy454]
#771627
08/16/10 01:57 PM
08/16/10 01:57 PM
Posts: 214 canada,NB
jb15
canada,NB
Post deleted by jb15
[Re: moparniac]
#771628
08/16/10 01:58 PM
08/16/10 01:58 PM
an8sec70cuda
whens the next time you are going to the track?
I'm up for going anytime. ![](/ubbthreads/images/graemlins/thumbs.gif)
