Re: Whats up with the Pro Systems SV1 Carb ?
[Re: 9secondsatellite]
#771612
08/11/10 08:26 PM
08/11/10 08:26 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
The reason the throttle response is better is because that with one big blade, when you open that carb versus a regular carb the same amount, the SV-1 is letting a lot more air in.........You could do the same with a progressive linkage on a regular 4 barrel.........Just set it up to where the carb opens a lot with very little throttle cable movement...... There's NO WAY that carb will make your motor make more vacuum.........Vacuum is what it is.......
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#771614
08/11/10 09:08 PM
08/11/10 09:08 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
the wording was "better" not "more". a poorly tuned carb at idle in gear will yield less vacuum then a well tuned one.
[Re: DJVCuda]
#771616
08/11/10 10:42 PM
08/11/10 10:42 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
You guys outta change over to a flying toilet if you like throttle response...there is nothing that can even compare a alky injection setup.. Reason I say this that you can pickup a toilet setup for the price of the SV1
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: b1dartsport]
#771621
08/16/10 08:54 AM
08/16/10 08:54 AM
Posts: 13,405 Marion, South Carolina [><]
an8sec70cuda
The Pro Systems dominator I have on my hemi cost $1000. I was quoted $1150 for a custom SV1.
I think the jury is still out as to just how much better the SV1 is than a regular dominator. Glad I waited to see some results before buying one myself. I'll be sticking with my current carb for now.
[Re: moparniac]
#771625
08/16/10 12:26 PM
08/16/10 12:26 PM
Posts: 105 Ozark Mountains
Chevy454
I Love Mopars
I Love Mopars
Ozark Mountains
FWIW from a GM guy, the engine builders I've dealt with in this part of the world have nothing but love for these things...my dad watched them dyno an engine with an SV-1, and the engine guy told him a simple carb swap from his worked Dominator picked up 25hp...
Rob Clary
Fat, yellow Yenko Camaro
11.75 @ 118, Pure Stock!
[Re: Chevy454]
#771626
08/16/10 01:53 PM
08/16/10 01:53 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
This is what I keep reading and i doubt that Jon Kaase and David Reher are wrong on what the have seen and used.
Re: Whats up with the Pro Systems SV1 Carb ? *DELETED*
[Re: Chevy454]
#771627
08/16/10 01:57 PM
08/16/10 01:57 PM
Posts: 214 canada,NB
jb15
canada,NB
Post deleted by jb15
[Re: moparniac]
#771628
08/16/10 01:58 PM
08/16/10 01:58 PM
an8sec70cuda
whens the next time you are going to the track?
I'm up for going anytime.
