Re: 727 pump bearing
[Re: 727specialist]
#581943
01/14/10 03:06 PM
01/14/10 03:06 PM
Posts: 5,080 organ
maximum entropy
organ
the converter does not charge in park. that bushing is pressurized in park, yes? maybe case misalignment?
[Re: maximum entropy]
#581944
01/14/10 04:06 PM
01/14/10 04:06 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The bushing is lubricated by the fluid that leaks past the pump rotors; if the crankshaft is turning, the pump rotors are turning and the bushing is being lubricated regardless of what gear it's in.
[Re: 451Mopar]
#581947
01/15/10 08:43 AM
01/15/10 08:43 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
This reminds me of a plroblem I had years ago. I had a pump bushing failure twice before finding this little issue. Try looking at the dowl pins on the block and make sure that they are sticking out far enough to completly engage the mating holes in the transmission. In my car, the tapper on the dowl pin only engaged into the chamfer of the case and allowed it to move around. The end result was leaking converter seal and worn bushings. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: B1Johnny]
#581948
01/15/10 11:09 AM
01/15/10 11:09 AM
Posts: 16,928 NC
440Jim
NC
a bad electrical ground can cause bushings to pit,flake apart.run a ground strap from trans to frame.hope this helps john.
I would check the car grounding (engine/trans/chassis)
