my trans wasn't running as good as i wanted so i took it back to the shop. before he got it i looked in the pan, it had some bearing material in there. trans man says it's because i start & run it in park for too long. BS was my reply, it's an A&A ultimate brake & only starts in park. usually once it's started i idle the car in Neutral. is he talking crap or is this the case, if it runs in park too long it'll kill the pump bearing?
