727 pump bearing #581935
01/14/10 04:16 AM
01/14/10 04:16 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
my trans wasn't running as good as i wanted so i took it back to the shop. before he got it i looked in the pan, it had some bearing material in there. trans man says it's because i start & run it in park for too long. BS was my reply, it's an A&A ultimate brake & only starts in park. usually once it's started i idle the car in Neutral. is he talking crap or is this the case, if it runs in park too long it'll kill the pump bearing?
Re: 727 pump bearing [Re: rebel] #581936
01/14/10 04:24 AM
01/14/10 04:24 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Is your TRANS MAN sober? ..
Me thimks not. Do you have a pic of that material ?
Re: 727 pump bearing [Re: dOoC] #581937
01/14/10 05:17 AM
01/14/10 05:17 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i saw the bearing. it looks like someone took to it with a scraper. 2/3rds of the inner surface was like flaked off.
Re: 727 pump bearing [Re: rebel] #581938
01/14/10 05:29 AM
01/14/10 05:29 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
A pic is going to be worth 1000 words.
BTW .. there is a BUSHING in there .. not a bearing.
Re: 727 pump bearing [Re: rebel] #581939
01/14/10 05:30 AM
01/14/10 05:30 AM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
torqueflites do not have cooler flow in park.if you run it in park for a long time it could wipe out a pump bushing. run it in neutral.sonnax corp and transgo make a manual valve for the valve body that gives cooler flow in park. a bad electrical ground can cause bushings to pit,flake apart.run a ground strap from trans to frame.hope this helps john.
Re: 727 pump bearing [Re: dOoC] #581940
01/14/10 01:44 PM
01/14/10 01:44 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
yes you're right it is a bushing, sorry my bad, wrong word. it's not ptted but like flaked like chrome does when it falls off. sorry no pic.
Re: 727 pump bearing [Re: rebel] #581941
01/14/10 02:00 PM
01/14/10 02:00 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
I don't think that running in park would be the cause. --- Because, the pump is pumping in park. But it is not under pressure.
I know this because when I test a valve body on the flow bench, the fluid from the pump is gushing out of the manual valve bore hole.
Re: 727 pump bearing [Re: 727specialist] #581942
01/14/10 02:32 PM
01/14/10 02:32 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I always start my car neutral..just because of this..
Re: 727 pump bearing [Re: 727specialist] #581943
01/14/10 03:06 PM
01/14/10 03:06 PM
organ
maximum entropy Offline
organ
the converter does not charge in park. that bushing is pressurized in park, yes? maybe case misalignment?
Re: 727 pump bearing [Re: maximum entropy] #581944
01/14/10 04:06 PM
01/14/10 04:06 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The bushing is lubricated by the fluid that leaks past the pump rotors; if the crankshaft is turning, the pump rotors are turning and the bushing is being lubricated regardless of what gear it's in.
Re: 727 pump bearing [Re: John_Kunkel] #581945
01/15/10 03:17 AM
01/15/10 03:17 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
thanks for all the advice. i got my trans back today, fully checked, & flushed with a new bushing & a new drive hub on the converter. line pressure has been increased to help with band application so i'm told. the converter was split & checked & flushed & rewelded. hopefully it's all go. trans man didn't charge me so all is good i hope. he said he's seen the car on tv enough times so i might be hitting him up for sponsorship next season.
i think it was badly installed.
Re: 727 pump bearing [Re: rebel] #581946
01/15/10 03:46 AM
01/15/10 03:46 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Make sure the converter hub is not cracked.
Re: 727 pump bearing [Re: 451Mopar] #581947
01/15/10 08:43 AM
01/15/10 08:43 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
This reminds me of a plroblem I had years ago. I had a pump bushing failure twice before finding this little issue. Try looking at the dowl pins on the block and make sure that they are sticking out far enough to completly engage the mating holes in the transmission. In my car, the tapper on the dowl pin only engaged into the chamfer of the case and allowed it to move around. The end result was leaking converter seal and worn bushings.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: 727 pump bearing [Re: B1Johnny] #581948
01/15/10 11:09 AM
01/15/10 11:09 AM
NC
440Jim Offline
440Jim  Offline
NC
I would check the car grounding (engine/trans/chassis)
Re: 727 pump bearing [Re: 440Jim] #581949
01/15/10 04:31 PM
01/15/10 04:31 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i'm sure it's just a bad alinement problem caused by the trans mans assembly. the converter hub had some nasty grooves in it so they put a new drive hub on the converter for me this time. the engine is solid mounted so i doubt there's an earthing problem. the locating dowels on the engine/trans mating surface are a tight fit so i don't think thats a problem either. just a bad day in the trans shop.
