1966 Belvedere I from S6 Granny Car to 360 Sleeper
#512534
10/31/09 05:50 PM
10/31/09 05:50 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
1966 Belvedere I, 36K,S6,Bench,MS,MB,radio delete, converting to V8 K-framed,360/904/ 8 3/4.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper
[Re: Joesixpack]
#512535
10/31/09 05:55 PM
10/31/09 05:55 PM
Joesixpack
APACHE JUNCTION AZ
sold and removed S6,trans, 7 1/4, replaced rear with 8 3/4,4.56 742 case sure grip, SS springs,new gas tank,strap,3/8s sender...
[Re: Joesixpack]
#512539
10/31/09 06:31 PM
10/31/09 06:31 PM
Joesixpack
APACHE JUNCTION AZ
Aquired a 1972 360 core, tore it down,hot tanked,deck checked,align bore checked, block was bored .030,crank was cut 10/10, new Eagle I beam rods&Coated 9.1 Speed Pro pistons were aquired,B&M 904 Flex Plate, assembly was balanced,also added to the Nostalgic pile a Nos DC 525 mechanical cam&lifters,Sig Erson pushrods,DC Tach drive,electronic,mechanical advance distributor,double roller chain and gear set,hd pinned oil pump drive shaft,Offy port-o-sonic intake,2.02 915j heads....etc etc...
[Re: Joesixpack]
#512540
10/31/09 06:37 PM
10/31/09 06:37 PM
Joesixpack
APACHE JUNCTION AZ
Got a 904 core from a fellow member in IL, had it rebuilt with a Mancini HD rebuild kit, added a 3.8 servo lever,a Turbo Action RMVB, deep pan, also added a very nice(thanks Ken)4000 stall convertor fresh from Frank Lupo...cut out old floor pans....flintstone flyer!
[Re: Joesixpack]
#512554
10/31/09 10:11 PM
10/31/09 10:11 PM
Joesixpack
APACHE JUNCTION AZ
add some new lower ball joints,nos 778&779 Tbars, idler arm,reusing drum brakes for now, disc at a later date....oh yea 68 and up use larger steering gear box bolts!
[Re: Joesixpack]
#512556
10/31/09 10:19 PM
10/31/09 10:19 PM
Joesixpack
APACHE JUNCTION AZ
next up is rebuilding the soon to be delivered upper control arms, new ball joints, new upper control arm bushings, then install them on the car, torque the lower control arm pivot nuts..crank up the tbars....on to the brake and fuel lines, master cyl,splitter,install the interior,carpet, seats....
[Re: jake4cars]
#512560
03/27/10 02:36 PM
03/27/10 02:36 PM
Joesixpack
APACHE JUNCTION AZ
ok latest update, just picked up the 360 from Bob Horner the local engine guru,specs are 9.1 KB coated skirt pistons,I beam rods,525 DC Mech. cam,2.02 915 J heads,offy port-o-sonic intake,Pro Stock valve covers,B&M 904 flexplate,next up is getting the engine compartment ready,new brake lines,dual master,splitter,hoses etc, then we can drop the engine&trans in the hole!
[Re: Joesixpack]
#512561
03/27/10 04:02 PM
03/27/10 04:02 PM
Posts: 894 Connecticut, USA
sixty7gtx
Connecticut, USA
Nice car, I love post cars...
1967 Plymouth GTX, 1968 HEMI, 4 Spd. Super Bee, 2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
[Re: peabodyracing]
#512575
05/05/11 06:24 PM
05/05/11 06:24 PM
Joesixpack
APACHE JUNCTION AZ
Finally got back at it this week, got the 3/8s fuel line installed,front brake hoses,dual master cylinder,splitter,lines,steering collumn,headers,starter,seaat belts,rear seat.....
[Re: Joesixpack]
#512578
05/06/11 05:42 PM
05/06/11 05:42 PM
Joesixpack
APACHE JUNCTION AZ
5/06 more progress...distributor in,spark plugs in,wiring harness installed,voltage regulator,ballast resistor,oil pressure gauge in,temp sender in,went with Auto Meter electric water temp gauge...no where to plug in my nos moon mechanical water temp gauge...no threaded hole big or deep enough in that manifold...looks like i will mount MSD6C inside under dash,Mount mallory coil to left and below ballast resistor.removed entire heater box assembly, now got two nice holes to run wires thru....have to get some grommets...
[Re: Michael]
#512580
08/15/11 12:35 PM
08/15/11 12:35 PM
Joesixpack
APACHE JUNCTION AZ
Ok finally back at it....installed battery tray,cables,starter relay,horn relay,coil,MSD6C,ballast resistor,trans cooler lines,seat belts,electric water temp gauge..,horns,electronic ignition wiring harness....
[Re: Joesixpack]
#512581
08/15/11 12:39 PM
08/15/11 12:39 PM
Joesixpack
APACHE JUNCTION AZ
powdercoated tray&braces,(Thanks Larry at JIT),nice cad plated mounting bolts(thanks to my friend,the late "Big" Dan Buick)
[Re: Joesixpack]
#512582
08/23/11 05:53 PM
08/23/11 05:53 PM
Joesixpack
APACHE JUNCTION AZ
more progress......carb spacer,carb on,fuel line ran...alternator,brackets,spacers,bolts,pullies,spark plug wires(separators on order)wiring harness to alternator...
[Re: Joesixpack]
#512593
03/31/12 12:25 AM
03/31/12 12:25 AM
Joesixpack
APACHE JUNCTION AZ
Ok getting closer.....this week the following was done, gear lube in,brake drums on,radiator hoses on,new throttle cable,throttle cable holder,return springs&holder installed,driveshaft in,shifter mounted,cable ran,3/8s union installed in fuel line,hopefully will get time to get trans cooler on,install tach,put in some gas,trans fluid,top off radiator,and drop in a battery....and fire it up....run it,go thru gears,check for leaks,tighten everything up,break engine in....get header mufflers adapters and bolt on the screaming purple hornies..
[Re: Rhinodart]
#512604
12/08/12 12:35 PM
12/08/12 12:35 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Hope you get it figured out soon. I can imagine how anxious you are to hear it run. By now I think I'd have been slipping in a point style distributor and hot wiring it just to make some noise while you wait for the wiring diagram. Possibly you know someone who deals in ignition parts?
Lead, follow or get the hell out of the way
[Re: Joesixpack]
#512606
08/30/13 05:10 PM
08/30/13 05:10 PM
Joesixpack
APACHE JUNCTION AZ
8/30/2013 IT LIVES! RT66 Racer Mart B came by this morning and wired the MSD6C&Mallory coil...we filled the float bowls of the carb,hooked up a timing light.....hit the key and it roared to life...amazing sound....a few minor leaks(trans cooler lines,rad cooler line fitting,duh,tightened them up, hooked up the timing light,moved the dist a bit..., 1 minor fuel leak at float bowl screw(gasket delaminated,time to get nylon),and a few minor carb adjustments...sputter and dies....mechanical fuel pump needed to be primed...dropped line from pump to tank, back filed line with gas, reattached line, fired up and finallly gas flowed. warmed it up,no more trans leaks.no fuel leaks, no anti freeze leaks...its a great day!
[Re: CHAPPER]
#512610
09/01/13 09:16 AM
09/01/13 09:16 AM
peabodyracing
Minnesota
Way to go Bill! Congratulations.
[Re: Stroker]
#512622
09/14/13 07:58 PM
09/14/13 07:58 PM
Joesixpack
APACHE JUNCTION AZ
well i picked friday the 13th as get some stuff done day.....we bled the brakes, adjusted the shifter, put the hood on, added gas, fired up the engine, 1500 rpm for 12-14 minutes per the builder instructions to break in the cam. engine got to 180,thermostat opened,idled it down, shifted trans into reverse, ok, got reverse, then to "N", ok, into 1st, nothing, 2nd, nothing, 3rd, nothing, no foward gears....full of fluid, have to pull pan, pull valve body and air check some bands and servos...
[Re: Joesixpack]
#512638
11/08/13 09:48 PM
11/08/13 09:48 PM
Joesixpack
APACHE JUNCTION AZ
UPDATE 11/08 trans rebuilt(by Lee Kapustka)supposed to be sunny@59 Saturday....trans going back in...we will try it again!
[Re: Joesixpack]
#512643
11/17/13 09:37 AM
11/17/13 09:37 AM
peabodyracing
Minnesota
Way to go Bill! I can imagine how relieved you must feel.
[Re: peabodyracing]
#512644
11/17/13 12:11 PM
11/17/13 12:11 PM
Joesixpack
APACHE JUNCTION AZ
Thanks Larry, Having a second trans built right now as a spare, also bought a third trans as a "test" unit. I enjoy R&R ing them so much!the third unit is a A999 lock up,2.74 first gear,5 clutch drum...once the current combo is "worked in"would like to experiment with the lock up trans. use the 2.74 low gear to launch and get a better 60 foot time, a micro switch on the shifter, when i hit third gear it would lock up...A B-body small block combo is not real common...as time&finances allow would like to try an aluminum driveshaft, an aluminum third member,alloy lite weight axles,aluminum radiator, glass hood&scoop,as i think this is my last project...an aluminum headed 408 would be great for 2015.... https://www.facebook.com/photo.php?v=102...e=2&theater
[Re: Joesixpack]
#512647
03/31/14 02:15 PM
03/31/14 02:15 PM
peabodyracing
Minnesota
Congrats Bill. Looks darn good!
[Re: Joesixpack]
#512670
08/17/14 10:58 PM
08/17/14 10:58 PM
Joesixpack
APACHE JUNCTION AZ
on jack stands trans shifted fine....on the ground ....no had to rev engine to get it to even move at all. ouch. looks like we have a bad torque convertor...so out it comes ....trans taken to John at CRT...he check it out,pump,valve body,drums...everything is ok...sending the torque converter in TO GET IT CUT APART AND SEE WHATS FAILED...
[Re: Joesixpack]
#512673
09/16/14 02:25 PM
09/16/14 02:25 PM
Joesixpack
APACHE JUNCTION AZ
Drove it today! everything worked,no fires,no leaks, nothing fell off...stopped and did a holeshot,smoked tires and went sideways wow gotta learn how to drive all over again!
[Re: Joesixpack]
#1936079
10/21/15 11:49 AM
10/21/15 11:49 AM
Joesixpack
APACHE JUNCTION AZ
10/20/2015 US41 MOTORPLEX 6 PM PASS#1 13.69@97 CHECK OUT PASS
PASS#2 13.28@100.79
PASS#3 13.13@100.59 STREET TIRES, FOOT BRAKE 2400
[Re: Joesixpack]
#2218891
12/22/16 12:14 PM
12/22/16 12:14 PM
Posts: 929 Chicago
rocksmopar
Chicago
Congrats on the move to a warmer climate!!
Must feel good to be away from Illinois...
Looking for affordable 72-74 Cuda parts
[Re: rocksmopar]
#2771348
05/05/20 10:27 AM
05/05/20 10:27 AM
Joesixpack
APACHE JUNCTION AZ
new dual exhaust with dyna flow super turbos
