Page 1 of 9 1 2 3 4 5 6 7 8 9
1966 Belvedere I from S6 Granny Car to 360 Sleeper #512534
10/31/09 05:50 PM
10/31/09 05:50 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
1966 Belvedere I, 36K,S6,Bench,MS,MB,radio delete, converting to V8 K-framed,360/904/ 8 3/4.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512535
10/31/09 05:55 PM
10/31/09 05:55 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
sold and removed S6,trans, 7 1/4, replaced rear with 8 3/4,4.56 742 case sure grip, SS springs,new gas tank,strap,3/8s sender...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512536
10/31/09 05:57 PM
10/31/09 05:57 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
removed interior, floor pans shot,leaky heater core,wet feet, multiple patches...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512537
10/31/09 06:01 PM
10/31/09 06:01 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Taped off and sandblasted engine compartment,inner fenders,under floorpans...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512538
10/31/09 06:01 PM
10/31/09 06:01 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
bare metal!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512539
10/31/09 06:31 PM
10/31/09 06:31 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Aquired a 1972 360 core, tore it down,hot tanked,deck checked,align bore checked, block was bored .030,crank was cut 10/10, new Eagle I beam rods&Coated 9.1 Speed Pro pistons were aquired,B&M 904 Flex Plate, assembly was balanced,also added to the Nostalgic pile a Nos DC 525 mechanical cam&lifters,Sig Erson pushrods,DC Tach drive,electronic,mechanical advance distributor,double roller chain and gear set,hd pinned oil pump drive shaft,Offy port-o-sonic intake,2.02 915j heads....etc etc...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512540
10/31/09 06:37 PM
10/31/09 06:37 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Got a 904 core from a fellow member in IL, had it rebuilt with a Mancini HD rebuild kit, added a 3.8 servo lever,a Turbo Action RMVB, deep pan, also added a very nice(thanks Ken)4000 stall convertor fresh from Frank Lupo...cut out old floor pans....flintstone flyer!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512541
10/31/09 06:48 PM
10/31/09 06:48 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I hope you go with body color under the hood and not a re-shoot of that black? Sweet looking little car!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512542
10/31/09 06:50 PM
10/31/09 06:50 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
off to body shop for floor pan replacement.....cutting out of the old, fitting of the new...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512543
10/31/09 06:51 PM
10/31/09 06:51 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
ditto
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512544
10/31/09 06:52 PM
10/31/09 06:52 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
and the beat goes on...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512545
10/31/09 06:53 PM
10/31/09 06:53 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
lol that black WAS UNDERCOATING!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512546
10/31/09 09:35 PM
10/31/09 09:35 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Firewall stripped for prep to trip to body shop
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: ScottSmith_Harms] #512547
10/31/09 09:57 PM
10/31/09 09:57 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
chop,cut,rebuild
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper *DELETED* [Re: Joesixpack] #512548
10/31/09 10:00 PM
10/31/09 10:00 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Post deleted by Joesixpack
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512549
10/31/09 10:01 PM
10/31/09 10:01 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
blue shot on
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512550
10/31/09 10:03 PM
10/31/09 10:03 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
fenderwell
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512551
10/31/09 10:05 PM
10/31/09 10:05 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
next was drop 6 k-frame,tbars,upper control arms,lower control arms for a rebuild of front suspension to pony up for the V8
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512552
10/31/09 10:08 PM
10/31/09 10:08 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
presto chango, 1 powdercoated V8 68 Charger K-frame, original rebuilt lower control arms.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512553
10/31/09 10:09 PM
10/31/09 10:09 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
sweet!
