1966 Belvedere I from S6 Granny Car to 360 Sleeper
#512534
10/31/09 05:50 PM
10/31/09 05:50 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
1966 Belvedere I, 36K,S6,Bench,MS,MB,radio delete, converting to V8 K-framed,360/904/ 8 3/4.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper
[Re: Joesixpack]
#512535
10/31/09 05:55 PM
10/31/09 05:55 PM
Joesixpack
APACHE JUNCTION AZ
sold and removed S6,trans, 7 1/4, replaced rear with 8 3/4,4.56 742 case sure grip, SS springs,new gas tank,strap,3/8s sender...
[Re: Joesixpack]
#512539
10/31/09 06:31 PM
10/31/09 06:31 PM
Joesixpack
APACHE JUNCTION AZ
Aquired a 1972 360 core, tore it down,hot tanked,deck checked,align bore checked, block was bored .030,crank was cut 10/10, new Eagle I beam rods&Coated 9.1 Speed Pro pistons were aquired,B&M 904 Flex Plate, assembly was balanced,also added to the Nostalgic pile a Nos DC 525 mechanical cam&lifters,Sig Erson pushrods,DC Tach drive,electronic,mechanical advance distributor,double roller chain and gear set,hd pinned oil pump drive shaft,Offy port-o-sonic intake,2.02 915j heads....etc etc...
[Re: Joesixpack]
#512540
10/31/09 06:37 PM
10/31/09 06:37 PM
Joesixpack
APACHE JUNCTION AZ
Got a 904 core from a fellow member in IL, had it rebuilt with a Mancini HD rebuild kit, added a 3.8 servo lever,a Turbo Action RMVB, deep pan, also added a very nice(thanks Ken)4000 stall convertor fresh from Frank Lupo...cut out old floor pans....flintstone flyer!
