Page 4 of 9 1 2 3 4 5 6 7 8 9
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512594
04/10/12 04:57 PM
04/10/12 04:57 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
functional throttle cable bracket,return springs,new cable...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512595
04/10/12 04:58 PM
04/10/12 04:58 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Gates belt and hoses...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512596
04/10/12 05:00 PM
04/10/12 05:00 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
nors Delco Remy battery,from 1976-1977,from a Ford application I think, fits great in B-body tray, Nors repo battery cables.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512597
04/10/12 05:01 PM
04/10/12 05:01 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
742,4.56 traction lock 8 3/4,coming apart for freshing up....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512598
04/10/12 05:02 PM
04/10/12 05:02 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
balanced driveshaft installed
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512599
04/10/12 05:03 PM
04/10/12 05:03 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
11 inch rear brakes,replacing 10s
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512600
04/10/12 05:04 PM
04/10/12 05:04 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
after inital break in of engine,this will be going on....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512601
10/05/12 04:18 PM
10/05/12 04:18 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
ok put a fresh battery in it, hooked up cables....some issues....brake lights are on,no headlights,turned key to start,nothing, jumped relay and it did turn over...no spark....looks like there is some troubleshooting to do....10/04/2012
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512602
12/07/12 10:56 AM
12/07/12 10:56 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
12/07 Jim Rhinehart stopping by and were going to trouble shoot it and see if we can get it started today.Got a dozen krispy kremes so that should help.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512603
12/07/12 09:45 PM
12/07/12 09:45 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Well I helped working on the ignition and at least got it to turn over with the key. We still couldn't get spark through the MSD 6C but did get MSD to say they were emailing the wiring diagram, so some progress was made! I only got one Crusty Cop donut though, what was I thinking?
JB Rhinehart, Realist
A-Body's RULE!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Rhinodart] #512604
12/08/12 12:35 PM
12/08/12 12:35 PM
Minnesota
peabodyracing Offline
Minnesota
Hope you get it figured out soon. I can imagine how anxious you are to hear it run. By now I think I'd have been slipping in a point style distributor and hot wiring it just to make some noise while you wait for the wiring diagram. Possibly you know someone who deals in ignition parts?
Lead, follow or get the hell out of the way
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: peabodyracing] #512605
01/08/13 11:11 AM
01/08/13 11:11 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
I have the MSD 6C wiring schematic,but no gas line from house to garage,so no heat...supposed to be high 40s and low 50s later in the week,will rewire it and check for spark.yea after more years than i can count or even remember it will be good to hear it run...looks like 2013 will be its season.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512606
08/30/13 05:10 PM
08/30/13 05:10 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
8/30/2013 IT LIVES!
RT66 Racer Mart B came by this morning and wired the MSD6C&Mallory coil...we filled the float bowls of the carb,hooked up a timing light.....hit the key and it roared to life...amazing sound....a few minor leaks(trans cooler lines,rad cooler line fitting,duh,tightened them up, hooked up the timing light,moved the dist a bit..., 1 minor fuel leak at float bowl screw(gasket delaminated,time to get nylon),and a few minor carb adjustments...sputter and dies....mechanical fuel pump needed to be primed...dropped line from pump to tank, back filed line with gas, reattached line, fired up and finallly gas flowed. warmed it up,no more trans leaks.no fuel leaks, no anti freeze leaks...its a great day!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512607
08/30/13 05:14 PM
08/30/13 05:14 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
at speed
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512608
08/31/13 06:11 PM
08/31/13 06:11 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512609
08/31/13 09:31 PM
08/31/13 09:31 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
One of my favorite B-bodys..
If you like drag racing, support your local track.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: CHAPPER] #512610
09/01/13 09:16 AM
09/01/13 09:16 AM
Minnesota
Minnesota
Way to go Bill! Congratulations.
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: peabodyracing] #512611
09/07/13 09:12 PM
09/07/13 09:12 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
worked on it all day today....rewired electric wt gauge, it now works, tightened oil pan bolts, trans cooler lines, added brake fluid,cracked bleeders...coming along..
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512612
09/07/13 09:12 PM
09/07/13 09:12 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
view from below
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512613
09/07/13 09:13 PM
09/07/13 09:13 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
thats a wrap!
