Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper
[Re: peabodyracing]
#512575
05/05/11 06:24 PM
05/05/11 06:24 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
Finally got back at it this week, got the 3/8s fuel line installed,front brake hoses,dual master cylinder,splitter,lines,steering collumn,headers,starter,seaat belts,rear seat.....
[Re: Joesixpack]
#512578
05/06/11 05:42 PM
05/06/11 05:42 PM
Joesixpack
APACHE JUNCTION AZ
5/06 more progress...distributor in,spark plugs in,wiring harness installed,voltage regulator,ballast resistor,oil pressure gauge in,temp sender in,went with Auto Meter electric water temp gauge...no where to plug in my nos moon mechanical water temp gauge...no threaded hole big or deep enough in that manifold...looks like i will mount MSD6C inside under dash,Mount mallory coil to left and below ballast resistor.removed entire heater box assembly, now got two nice holes to run wires thru....have to get some grommets...
[Re: Michael]
#512580
08/15/11 12:35 PM
08/15/11 12:35 PM
Joesixpack
APACHE JUNCTION AZ
Ok finally back at it....installed battery tray,cables,starter relay,horn relay,coil,MSD6C,ballast resistor,trans cooler lines,seat belts,electric water temp gauge..,horns,electronic ignition wiring harness....
[Re: Joesixpack]
#512581
08/15/11 12:39 PM
08/15/11 12:39 PM
Joesixpack
APACHE JUNCTION AZ
powdercoated tray&braces,(Thanks Larry at JIT),nice cad plated mounting bolts(thanks to my friend,the late "Big" Dan Buick)
[Re: Joesixpack]
#512582
08/23/11 05:53 PM
08/23/11 05:53 PM
Joesixpack
APACHE JUNCTION AZ
more progress......carb spacer,carb on,fuel line ran...alternator,brackets,spacers,bolts,pullies,spark plug wires(separators on order)wiring harness to alternator...
[Re: Joesixpack]
#512593
03/31/12 12:25 AM
03/31/12 12:25 AM
Joesixpack
APACHE JUNCTION AZ
Ok getting closer.....this week the following was done, gear lube in,brake drums on,radiator hoses on,new throttle cable,throttle cable holder,return springs&holder installed,driveshaft in,shifter mounted,cable ran,3/8s union installed in fuel line,hopefully will get time to get trans cooler on,install tach,put in some gas,trans fluid,top off radiator,and drop in a battery....and fire it up....run it,go thru gears,check for leaks,tighten everything up,break engine in....get header mufflers adapters and bolt on the screaming purple hornies..
