Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512654
04/30/14 09:14 PM
04/30/14 09:14 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
tight on outer to quarter panel lip
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512655
06/08/14 03:45 PM
06/08/14 03:45 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
flanges welded unto headers...header mufflers bolted on, have to make some hangers...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512656
06/08/14 03:45 PM
06/08/14 03:45 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
4.56 installed, ujoints greased, driveshaft installed...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512657
06/08/14 03:46 PM
06/08/14 03:46 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
3 prong NSSW installed, have to wire it....got new pigtail...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512658
06/08/14 03:48 PM
06/08/14 03:48 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Gabriel Pro Shockers 3 way adjustable installed.(yea i know there old tech, but thats the way i roll)
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512659
06/08/14 03:50 PM
06/08/14 03:50 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
90/10 setting fist
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512660
06/08/14 03:51 PM
06/08/14 03:51 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Wizard Cooling 3 row,3/4 tube.22 inch aluminum radiator installed...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512661
06/08/14 03:52 PM
06/08/14 03:52 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
external trans cooler fabbed in...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512662
06/08/14 03:54 PM
06/08/14 03:54 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
went to local truck supply store,Standard Truck,got some neat brass adapter fittings and was able to use stock cooler steel lines hooked right to trans cooler lines...without cutting steel tubing and reflaring...clean
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512663
06/08/14 03:55 PM
06/08/14 03:55 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
closeup
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512664
06/21/14 07:02 PM
06/21/14 07:02 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
electric fan installed&wired
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512665
06/21/14 07:02 PM
06/21/14 07:02 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
new tach instlalled&wired
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512666
08/17/14 10:44 PM
08/17/14 10:44 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
another minor setback....remember to use thick spacer washers when you put back the shift cable bracket on the trans and bolt it up or this may happen.unreal the longer pan bolt went tru the top of the case and impacted the body of the NSSW....driven upward it broke the trans case...opps....gotta come out and ..no i did not do it....a "guy i know" who has worked at Chrysler Dealerships for 20 plus years was helping me out that day...ouch
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512667
08/17/14 10:47 PM
08/17/14 10:47 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
yank that broken case trans out....drop off core at Lee Kapustkas with a rebuild kit, bands, thrust washers...etc....have him rebuild a fresh one....get it back and ...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512668
08/17/14 10:50 PM
08/17/14 10:50 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
put in a new one...same converter ...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512669
08/17/14 10:53 PM
08/17/14 10:53 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512670
08/17/14 10:58 PM
08/17/14 10:58 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
on jack stands trans shifted fine....on the ground ....no had to rev engine to get it to even move at all. ouch. looks like we have a bad torque convertor...so out it comes ....trans taken to John at CRT...he check it out,pump,valve body,drums...everything is ok...sending the torque converter in TO GET IT CUT APART AND SEE WHATS FAILED...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512671
08/17/14 10:59 PM
08/17/14 10:59 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Trans back from John Cope at CRT...ready to go in....dug up a Hurst Shotgun Torque Converter for now...back to basics to get this car on the road...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512672
08/17/14 11:00 PM
08/17/14 11:00 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
real old school...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512673
09/16/14 02:25 PM
09/16/14 02:25 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Drove it today! everything worked,no fires,no leaks, nothing fell off...stopped and did a holeshot,smoked tires and went sideways wow gotta learn how to drive all over again!
