Throttle cable problem
#2768077
04/25/20 11:31 AM
04/25/20 11:31 AM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
I've found that my carburetor is not fully open when the pedal is floored. It seems to me that the problem is the throttle arm on my Demon carb needs to travel 2.5 inches to reach fully open and my throttle cable has only 2.25 inches of travel before it bottoms out. It is not an issue of pedal travel, its that the cable itself only has 2.25" of travel. Has anyone else had this problem and found a good solution? Does anyone know of a stock type throttle cable that has a bit more travel?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Throttle cable problem
[Re: Andrewh]
#2768086
04/25/20 11:43 AM
04/25/20 11:43 AM
MadMatt
Nampa, ID
I always thought it was where you hooked it up on the arm that made the difference. kind of a leverage thing. there was also a mopar adapter I never needed but for holley type carbs as well. I could attach it lower on the arm, but then I would have to change the bracket in order to have a straight pull and it would increase the throttle effort. I would also have to drill the throttle arm which I would rather avoid.
[Re: Sniper]
#2768101
04/25/20 12:19 PM
04/25/20 12:19 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I tried many different things.Ended up with a lokar throttle pedal raised up off the floor.
[Re: Sniper]
#2768108
04/25/20 12:51 PM
04/25/20 12:51 PM
MadMatt
Nampa, ID
Are you running the mopar throttle linkage adapter? No, it didn't seem necessary. I did have to adapt things a bit. Would the Mopar adapter somehow give me more travel on the throttle arm?
[Re: NITROUSN]
#2768124
04/25/20 01:38 PM
04/25/20 01:38 PM
MadMatt
Nampa, ID
Thanks, I actually saw that thread when I was searching the archives earlier. I may try that option.
[Re: topside]
#2768127
04/25/20 01:41 PM
04/25/20 01:41 PM
MadMatt
Nampa, ID
You have 3 choices, Matt -
1. Move the connection at the throttle arm lower 2. Move the cable bracket at the carb forward 3. Get a cable with more travel*
* may require modifying pedal lever or mounting to use the travel
This assumes you have the Mopar throttle arm adapter, though my racecar doesn't use one, but that's a fabbed-up deal. The amount of increased effort from #1 isn't much at all. Did you see the pictures I posted? There is a hole on the throttle arm a little lower and further back. I may try that one if I can make it work.
[Re: MadMatt]
#2768134
04/25/20 01:54 PM
04/25/20 01:54 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I use the next hole down on the lever and I also use the AR Engineering brackets on my 493. Here is a pic of the AR bracket on a small block. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: topside]
#2768283
04/25/20 10:22 PM
04/25/20 10:22 PM
MadMatt
Nampa, ID
Looking at that cable bracket, I'd want to play around there, and clean it up a bit too. You'll have to check travel, binding & return. You can also move the return springs so they work off the bottom hole and attach to that rear bracket. That cleans up the front bracket stuff; fewer parts to provide same function looks cleaner. I fixed it!
[Re: moparx]
#2768535
04/26/20 08:07 PM
04/26/20 08:07 PM
hemi-itis
I have 2 carbs with TR linkage,I tried every which way.Either no WOT or no idle.I had to raise the pedal assembly off the floor for more pull. Lokar pedal & throttle cable.
