Throttle cable problem #2768077
04/25/20 11:31 AM
04/25/20 11:31 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I've found that my carburetor is not fully open when the pedal is floored. It seems to me that the problem is the throttle arm on my Demon carb needs to travel 2.5 inches to reach fully open and my throttle cable has only 2.25 inches of travel before it bottoms out. It is not an issue of pedal travel, its that the cable itself only has 2.25" of travel. Has anyone else had this problem and found a good solution? Does anyone know of a stock type throttle cable that has a bit more travel?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Throttle cable problem [Re: MadMatt] #2768079
04/25/20 11:34 AM
04/25/20 11:34 AM
Andrewh Offline
Andrewh  Offline
I always thought it was where you hooked it up on the arm that made the difference.
kind of a leverage thing.
there was also a mopar adapter I never needed but for holley type carbs as well.
Re: Throttle cable problem [Re: Andrewh] #2768086
04/25/20 11:43 AM
04/25/20 11:43 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I could attach it lower on the arm, but then I would have to change the bracket in order to have a straight pull and it would increase the throttle effort. I would also have to drill the throttle arm which I would rather avoid.
Re: Throttle cable problem [Re: MadMatt] #2768091
04/25/20 11:51 AM
04/25/20 11:51 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Are you running the mopar throttle linkage adapter?
Re: Throttle cable problem [Re: Sniper] #2768101
04/25/20 12:19 PM
04/25/20 12:19 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I tried many different things.Ended up with a lokar throttle pedal raised up off the floor.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Throttle cable problem [Re: hemi-itis] #2768106
04/25/20 12:49 PM
04/25/20 12:49 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
You have 3 choices, Matt -
1. Move the connection at the throttle arm lower
2. Move the cable bracket at the carb forward
3. Get a cable with more travel*
* may require modifying pedal lever or mounting to use the travel
This assumes you have the Mopar throttle arm adapter, though my racecar doesn't use one, but that's a fabbed-up deal.
The amount of increased effort from #1 isn't much at all.
Re: Throttle cable problem [Re: Sniper] #2768108
04/25/20 12:51 PM
04/25/20 12:51 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
No, it didn't seem necessary. I did have to adapt things a bit. Would the Mopar adapter somehow give me more travel on the throttle arm?
Re: Throttle cable problem [Re: MadMatt] #2768113
04/25/20 01:03 PM
04/25/20 01:03 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The adapter moves the cable connection lower, which means it doesn’t have to travel as far to gomWide open.
It’s like a long breaker bar or a long shift lever. You are Doing the same work at the pivot point, but the further out from the pivot point you travel much further to do the movement.
Re: Throttle cable problem [Re: MadMatt] #2768120
04/25/20 01:22 PM
04/25/20 01:22 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
I had the same problem. Read the second to last post. I put the part number of the cable I used.
https://board.moparts.org/ubbthread...e-throttle-cable-dilema.html#Post2697197
Re: Throttle cable problem [Re: NITROUSN] #2768123
04/25/20 01:30 PM
04/25/20 01:30 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What Nanket said is true.
Re: Throttle cable problem [Re: NITROUSN] #2768124
04/25/20 01:38 PM
04/25/20 01:38 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Thanks, I actually saw that thread when I was searching the archives earlier. I may try that option.
Re: Throttle cable problem [Re: topside] #2768127
04/25/20 01:41 PM
04/25/20 01:41 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Did you see the pictures I posted? There is a hole on the throttle arm a little lower and further back. I may try that one if I can make it work.
Re: Throttle cable problem [Re: MadMatt] #2768134
04/25/20 01:54 PM
04/25/20 01:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use the next hole down on the lever and I also use the AR Engineering brackets on my 493. Here is a pic of the AR bracket on a small block.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Throttle cable problem [Re: fourgearsavoy] #2768258
04/25/20 08:32 PM
04/25/20 08:32 PM
A collage of whims
A collage of whims
Looking at that cable bracket, I'd want to play around there, and clean it up a bit too.
You'll have to check travel, binding & return.
You can also move the return springs so they work off the bottom hole and attach to that rear bracket.
That cleans up the front bracket stuff; fewer parts to provide same function looks cleaner.
Re: Throttle cable problem [Re: topside] #2768264
04/25/20 08:58 PM
04/25/20 08:58 PM
N
N
This is what mine ended up looking like.
Re: Throttle cable problem [Re: topside] #2768283
04/25/20 10:22 PM
04/25/20 10:22 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I fixed it!
Re: Throttle cable problem [Re: MadMatt] #2768384
04/26/20 11:42 AM
04/26/20 11:42 AM
moparx Offline
moparx  Offline
good deal ! up
beer
Re: Throttle cable problem [Re: moparx] #2768535
04/26/20 08:07 PM
04/26/20 08:07 PM
hemi-itis Offline
hemi-itis  Offline
I have 2 carbs with TR linkage,I tried every which way.Either no WOT or no idle.I had to raise the pedal assembly off the floor for more pull.
Lokar pedal & throttle cable.
