Re: gas gauge not working
[Re: tak]
#231360
02/21/09 07:05 PM
02/21/09 07:05 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
I'm going to try both suggestion. Yes it is a new sender but quality of parts being what they are it wouldn't suprise me if the float is full of fuel. I'll check that if all else fails. I kept the old one I think. Thanks guys.
Try grounding the gauge first and see if it reads past full. Your sending unit float is probably fine.
[Re: plymguy]
#231364
02/22/09 09:40 AM
02/22/09 09:40 AM
68CoronetRT
Arizona
My '67 Fury is doing the same thing. I grounded the wire feeding the sender and the gauge went up to full. I made sure that the fuel tube is grounded to the frame. It usually reads just above empty but sometimes will go up to half. When I fill the tank it will go to full after a few minutes but then back to just above empty. Does that sound like ground problems or sender on the way out? John
Sender is bad.
[Re: ngpSatellite]
#231366
02/22/09 11:02 AM
02/22/09 11:02 AM
where can you get a GOOD American sending unit from??
goodluck, i got 3 sending units REPRO garbage and they all read 3/4 full when full. even yearones sending units suck!!
[Re: tak]
#231367
02/22/09 11:10 AM
02/22/09 11:10 AM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
If everything else checks out okay, here's where I've found problems. On the back of the gauge pod where the nuts attach the gauges to the circuit board, remove the nuts and clean the corrosion off the circuit flats. I've found these dirty, even loose, causing gauge problems. Clean them all while you're back there. You'll have to remove the cluster to do it correctly.
#231368
02/22/09 02:31 PM
02/22/09 02:31 PM
Posts: 936 own private Idaho
ngpSatellite
own private Idaho
does anyone make rebuild kits??
Re: gas gauge not working-----------UPDATE!!!!!
[Re: tak]
#231369
03/07/09 09:51 PM
03/07/09 09:51 PM
Posts: 340 Ohio
tak
Ohio
Thought I'ld give an update on the gas gauge, FIXED! Finally had time to pull the sender after testing the gauge, the float was full of gas. Thanks to everyone for the help and advice !!!
