gas gauge not working #231356
02/21/09 03:01 PM
02/21/09 03:01 PM
Ohio
tak Offline OP
tak  Offline OP
Ohio
I'm getting the little things fixed before spring, my gas gauge in the 71 RR doen't work most of the time. I have a new sender and I do have the ground clip on the line. The wire is in good shape, I do know that much. I have held the ground clip tight in the gas line so I'm PRETTY sure it's not that. Is there a way to check the gauge? The ground on the back of the gauge has been check and is definitely good.
Re: gas gauge not working [Re: tak] #231357
02/21/09 03:14 PM
02/21/09 03:14 PM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
Ground the wire at the sender on the tank. IF the gauge does not read extra full the gauge/dash pcb or wire to gauge is bad.
My guess the float is full of fuel and does not follow the fuel level.
Our 440 73 Dart currently has a bad sender stuck at bottom so reads empty.
Re: gas gauge not working [Re: tak] #231358
02/21/09 03:16 PM
02/21/09 03:16 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Take a jumper wire from the sender to a clean spot on the frame. If it works at times it sounds like and intermittent ground. Check all your body grounds. Battery should have a good ground and the engine should have a good ground from the rear of the engine to the fire wall.
stated new sender.
Re: gas gauge not working [Re: MoparforLife] #231359
02/21/09 03:55 PM
02/21/09 03:55 PM
Ohio
tak Offline OP
tak  Offline OP
Ohio
I'm going to try both suggestion. Yes it is a new sender but quality of parts being what they are it wouldn't suprise me if the float is full of fuel. I'll check that if all else fails. I kept the old one I think. Thanks guys.
Re: gas gauge not working [Re: tak] #231360
02/21/09 07:05 PM
02/21/09 07:05 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Try grounding the gauge first and see if it reads past full.
Your sending unit float is probably fine.
Re: gas gauge not working [Re: 68CoronetRT] #231361
02/21/09 07:42 PM
02/21/09 07:42 PM
MA.
P
plymguy Offline
plymguy  Offline
P
MA.
My '67 Fury is doing the same thing. I grounded the wire feeding the sender and the gauge went up to full. I made sure that the fuel tube is grounded to the frame. It usually reads just above empty but sometimes will go up to half. When I fill the tank it will go to full after a few minutes but then back to just above empty. Does that sound like ground problems or sender on the way out?
John
Re: gas gauge not working [Re: plymguy] #231362
02/21/09 11:50 PM
02/21/09 11:50 PM
Ohio
tak Offline OP
tak  Offline OP
Ohio
This sounds almost exactly what mine is doing, anyone?
Re: gas gauge not working [Re: tak] #231363
02/21/09 11:59 PM
02/21/09 11:59 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Just replace my sender(w/float) in my cuda. Float was full of fuel. Diagnosis when I grounded the wire the gauge went to full. BTW last year when ever I drove the car I would put a couple of gallons in to be safe,well when I removed the retainer ring on the unit it was full.Had to quick locate a bucket to catch a gallon or two.
Re: gas gauge not working [Re: plymguy] #231364
02/22/09 09:40 AM
02/22/09 09:40 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
John
Sender is bad.
Re: gas gauge not working [Re: 68CoronetRT] #231365
02/22/09 10:01 AM
02/22/09 10:01 AM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
where can you get a GOOD American sending unit from??
Re: gas gauge not working [Re: ngpSatellite] #231366
02/22/09 11:02 AM
02/22/09 11:02 AM
goodluck, i got 3 sending units REPRO garbage and they all read 3/4 full when full. even yearones sending units suck!!
Re: gas gauge not working [Re: tak] #231367
02/22/09 11:10 AM
02/22/09 11:10 AM
God's Country Maryland
GODSCOUNTRY340 Offline
If everything else checks out okay, here's where I've found problems. On the back of the gauge pod where the nuts attach the gauges to the circuit board, remove the nuts and clean the corrosion off the circuit flats. I've found these dirty, even loose, causing gauge problems. Clean them all while you're back there. You'll have to remove the cluster to do it correctly.
Re: gas gauge not working #231368
02/22/09 02:31 PM
02/22/09 02:31 PM
own private Idaho
N
N
own private Idaho
does anyone make rebuild kits??
Re: gas gauge not working-----------UPDATE!!!!! [Re: tak] #231369
03/07/09 09:51 PM
03/07/09 09:51 PM
Ohio
tak Offline OP
tak  Offline OP
Ohio
Thought I'ld give an update on the gas gauge, FIXED! Finally had time to pull the sender after testing the gauge, the float was full of gas. Thanks to everyone for the help and advice !!!
