Ground the wire at the sender on the tank. IF the gauge does not read extra full the gauge/dash pcb or wire to gauge is bad.
My guess the float is full of fuel and does not follow the fuel level.
Our 440 73 Dart currently has a bad sender stuck at bottom so reads empty.
