If everything else checks out okay, here's where I've found problems. On the back of the gauge pod where the nuts attach the gauges to the circuit board, remove the nuts and clean the corrosion off the circuit flats. I've found these dirty, even loose, causing gauge problems. Clean them all while you're back there. You'll have to remove the cluster to do it correctly.
I love the smell of Deer guts in the morning, it smells like... VICTORY!
