Qa1 k member #2164176
09/29/16 07:45 AM
09/29/16 07:45 AM
plainwell,michigan
1fastaspen Offline OP
plainwell,michigan
Has anyone used one of these if so what do you think of it thanks for the feed back
75 duster 440 in the works
71 pro street cuda
Re: Qa1 k member [Re: 1fastaspen] #2164712
09/29/16 10:04 PM
09/29/16 10:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Stay away, they bought that design from caps. No one has had any good luck with caps.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Qa1 k member [Re: 1fastaspen] #2164799
09/29/16 11:47 PM
09/29/16 11:47 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Seems Tory's deal is about one of the top deals goin.
Re: Qa1 k member [Re: 1fastaspen] #2164802
09/29/16 11:50 PM
09/29/16 11:50 PM
Ohio
lockjaw-express Offline
Ohio
I got the RMS Alterkation for my 1968 super Bee...it replaces the torsion bars and has coil-over shock and rack steering. I am very impressed with it!
More expensive, but well worth it. I will eventually replace my GTX with one too.
Re: Qa1 k member [Re: 1fastaspen] #2164812
09/29/16 11:58 PM
09/29/16 11:58 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
IIRC member 70aarcuda's Duster has a QA1 K on it for some time. Pretty sure he's putting one on his other daughters Dart....
Re: Qa1 k member [Re: 1967dartgt] #2164826
09/30/16 12:18 AM
09/30/16 12:18 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I know several guys running them for years with zero issues. Shouldn't bad mouth them, saying nobody likes them. It's flat not true
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Qa1 k member [Re: B3422W5] #2164860
09/30/16 01:21 AM
09/30/16 01:21 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
One of our local guys runs one.. and seems to be very happy. With it. But myself I have no personal experience with it
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Qa1 k member [Re: 1fastaspen] #2164898
09/30/16 02:21 AM
09/30/16 02:21 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have raced a few times over the years with Ray, the Canadian who started CAP back probably 10 years ago now. He campaigns a 65-66 ish Dart that runs mid 9's. Seen him at US131 a few times and chatted with him.
Real nice guy, and sold a good product, especially if your looking for more room.
I think there was a story a few years back about bad welds or something on one of the K members. Not cool, but not the norm.
Nobody is perfect but I have seen them in use and they seem to work well and be safe
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Qa1 k member [Re: 1967dartgt] #2164947
09/30/16 05:40 AM
09/30/16 05:40 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
Running a cap for years no issues and ray was very supportive ,just saying....go 143 mph
Re: Qa1 k member [Re: 1fastaspen] #2164956
09/30/16 06:45 AM
09/30/16 06:45 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I have one CAP and two QA1 k members...all fit just find...
One of the QA1 on 71 Duster has a torsion bar elimination kit from Geist Suspension...I am in the process of doing the same on the 71 Dart with a QA1 K member using the Kit from Hemi Denny...I basically finished it today except waiting on double adjustable shocks ..UPS says they will be here on Monday...
My Demon has the CAP K member and it has been in use for 5 or more years...
Tony
70 AARCuda Vitamin C
Re: Qa1 k member [Re: 1fastaspen] #2164970
09/30/16 08:22 AM
09/30/16 08:22 AM
plainwell,michigan
plainwell,michigan
Thanks for the replays guys
71 pro street cuda
Re: Qa1 k member [Re: 1fastaspen] #2164991
09/30/16 10:19 AM
09/30/16 10:19 AM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I have the old CAP with a rack and pinion in my 3500 LBS 69 GTX. Tons of room even with torsion bars and big headers on a 540 inch Hemi. The GTX drives as nice at 140 mph as my new SRT Challenger does.
If QA1 produces them with a rack I will be switching over my other Mopars. Don't believe EVERYTHING you see on the internet.
Re: Qa1 k member [Re: 1fastaspen] #2165057
09/30/16 12:41 PM
09/30/16 12:41 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
from what I've seen the "Alter K" is a really nice piece, and certainly robust enough for street duty. My K set up is pretty much track only as per chassis shop. Something you might keep in mind depending on usage.
Re: Qa1 k member [Re: 1fastaspen] #2165086
09/30/16 01:18 PM
09/30/16 01:18 PM
I had a early CAP K member for 1963 to 1966 A bodys with stock steering and torsion bars that I sold to Mopar Billy, I beleive it is in his drag week Valient shruggy
Maybe he will see this post and chip in on his thoughts and results on his luck
I wanted one with front mount rack and pinion steering for A arms with coil over to eliminate the torson bars for more header clearances is the reason I didn't use it shruggy
Re: Qa1 k member [Re: Cab_Burge] #2165203
09/30/16 05:23 PM
09/30/16 05:23 PM
Wisconsin
Jet Doc Offline
Jet Doc  Offline
Wisconsin
I have a QA1 front end on my 67 Barracuda, it's probably the best driving Mopar I've ever owned, launches straight and steers like it's on rails.
Re: Qa1 k member [Re: 1fastaspen] #2165330
09/30/16 07:27 PM
09/30/16 07:27 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Looking at the add it does not say rack or std steering
Re: Qa1 k member [Re: 1fastaspen] #2165346
09/30/16 07:46 PM
09/30/16 07:46 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
What rack does this use?
Re: Qa1 k member [Re: 1fastaspen] #2165414
09/30/16 09:29 PM
09/30/16 09:29 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I have looked at the QA1 at shows, just doesn't have enough improvements over a lightened stock K for me.
I run one of Tory's front ends and I'll never say what my car runs but I have no complaints in my fast small tire street car
Re: Qa1 k member [Re: Cab_Burge] #2165515
09/30/16 11:49 PM
09/30/16 11:49 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Cab I had a chance to look Mopar Billys car over this year at drag week and He did mention that the K member he was running came from you. If you every get aline on another please keep me in mind Id like to put one on in my Valiant. up
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Qa1 k member [Re: turbo toad] #2165520
09/30/16 11:58 PM
09/30/16 11:58 PM
I got that one from Al Aquire shruggy
I'll try to keep my ears and memory open for one up
