Originally Posted By Cab_Burge
I had a early CAP K member for 1963 to 1966 A bodys with stock steering and torsion bars that I sold to Mopar Billy, I beleive it is in his drag week Valient shruggy
Maybe he will see this post and chip in on his thoughts and results on his luck
I wanted one with front mount rack and pinion steering for A arms with coil over to eliminate the torson bars for more header clearances is the reason I didn't use it shruggy
Cab I had a chance to look Mopar Billys car over this year at drag week and He did mention that the K member he was running came from you. If you every get aline on another please keep me in mind Id like to put one on in my Valiant. up
Check out my build on Facebook Ttoad Hurley its updated regularly
