Qa1 k member
#2164176
09/29/16 07:45 AM
09/29/16 07:45 AM
Posts: 257 plainwell,michigan
1fastaspen
plainwell,michigan
Has anyone used one of these if so what do you think of it thanks for the feed back
75 duster 440 in the works
71 pro street cuda
Re: Qa1 k member
[Re: 1fastaspen]
#2164712
09/29/16 10:04 PM
09/29/16 10:04 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Stay away, they bought that design from caps. No one has had any good luck with caps.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Qa1 k member
[Re: 1967dartgt]
#2164826
09/30/16 12:18 AM
09/30/16 12:18 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Stay away, they bought that design from caps. No one has had any good luck with caps. I know several guys running them for years with zero issues. Shouldn't bad mouth them, saying nobody likes them. It's flat not true
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Qa1 k member
[Re: B3422W5]
#2164860
09/30/16 01:21 AM
09/30/16 01:21 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
One of our local guys runs one.. and seems to be very happy. With it. But myself I have no personal experience with it
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Qa1 k member
[Re: 1fastaspen]
#2164898
09/30/16 02:21 AM
09/30/16 02:21 AM
B3422W5
Portage,michigan
I have raced a few times over the years with Ray, the Canadian who started CAP back probably 10 years ago now. He campaigns a 65-66 ish Dart that runs mid 9's. Seen him at US131 a few times and chatted with him. Real nice guy, and sold a good product, especially if your looking for more room. I think there was a story a few years back about bad welds or something on one of the K members. Not cool, but not the norm. Nobody is perfect but I have seen them in use and they seem to work well and be safe
Re: Qa1 k member
[Re: 1fastaspen]
#2164956
09/30/16 06:45 AM
09/30/16 06:45 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
I have one CAP and two QA1 k members...all fit just find...
One of the QA1 on 71 Duster has a torsion bar elimination kit from Geist Suspension...I am in the process of doing the same on the 71 Dart with a QA1 K member using the Kit from Hemi Denny...I basically finished it today except waiting on double adjustable shocks ..UPS says they will be here on Monday...
My Demon has the CAP K member and it has been in use for 5 or more years...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Qa1 k member
[Re: 1fastaspen]
#2165086
09/30/16 01:18 PM
09/30/16 01:18 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
I had a early CAP K member for 1963 to 1966 A bodys with stock steering and torsion bars that I sold to Mopar Billy, I beleive it is in his drag week Valient Maybe he will see this post and chip in on his thoughts and results on his I wanted one with front mount rack and pinion steering for A arms with coil over to eliminate the torson bars for more header clearances is the reason I didn't use it
Re: Qa1 k member
[Re: Cab_Burge]
#2165515
09/30/16 11:49 PM
09/30/16 11:49 PM
Posts: 368 michigan
turbo toad
michigan
I had a early CAP K member for 1963 to 1966 A bodys with stock steering and torsion bars that I sold to Mopar Billy, I beleive it is in his drag week Valient Maybe he will see this post and chip in on his thoughts and results on his I wanted one with front mount rack and pinion steering for A arms with coil over to eliminate the torson bars for more header clearances is the reason I didn't use it Cab I had a chance to look Mopar Billys car over this year at drag week and He did mention that the K member he was running came from you. If you every get aline on another please keep me in mind Id like to put one on in my Valiant.
Check out my build on Facebook Ttoad Hurley its updated regularly
