FINALLY got me a 360..
#2074113
05/15/16 09:20 PM
05/15/16 09:20 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
.. I had to pull it, $50. Lol. Now lets see how much horsepower that stock block can handle. Ok seriously though, after working 20 years with big blocks, this will be my first serious N/A small block build. please excuse the noob questions.. This is a run of the mill 74 360, no windage tray, etc. Is there enough meat on the block for a 4-bolt main conversion (if even available)? Or would it make that area weaker on a stock block? Is a stock mains and stud kit plenty for say 6500-6700 rpm (will be a 4" stroke crank)? I'm sure I'll have more questions later on, thanks. And got this for 10 bucks, cause nothing short of a dominator will do but that's way down the road.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: FINALLY got me a 360..
[Re: DARTH V8Я]
#2074121
05/15/16 09:29 PM
05/15/16 09:29 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I wouldn't do a four bolt main, weakens block. I ran stock 340 blocks harder then that with arp studs. I would also do a short fill to give it a little more stability.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: DARTH V8Я]
#2074128
05/15/16 09:36 PM
05/15/16 09:36 PM
Posts: 4,457 Washington
madscientist
Washington
There are guys who put 4 bolt caps on Pcar blocks but it is a waste of time and WILL make the block weaker.
BTW with that stroke and those mains, I would have no less that .0036-.0038 main clearance. The block will flex and eat up the clearance.
[Re: DARTH V8Я]
#2074190
05/15/16 10:39 PM
05/15/16 10:39 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Not sure how fast you are lookin to go but I beat the snot out of a stock stroke iron headed truck 360 w/a clean up and GOOD valve job from Pettis, a solid Isky flat tappet cam and it went 11.80`s at L.A.C.R`s altitude track and was my daily driver............not stellar but fun..........
[Re: madscientist]
#2074222
05/15/16 11:23 PM
05/15/16 11:23 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
BTW with that stroke and those mains, I would have no less that .0036-.0038 main clearance. The block will flex and eat up the clearance. Not only the mains, mine was flexing enough the cam bearings had grooves in them.
[Re: DARTH V8Я]
#2074228
05/15/16 11:32 PM
05/15/16 11:32 PM
Posts: 13,194 aZLiViN
J_BODY
aZLiViN
sheesh! we went from R blocks and Ritter blocks to this??? at least we know you are sane now!! We had a nice 340 block build that went a best of 9.8's. Only had a roll bar so my dad was shifting at like 5800 with a 4.3 gear. Bumped it up to 6800 it really got with it... I'm betting more gear and some tuning we would have been able to get some 9.6's out of it.... unfortunately it met a leaky W5 untimely death. If those heads would have been worth a krap I'm betting we'd still be wheeling that mill. 4" stroke, 2 bolt main, 13.5 to 1 compression, Indy intake with 4500 adapter. life was so much simpler then.....
[Re: J_BODY]
#2074284
05/16/16 01:05 AM
05/16/16 01:05 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Looks it a fun build. Im in the process of building one myself for my sister... Eagle rods K1 crank SRP Pistons 4in stroke. Solid flat tappet and Edelbrock heads. I ran a 408 built on a 1999 block with 360-1 . It was a 2 bolt Main...man put a ton of passes on thing.good luck
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: DARTH V8Я]
#2074329
05/16/16 02:51 AM
05/16/16 02:51 AM
DARTH V8Я
Its a TRAP!
@ Thumperdart - looking for high 9's @ 3100#. Going tomorrow to buy a used 1050 Dominator, will be sending it to you when I'm ready @ 1967dartgt & madscientest - roger that, no 4-bolt mains. ARP mains studs on stock or aftermarket caps? @ J-Body R's are out there, but suddenly the prices went Sky High, guess cause now when they are no longer being produced. Talked with a few people about the Ritter block, machine costs alone would be quadruple to a very well machined/prepped stock block. So had to go with plan 'c'.. the 50 dollar engine lol. Indy 360-1's are still the plan. Now the short fill question. Necessary for a street driven engine that'll only see the track twice a year @ the ET i'm gunning for? I'm not fond of filled blocks, however if it makes it more stable, I guess I'll have to be open to the idea. @ whitedart good to know the 2-bolt mains held up, thanks.
[Re: DARTH V8Я]
#2074330
05/16/16 02:58 AM
05/16/16 02:58 AM
madscientist
Washington
Studs and a short fill. Good to go.
[Re: DARTH V8Я]
#2074477
05/16/16 12:56 PM
05/16/16 12:56 PM
Thumperdart
State of confusion
@ Thumperdart - looking for high 9's @ 3100#. Going tomorrow to buy a used 1050 Dominator, will be sending it to you when I'm ready @ 1967dartgt & madscientest - roger that, no 4-bolt mains. ARP mains studs on stock or aftermarket caps? @ J-Body R's are out there, but suddenly the prices went Sky High, guess cause now when they are no longer being produced. Talked with a few people about the Ritter block, machine costs alone would be quadruple to a very well machined/prepped stock block. So had to go with plan 'c'.. the 50 dollar engine lol. Indy 360-1's are still the plan. Now the short fill question. Necessary for a street driven engine that'll only see the track twice a year @ the ET i'm gunning for? I'm not fond of filled blocks, however if it makes it more stable, I guess I'll have to be open to the idea. @ whitedart good to know the 2-bolt mains held up, thanks. Oh, more smallblocks whoopin on big blocks...........I get it.......... I`ve got blocks, boosters and bowls lookin for a good home............
[Re: qwkmopardan]
#2074594
05/16/16 04:38 PM
05/16/16 04:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Can you tell me the specs on the STX22.. I couldnt find them on line.... I'm looking to change cams... thanks
[Re: DARTH V8Я]
#2074600
05/16/16 04:54 PM
05/16/16 04:54 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
STX-21M 306 272@.050 .560 .597
[Re: krautrock]
#2074609
05/16/16 05:11 PM
05/16/16 05:11 PM
MR_P_BODY
Thanks..... what LSA are the STX22 ground on.. and I assume its a solid FT cam
[Re: MR_P_BODY]
#2074859
05/17/16 12:08 AM
05/17/16 12:08 AM
madscientist
Washington
Thanks..... what LSA are the STX22 ground on.. and I assume its a solid FT cam Jim will pretty much grind his lobes on the LSA you want. He also has lobes not on that web site. You just have to call him. I'm using a lobe not on Dons site.
[Re: DARTH V8Я]
#2074876
05/17/16 12:48 AM
05/17/16 12:48 AM
DARTH V8Я
Its a TRAP!
@ qwkmopardan ~ thanks for the info. Didn't think those "smogger" heads had enough flow for a 9 second pass. Nice combo BTW. @ thumperdart you bet buddy :thumb: & duly noted expect a package later on Solid rollers question: I know they are spendy, but PITA to install & clearance or pretty straight forward? Thanks.
[Re: DARTH V8Я]
#2074894
05/17/16 01:09 AM
05/17/16 01:09 AM
DARTH V8Я
Its a TRAP!
Also I've seen a lot of things in my life, but never, NEVER had I ever had all the exhaust manifold bolts come out without a hitch! Guess VC leaks were a good thing in my engines case. To quote Spock.. "Fascinating".
[Re: DARTH V8Я]
#2074899
05/17/16 01:27 AM
05/17/16 01:27 AM
madscientist
Washington
@ qwkmopardan ~ thanks for the info. Didn't think those "smogger" heads had enough flow for a 9 second pass. Nice combo BTW. @ thumperdart you bet buddy :thumb: & duly noted expect a package later on Solid rollers question: I know they are spendy, but PITA to install & clearance or pretty straight forward? Thanks. Pretty straight forward on SRL install. I question the head deal myself. But, and this is a big butt, to go 9's in a 3100 pound car takes about 595 HP and in the correct combo any Pcar head can do that.
[Re: DARTH V8Я]
#2074903
05/17/16 01:34 AM
05/17/16 01:34 AM
justinp61
W. Kentucky
@ qwkmopardan ~ thanks for the info. Didn't think those "smogger" heads had enough flow for a 9 second pass. Nice combo BTW. @ thumperdart you bet buddy :thumb: & duly noted expect a package later on Solid rollers question: I know they are spendy, but PITA to install & clearance or pretty straight forward? Thanks. If you buy the right lifters there shouldn't be any grinding. I've seen Dan's stuff run, there is no bs there, it runs hard.
[Re: DARTH V8Я]
#2074904
05/17/16 01:39 AM
05/17/16 01:39 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I am going to lurk in the background on this thread because last Monday I bought a 360 in pieces from a guy on Craigslist. It was a 1990 roller cam engine, the block was standard bore and had been hot tanked but not bored, the heads had been rebuilt and came with a Delta Cam regrind (new). The crank seems to be standard, but I also have a fresh .010/.010 stock stroke crank. It also had a truck pan and factory windage tray. He gave me a new mini-starter with it and some other scrap iron, intake & exhaust manifolds. So I think it was worth the $150.00 I paid for it. It will go in the DD when it is done.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: DARTH V8Я]
#2074915
05/17/16 02:21 AM
05/17/16 02:21 AM
DARTH V8Я
Its a TRAP!
Well that's good to know the Pcar heads can get up and boogie! What kind of compression are you guys getting away with on an iron headed with 92oct E10 swill?
[Re: DARTH V8Я]
#2074934
05/17/16 03:29 AM
05/17/16 03:29 AM
madscientist
Washington
11.08:1 on pump gas.
[Re: DARTH V8Я]
#2075022
05/17/16 11:27 AM
05/17/16 11:27 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I have comp 828-16s in a 76 model 360 block. They are close but no grinding was needed. I did need to tube the block though because they were uncovering the oil holes.
68 Barracuda Formula S 340
[Re: DARTH V8Я]
#2075228
05/17/16 05:10 PM
05/17/16 05:10 PM
DARTH V8Я
Its a TRAP!
All righty I like the idea of 11:1 on pump gas with iron heads. Nothing like smoking aluminum headed BBC's with an iron headed engine.
[Re: DARTH V8Я]
#2075256
05/17/16 06:02 PM
05/17/16 06:02 PM
madscientist
Washington
All righty I like the idea of 11:1 on pump gas with iron heads. Nothing like smoking aluminum headed BBC's with an iron headed engine. I haven't got it in the car yet. It's on the run in stand now and runs, just dealing with a pissy carb right now. Was going to dyno it but I'm just burning out in the deal and it may go straight to the car.
[Re: DARTH V8Я]
#2075308
05/17/16 08:01 PM
05/17/16 08:01 PM
DARTH V8Я
Its a TRAP!
Roller cam? What kind of timing are you running with the iron heads?
[Re: DARTH V8Я]
#2075312
05/17/16 08:11 PM
05/17/16 08:11 PM
MR_P_BODY
Roller cam? What kind of timing are you running with the iron heads? With my 416 and W-2 iron heads I am running 10.6 compression and 36* of timing.. its a decent size roller cam 260/270 on a 105 LSA installed on 105.. that with .640/.640 lift... on the street I run 87 octane.. I will run 93 at the track... I get on it pretty good on the street with the 87 and no issues
[Re: DARTH V8Я]
#2075327
05/17/16 08:32 PM
05/17/16 08:32 PM
madscientist
Washington
Roller cam? What kind of timing are you running with the iron heads? SFT with 255 @ .050 with .620 lift gross 105 LSA installed on a 105 ICL and I'm locked out at 35* total.
[Re: DARTH V8Я]
#2075567
05/18/16 01:47 AM
05/18/16 01:47 AM
DARTH V8Я
Its a TRAP!
Mr P.. given her on the street 10.6 & 87 oct? Are those W2 chambers that good?
Thanks for the info mad!
[Re: DARTH V8Я]
#2075682
05/18/16 10:23 AM
05/18/16 10:23 AM
MR_P_BODY
Thanks for the info mad! They arent bad.. but I also have a .039 quench which is a help... I also touch up the chambers so there isnt any hot spots.. that was real quick with a tootsie roll
[Re: J_BODY]
#2075754
05/18/16 12:06 PM
05/18/16 12:06 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
OK.... maybe I'm "elevation handicapped", but I'd stick to the plan of the Indy top end. I'm thinking you'll find it easier to meet your ET goal. I'm hearing ya. I was sure w/iron heads that there would have to be a quench dome.
[img] [/img]
[Re: J_BODY]
#2075894
05/18/16 03:27 PM
05/18/16 03:27 PM
DARTH V8Я
Its a TRAP!
OK.... maybe I'm "elevation handicapped", but I'd stick to the plan of the Indy top end. I'm thinking you'll find it easier to meet your ET goal. No doubt. Just fascinated that P-car Iron heads can go that fast.
[Re: Porter67]
#2075953
05/18/16 04:39 PM
05/18/16 04:39 PM
clonestocker
Tucson, Arizona
This pic is from RJ and these are far from ideal imo as well your fast iron heads are not going to look near oem except from a visual standpoint.
Look back at the days of mastic, who needs a 3d printer to make things with that stuff.
Why they would do this with oem valve use in mind...hmmm... not ideal.
THose have got to be thin somewhere. They milled the chambers out. Scary !
[img] [/img]
[Re: Porter67]
#2076109
05/18/16 09:11 PM
05/18/16 09:11 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
You can get around that with a mopar crank, std. length rods and a off the shelf chevy piston, you can nail .035 above deck. Do tell... Std length Mopar rod? What Chevy piston?? Most importnat: What head gasket for an acceptable piston to head clearance???
[Re: MR_P_BODY]
#2076132
05/18/16 10:05 PM
05/18/16 10:05 PM
madscientist
Washington
You can get around that with a mopar crank, std. length rods and a off the shelf chevy piston, you can nail .035 above deck. Why would I want to be .035 above the deck? I'm running mine .054 out of the deck. Would have been more but I'm on pump gas.
[Re: madscientist]
#2076133
05/18/16 10:07 PM
05/18/16 10:07 PM
MR_P_BODY
You can get around that with a mopar crank, std. length rods and a off the shelf chevy piston, you can nail .035 above deck. Why would I want to be .035 above the deck? I'm running mine .054 out of the deck. Would have been more but I'm on pump gas. You sure didnt want any quench did ya EDIT I run a flat top piston with a 22cc dish with a .039 gasket to give me 10.6 compression(iron heads W-2s)
[Re: Porter67]
#2076139
05/18/16 10:18 PM
05/18/16 10:18 PM
MR_P_BODY
Building with stock based parts is a odd duck and very different from even eddie headed entry level stuff thats more or less setup for a quench type build.
If you figure just say a .040 head head gasket and your heads pad is .060 deep your fighting a .100 span so like posted above if hes .055 out hes at .045 quench....maybe?
Im my case with milled heads I only needed to be .035 above deck to use the oem pad to get a decent quench number.
Edit... these are not very pump gas friendly. Mine is running great on the street with 87 octane with a fair amount of beating on it..I will race on 93... and it dynoed at 590 hp 525 tq
[Re: Porter67]
#2076152
05/18/16 10:36 PM
05/18/16 10:36 PM
MR_P_BODY
Everyone has a different agenda, your out thrashing and having fun with your car, my fun involves my car and another brand running iron heads where alomst anything goes and its limited miles. But im trying to win.
For myself I never understood the pump gas concept, mainly because if your so deep into a car and cant blend a bit of fuel, maybe I should be running a mopar... but thats me, others have there reason.
Mr P if you were 3 point higher on compression, how much do you think you would gain?
No clue.. I played the race fuel game.. then changed to E-85.. this is a street rod for DW so no more race fuel for me
[Re: MR_P_BODY]
#2076154
05/18/16 10:37 PM
05/18/16 10:37 PM
madscientist
Washington
You can get around that with a mopar crank, std. length rods and a off the shelf chevy piston, you can nail .035 above deck. Why would I want to be .035 above the deck? I'm running mine .054 out of the deck. Would have been more but I'm on pump gas. You sure didnt want any quench did ya EDIT I run a flat top piston with a 22cc dish with a .039 gasket to give me 10.6 compression(iron heads W-2s) It should be noted that I'm running a 3.313 stroke. So the math works out a bit different.
[Re: DARTH V8Я]
#2076160
05/18/16 10:48 PM
05/18/16 10:48 PM
J_BODY
aZLiViN
OK.... maybe I'm "elevation handicapped", but I'd stick to the plan of the Indy top end. I'm thinking you'll find it easier to meet your ET goal. No doubt. Just fascinated that P-car Iron heads can go that fast. OK.... just found it interesting that it was into 2 pages and nobody brought that up. "IF" it were that easy, there would be lots of people doing it... he77 I was ecstatic with our iron head, flat tappet, KB piston 360 running 10.8's in Vegas with the way wrong gear and a converter that was dragging it down mercifully
[Re: Porter67]
#2076228
05/19/16 12:18 AM
05/19/16 12:18 AM
Thumperdart
State of confusion
Jason Pettis has seen 20+ hp per point..........
[Re: Thumperdart]
#2076295
05/19/16 01:55 AM
05/19/16 01:55 AM
DARTH V8Я
Its a TRAP!
Jason Pettis has seen 20+ hp per point.......... Really? Thats a lot. Personally seen a BBC that went from 10:1 to 13:1 with nothing else changed and it gain only 40hp. Now he has to run race gas. Maybe there's more gain going from 8:1 to 11:1 (same 3pt increase)?
[Re: DARTH V8Я]
#2076352
05/19/16 09:59 AM
05/19/16 09:59 AM
MR_P_BODY
Jason Pettis has seen 20+ hp per point.......... Really? Thats a lot. Personally seen a BBC that went from 10:1 to 13:1 with nothing else changed and it gain only 40hp. Now he has to run race gas. Maybe there's more gain going from 8:1 to 11:1 (same 3pt increase)? You normally see a bigger increase in power from lower compression vs the higher starting point when you jump up 3 points
[Re: DARTH V8Я]
#2077295
05/20/16 08:44 PM
05/20/16 08:44 PM
madscientist
Washington
Good to know. I'm gonna forgo on the Indy route and take a new direction: W2's. Operation coyote trap. Haha. My W2 stuff is out there under the bench, waiting for my fat self to do guides and valve job and then the port work. I'm getting old and slow.
[Re: DARTH V8Я]
#2077561
05/21/16 09:48 AM
05/21/16 09:48 AM
Bad340fish
Tulsa OK
Jason Pettis has seen 20+ hp per point.......... Really? Thats a lot. Personally seen a BBC that went from 10:1 to 13:1 with nothing else changed and it gain only 40hp. Now he has to run race gas. Maybe there's more gain going from 8:1 to 11:1 (same 3pt increase)? I have nothing personally to back this up but from what I have read it seems the gains diminish as the compression gets higher. Much more to be gained from going from 8:1 to 10:1 than there is from 12:1 to 14:1. The only downside to W2s in my opinion is that they are Iron. My Dad and I built a W2 headed 416 for drag week. We had to lower the compression some to know we would be safe on pump gas and its HEAVY. It took three full turns on the torsion bars to support the R1 W2 headed 416 over my aluminum headed 360.
[Re: Bad340fish]
#2077662
05/21/16 02:12 PM
05/21/16 02:12 PM
DARTH V8Я
Its a TRAP!
Try a 440 in a 73 Dart.
[Re: DARTH V8Я]
#2077689
05/21/16 03:02 PM
05/21/16 03:02 PM
Polarapete
Graham, WA
Well hopefully I'll get a PM about some W2's I have no idea if this is a good deal or not, but here is a CL listing in Western Washington for Aluminum W2 heads http://seattle.craigslist.org/tac/pts/5595446824.htmlThey are not mine, I don't need them, you can have them. Good luck. Corrected I first thought they were iron.
[Re: J_BODY]
#2077793
05/21/16 06:44 PM
05/21/16 06:44 PM
DARTH V8Я
Its a TRAP!
W2 heads??? hey now you're entering cast crank power territory! Sayin can't run 9's with an W2 Iron heads & cast crank?
[Re: DARTH V8Я]
#2077804
05/21/16 07:04 PM
05/21/16 07:04 PM
MR_P_BODY
W2 heads??? hey now you're entering cast crank power territory! Sayin can't run 9's with an W2 Iron heads & cast crank? They will run in the 9s.. the thing about W-2s you need to watch for.. they made them in 2 different installed heights..1.88 which is the standard lenght valve and then they made a 2.00 installed height which use a long valve.. I have a set of each.. on my Rampage I am running the long valve W-2s which I ported and they flow 310 at .650 with a 2.08 valve.. they could go a little more but core shift might be a issue.. mine have some core shift and I busted through 1 intake runner when I was clearancing the push rods.. I had to tube it... I run 9.56 with them.. thats with the same cam I have in the 416 right now(.640 lift)... they are a very good head but heavy.. alum heads will knock off 40# for the pair... this 416 dynoed at 590hp with a 950 carb EDIT Also when I ran that 9.56 it was with a 395ci
[Re: J_BODY]
#2077979
05/21/16 11:23 PM
05/21/16 11:23 PM
clonestocker
Tucson, Arizona
W2 heads??? hey now you're entering cast crank power territory! I've got an E58 standard bore block under the bench. If cam is small enough you can use Crane rockers also. Have some of those in the drawer. Then they start to get expensive.
[img] [/img]
[Re: MR_P_BODY]
#2078031
05/22/16 12:31 AM
05/22/16 12:31 AM
DARTH V8Я
Its a TRAP!
They will run in the 9s.. the thing about W-2s you need to watch for.. they made them in 2 different installed heights..1.88 which is the standard lenght valve and then they made a 2.00 installed height which use a long valve.. I have a set of each.. on my Rampage I am running the long valve W-2s which I ported and they flow 310 at .650 with a 2.08 valve.. they could go a little more but core shift might be a issue.. mine have some core shift and I busted through 1 intake runner when I was clearancing the push rods.. I had to tube it... I run 9.56 with them.. thats with the same cam I have in the 416 right now(.640 lift)... they are a very good head but heavy.. alum heads will knock off 40# for the pair... this 416 dynoed at 590hp with a 950 carb EDIT Also when I ran that 9.56 it was with a 395ci That's some solid info. Thank you very much Mr P Body.
[Re: Porter67]
#2078050
05/22/16 01:11 AM
05/22/16 01:11 AM
DARTH V8Я
Its a TRAP!
Mr. P... whats the length on the long valves your using? Probably 5.28" Stem Length.
[Re: Porter67]
#2078154
05/22/16 11:22 AM
05/22/16 11:22 AM
MR_P_BODY
Mr. P... whats the length on the long valves your using? 5.40".... 5.29" is the stock length for the standard length head(W-2 and W-5) EDIT Dont bother trying to use long valves in a short valve head... it doesnt work... the pedestals are in a different location.. unless you mill the stands off and relocate them and the different height
[Re: MR_P_BODY]
#2078250
05/22/16 01:54 PM
05/22/16 01:54 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do lots of research before buying W2 heads to avoid some issues and to make sure you get the set-up you want or need. I bought a set of Econo W2 heads and picked up some Crane and MP W2 rockers. I did some port work and with the stock 2.02 valves they were flowing slightly over 300 cfm. I ported the W2 intake and threw it in my Duster. After cam break-in I started it a few times in the shop and noticed a small puddle of water on the passenger side. Sure enough the heads cracked on the outside lower row of bolts by the W2 cast into the head. I ground the crack out and used Splash-zone epoxy to fix it and headed to the track. My Duster ran high 9 with that combo but about 3 months later the drivers-side head cracked in the same spot and even after a quick repair the crack continued to grow. After some reading I found out that some of these casting were known to have that issue so they are both leaning again my shop wall in the SCRAP zone. I'm just glad I didn't go to the work and expense of installing bigger valves.
[Re: pittsburghracer]
#2078271
05/22/16 02:28 PM
05/22/16 02:28 PM
MR_P_BODY
Other than what I said before I did forget to say.. that the W-2s can be bought in a race or econo version which is simple to spot.. the race ones dont have the pedestals for the rocker shafts.. the econo ones have the pedestals.. both sets of mine are the econo versions.. one set is the short valves the other is the long valve... I have never had the short valve ones on a engine yet.. I ported them and there they set.. I didnt get carried away with the port work on them so they didnt need any tubes added.. I think I have valves for them but I dont know... I might look to see what I can run for max lift on them just in case I want to put them on something... they should still flow right at 300 which is pretty simple on the W-2s
#2078336
05/22/16 04:46 PM
05/22/16 04:46 PM
madscientist
Washington
Do lots of research before buying W2 heads to avoid some issues and to make sure you get the set-up you want or need. I bought a set of Econo W2 heads and picked up some Crane and MP W2 rockers. I did some port work and with the stock 2.02 valves they were flowing slightly over 300 cfm. I ported the W2 intake and threw it in my Duster. After cam break-in I started it a few times in the shop and noticed a small puddle of water on the passenger side. Sure enough the heads cracked on the outside lower row of bolts by the W2 cast into the head. I ground the crack out and used Splash-zone epoxy to fix it and headed to the track. My Duster ran high 9 with that combo but about 3 months later the drivers-side head cracked in the same spot and even after a quick repair the crack continued to grow. After some reading I found out that some of these casting were known to have that issue so they are both leaning again my shop wall in the SCRAP zone. I'm just glad I didn't go to the work and expense of installing bigger valves. Do you want to sell those W2's. PM me if you do.
[Re: madscientist]
#2078517
05/22/16 11:26 PM
05/22/16 11:26 PM
DARTH V8Я
Its a TRAP!
Do lots of research before buying W2 heads to avoid some issues and to make sure you get the set-up you want or need. I bought a set of Econo W2 heads and picked up some Crane and MP W2 rockers. I did some port work and with the stock 2.02 valves they were flowing slightly over 300 cfm. I ported the W2 intake and threw it in my Duster. After cam break-in I started it a few times in the shop and noticed a small puddle of water on the passenger side. Sure enough the heads cracked on the outside lower row of bolts by the W2 cast into the head. I ground the crack out and used Splash-zone epoxy to fix it and headed to the track. My Duster ran high 9 with that combo but about 3 months later the drivers-side head cracked in the same spot and even after a quick repair the crack continued to grow. After some reading I found out that some of these casting were known to have that issue so they are both leaning again my shop wall in the SCRAP zone. I'm just glad I didn't go to the work and expense of installing bigger valves. Do you want to sell those W2's. PM me if you do. Same. Or any body else.. Mr P?
[Re: DARTH V8Я]
#2078537
05/22/16 11:52 PM
05/22/16 11:52 PM
DARTH V8Я
Its a TRAP!
Have you guys tried that electric motor paint? I tried some of it.. for a base coat on the timing cover, pretty slick. Water pump was rattle canned.
[Re: DARTH V8Я]
#2079161
05/24/16 01:47 AM
05/24/16 01:47 AM
DARTH V8Я
Its a TRAP!
LOL. Original timing chain, no broken teeth. Valved move freely.. yet somehow both the Intake and exhaust valves clipped the piston (#8). Also the exhaust valve clipped piston #2. Over rev much?
[Re: DARTH V8Я]
#2079176
05/24/16 02:39 AM
05/24/16 02:39 AM
DARTH V8Я
Its a TRAP!
Dunno. I'll have to check the cam in it. The head gaskets were done (composite, black in colour). Intake rails & face had a bejesus amount of silicon on em. Note; silicon blocking 1/2 the water ports aren't a good thing. That stock 2bbl intake weighs A LOT. Yikes lol.
[Re: DARTH V8Я]
#2080314
05/25/16 10:45 PM
05/25/16 10:45 PM
DARTH V8Я
Its a TRAP!
Scored 3 more 360 blocks. 1973,74, & 76. Picking them up this weekend. Life is grand..
[Re: DARTH V8Я]
#2080321
05/25/16 10:54 PM
05/25/16 10:54 PM
Posts: 20,182 Park Forest, IL
slantzilla
Park Forest, IL
Sweet! I traded 2 Slants for 3 360's a few weeks ago. They're everywhere!
[Re: DARTH V8Я]
#2080367
05/25/16 11:41 PM
05/25/16 11:41 PM
DARTH V8Я
Its a TRAP!
Nice! Anyways I was bored so I decided to open the 587 ports @ the pinch. Half hour of grinding later, gone(ish). Gave it the old hit it with a brass drift to see if it'll bust through, didn't. Then again that was just one port. What's it worth CFM wise outta curiosity?
[Re: slantzilla]
#2080392
05/25/16 11:59 PM
05/25/16 11:59 PM
madscientist
Washington
[quote=slantzilla]Sweet! I traded 2 Slants for 3 360's a few weeks ago. They're everywhere! [/
A slant is worth more than a 360. As it should be.
[Re: DARTH V8Я]
#2080561
05/26/16 11:05 AM
05/26/16 11:05 AM
MR_P_BODY
Scored 3 more 360 blocks. 1973,74, & 76. Picking them up this weekend. Life is grand.. I wish they started out with a bigger bore and would take more boring than they do.. thats why I still run 340 blocks.. but they are getting hard to find.. I only have 2 left that are stand by.. plus I have the one in the Rampage and 1 on the stand that was the back up for the race car
[Re: DARTH V8Я]
#2080753
05/26/16 04:03 PM
05/26/16 04:03 PM
HotRodDave
Kalispell Mt.
That 1990 block should have the extra reinforcement in the pan area like a magnum block, with sufficent meat left in the walls it should take a lot of crap
[Re: DARTH V8Я]
#2080821
05/26/16 06:22 PM
05/26/16 06:22 PM
DARTH V8Я
Its a TRAP!
@ dizuster; thats some crazy horsepower for a 2-bolt main cast crank engine. Try that with a SBC: BOOM. New low earth orbit Satellite. @ Mr P; your a 340 guy, I like the 360. (stock) 1550 gram bob weight @ HotRodDave; they say the same about early 400's.. the strength added is negligible.
[Re: DARTH V8Я]
#2080853
05/26/16 07:13 PM
05/26/16 07:13 PM
MR_P_BODY
@ dizuster; thats some crazy horsepower for a 2-bolt main cast crank engine. Try that with a SBC: BOOM. New low earth orbit Satellite. @ Mr P; your a 340 guy, I like the 360. (stock) 1550 gram bob weight @ HotRodDave; they say the same about early 400's.. the strength added is negligible. The simple reason that I like the 340s.. the bigger bore helps unshroud the valve and the small main journals and will turn more RPM
[Re: qwkmopardan]
#2080933
05/26/16 09:48 PM
05/26/16 09:48 PM
DARTH V8Я
Its a TRAP!
1.02" is maxed out without a tube. To get 1.02 you will have to spend another 1/2 hour+ on the common wall. Another 1/2 hour & 1.02"(+/-). I'm really digging porting these heads. More satisfying the porting BB's. What kind of CFM gain is there removing the pinch?
[Re: DARTH V8Я]
#2080944
05/26/16 10:08 PM
05/26/16 10:08 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Everyone wants to attach the pinch but the big dividends are on the shortside turn.
#2080952
05/26/16 10:32 PM
05/26/16 10:32 PM
DARTH V8Я
Its a TRAP!
Everyone wants to attach the pinch but the big dividends are on the shortside turn. Short side radius I'm not worried about. Blend + bowl work & pinch removal will shine.
[Re: DARTH V8Я]
#2081317
05/27/16 03:28 PM
05/27/16 03:28 PM
Posts: 883 Affton MO
qwkmopardan
Affton MO
You need to get rid of guide fat, lots of it. The intake pair without the long bolt will need a plug and an extra long bolt. Order an ARP W2 head bolt get and you get the 2 extra-long bolts. You will be cutting the pair of ports with the long bolt the same it just won't break through. The ones I port flow close to 280 cfm. Heads on Demon flowed 273. My engine in the Demon runs on 110 octane race fuel, 13 to 1 CR. I have ran 60% 110 and 40% 93 a few times when I couldn't get any 110 out of town racing. My 300 engine, 11.8 to 1 CR 442 c.i. small block, I mix 60% 93 and 40% 110. On Dragweek I cut it to about 80/20 for the drives and added enough 110 when I got to the track to get it back to 60/40. 442c.i. sm block--587 production heads--4150lbs--11.35 at 117 1/4 mile--7.22 at 97 1/8th mile--1.56 60 ft. There is more in it. I just got it back from body shop and will give it a tune up. Factory air cleaner a suspect problem
[Re: DARTH V8Я]
#2081435
05/27/16 06:57 PM
05/27/16 06:57 PM
DARTH V8Я
Its a TRAP!
Roger that on the heads. I'll do just the one intake port, flow it, if I get 260+ I'll continue on, otherwise I'll get the iron W2's.
Race gas however that's a big negative. Gotta be 100% pump. Cid will be in the 408 range. I don't have the big bore block.
Love that 300 setup. People walk by it without a second thought about the engine. Exactly what I want.
[Re: DARTH V8Я]
#2081447
05/27/16 07:19 PM
05/27/16 07:19 PM
MR_P_BODY
On the W-2s.. you can get over 300.. on mine the one set is 302.. the set on my 416 flow 310.. I did have to tube one intake port where I cut through but they are on the car now... I have heard of some W-2s going as high as 320.. but I dont know that for fact but mine were flowed on 2 benches.. the one at Chrysler and another local to me.. they were within 3 cfm .. but if I were to port another set I wouldnt go that far.. the issue is core shift
[Re: DARTH V8Я]
#2081483
05/27/16 08:28 PM
05/27/16 08:28 PM
madscientist
Washington
Love that 300 setup. People walk by it without a second thought about the engine. Exactly what I want. You could get 260 out of the Pcar head, and 260 out of the W2 and the W2 will KILL that Pcar head every single time. There is more to heads than flow. Volume is just as important, and I don't care what you do, you won't get W2 volume from a Pcar head. If you have W2's or can get them, don't waste one more second on that Pcar crap.
[Re: DARTH V8Я]
#2081563
05/27/16 10:54 PM
05/27/16 10:54 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
Quick Dan, what size valve did you use to get 280cfm out of the pass car heads?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#2081689
05/28/16 04:47 AM
05/28/16 04:47 AM
qwkmopardan
Affton MO
Quick Dan, what size valve did you use to get 280cfm out of the pass car heads? 2.055"
[Re: slantzilla]
#2081869
05/28/16 03:58 PM
05/28/16 03:58 PM
DARTH V8Я
Its a TRAP!
Are those heads the same as J heads? There all 'smogger' heads. What I noticed so far if that there is plenty of meat to get rid of the pushrod pinch completely. Always thought that was a T/A only deal. 587 production heads 4" bore @ 28" stock port w/ 1.88" valve Lift--------Intake cfm 0.150------91 0.200-----124 0.250-----157 0.300-----182 0.350-----199 0.400-----206 0.450-----212 0.500-----214 0.550-----211 0.600-----206 So right there you can get 400hp from bone stock heads This is from Chrysler Power magazine: 2.02 intake, hog out ports (pinch removed) blended guides, bowl Lift--------Intake cfm 0.150-----110 0.200-----149 0.250-----183 0.300-----210 0.350-----232 0.400-----250 0.450-----267 0.500-----281 0.550-----277 0.600-----270 potential 550-600hp heads W2 stock port .050------30 .100-----61 .200-----120 .300-----166 .400-----210 .500-----236 .600-----244 .700-----234 Stock 587 heads beat the stock W2 up to .350ish lift, after that game over. Ported 587 heads smokes the stock W2. But it's alot of work.. that could be applied to the W2 lol.
[Re: DARTH V8Я]
#2081918
05/28/16 05:42 PM
05/28/16 05:42 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
What a head flows and what you get out of them for power are to totally different things!
Brian Hafliger
[Re: Brian Hafliger]
#2081942
05/28/16 06:47 PM
05/28/16 06:47 PM
DARTH V8Я
Its a TRAP!
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks.
[Re: DARTH V8Я]
#2081950
05/28/16 07:19 PM
05/28/16 07:19 PM
MR_P_BODY
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy
[Re: MR_P_BODY]
#2081952
05/28/16 07:24 PM
05/28/16 07:24 PM
DARTH V8Я
Its a TRAP!
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy Dunno. Whats it look like? That round thing under the retainer?
[Re: DARTH V8Я]
#2081962
05/28/16 07:55 PM
05/28/16 07:55 PM
MR_P_BODY
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy Dunno. Whats it look like? But spring, keepers, retainer, valve weighed 239 grams. They are a bearing that allowed the valve to turn easier.. usually on heavy duty truck engines I dont have a pic of them.. but they were about a 1/4" to 5/16" thick... took the place of the retainer.. you would know if they were on there.. someone could have puled them off.. I always trashed them
[Re: DARTH V8Я]
#2081968
05/28/16 08:22 PM
05/28/16 08:22 PM
dartman366
Mt. Vernon, Ohio
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy Dunno. Whats it look like? That round thing under the retainer? the valve on the left side of the pic has the rotator usually on the exhaust valve from my experience.
[Re: MR_P_BODY]
#2082020
05/28/16 09:45 PM
05/28/16 09:45 PM
qwkmopardan
Affton MO
What a head flows and what you get out of them for power are to totally different things! Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes. So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks. Did they have the rotators on them.. that makes them heavy The spring on the left has a rotater. They were on exh valves on truck engines. If you were building a mild engine and wanted 340 springs you could not do it. The valves are made for a shorter spring. For what you are doing you will end up with .100 long sb chevy valves or maybe magnum valves. Don't try LS valves, I just did a set with LS valves, and what a PITA
[Re: DARTH V8Я]
#2082061
05/28/16 11:06 PM
05/28/16 11:06 PM
DARTH V8Я
Its a TRAP!
Yep. Parts. All in the guys apartment lol. 1974 360 .030 over 1973 360 Std bore 1976 360 Std bore Game plan is the same. Cept going with W2's.
