Page 3 of 6 1 2 3 4 5 6
Re: FINALLY got me a 360.. [Re: Porter67] #2075953
05/18/16 04:39 PM
05/18/16 04:39 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Originally Posted By Porter67
This pic is from RJ and these are far from ideal imo as well your fast iron heads are not going to look near oem except from a visual standpoint.
Look back at the days of mastic, who needs a 3d printer to make things with that stuff.
Why they would do this with oem valve use in mind...hmmm... not ideal.
THose have got to be thin somewhere. They milled the chambers out. Scary !
[img] [/img]
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2076068
05/18/16 07:48 PM
05/18/16 07:48 PM
P
Porter67 Offline
Porter67  Offline
P
You can get around that with a mopar crank, std. length rods and a off the shelf chevy piston, you can nail .035 above deck.
Re: FINALLY got me a 360..Coyote Trap [Re: DARTH V8Я] #2076086
05/18/16 08:30 PM
05/18/16 08:30 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
Haha just PM'd you about the rods. thumbs
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: FINALLY got me a 360.. [Re: Porter67] #2076109
05/18/16 09:11 PM
05/18/16 09:11 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Do tell...
Std length Mopar rod?
What Chevy piston??
Most importnat: What head gasket for an acceptable piston to head clearance???
Re: FINALLY got me a 360.. [Re: Porter67] #2076112
05/18/16 09:17 PM
05/18/16 09:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why would I want to be .035 above the deck?
wave
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2076132
05/18/16 10:05 PM
05/18/16 10:05 PM
Washington
madscientist Offline
Washington
wave
I'm running mine .054 out of the deck. Would have been more but I'm on pump gas.
Re: FINALLY got me a 360.. [Re: madscientist] #2076133
05/18/16 10:07 PM
05/18/16 10:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
You sure didnt want any quench did ya
EDIT
I run a flat top piston with a 22cc dish with a .039
gasket to give me 10.6 compression(iron heads W-2s)
wave
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2076137
05/18/16 10:12 PM
05/18/16 10:12 PM
P
Porter67 Offline
Porter67  Offline
P
Building with stock based parts is a odd duck and very different from even eddie headed entry level stuff thats more or less setup for a quench type build.
If you figure just say a .040 head head gasket and your heads pad is .060 deep your fighting a .100 span so like posted above if hes .055 out hes at .045 quench....maybe?
Im my case with milled heads I only needed to be .035 above deck to use the oem pad to get a decent quench number.
Edit... these are not very pump gas friendly.
Re: FINALLY got me a 360.. [Re: Porter67] #2076139
05/18/16 10:18 PM
05/18/16 10:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine is running great on the street with 87 octane with
a fair amount of beating on it..I will race on 93...
and it dynoed at 590 hp 525 tq
wave
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2076144
05/18/16 10:26 PM
05/18/16 10:26 PM
P
Porter67 Offline
Porter67  Offline
P
Everyone has a different agenda, your out thrashing and having fun with your car, my fun involves my car and another brand running iron heads where alomst anything goes and its limited miles. But im trying to win.
For myself I never understood the pump gas concept, mainly because if your so deep into a car and cant blend a bit of fuel, maybe I should be running a mopar... but thats me, others have there reason.
Mr P if you were 3 point higher on compression, how much do you think you would gain?
Re: FINALLY got me a 360.. [Re: Porter67] #2076152
05/18/16 10:36 PM
05/18/16 10:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No clue.. I played the race fuel game.. then changed to
E-85.. this is a street rod for DW so no more race fuel
for me
wave
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2076154
05/18/16 10:37 PM
05/18/16 10:37 PM
Washington
Washington
wave
EDIT
wave
It should be noted that I'm running a 3.313 stroke. So the math works out a bit different.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2076160
05/18/16 10:48 PM
05/18/16 10:48 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted By DARTH V8R
Originally Posted By J_BODY
OK.... maybe I'm "elevation handicapped", but I'd stick to the plan of the Indy top end. I'm thinking you'll find it easier to meet your ET goal.
No doubt. Just fascinated that P-car Iron heads can go that fast.
OK.... just found it interesting that it was into 2 pages and nobody brought that up. "IF" it were that easy, there would be lots of people doing it... he77 I was ecstatic with our iron head, flat tappet, KB piston 360 running 10.8's in Vegas with the way wrong gear and a converter that was dragging it down mercifully laugh2
Re: FINALLY got me a 360.. [Re: Porter67] #2076228
05/19/16 12:18 AM
05/19/16 12:18 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Jason Pettis has seen 20+ hp per point..........
Re: FINALLY got me a 360.. [Re: Thumperdart] #2076295
05/19/16 01:55 AM
05/19/16 01:55 AM
Its a TRAP!
Its a TRAP!
Really? Thats a lot. Personally seen a BBC that went from 10:1 to 13:1 with nothing else changed and it gain only 40hp. Now he has to run race gas. Maybe there's more gain going from 8:1 to 11:1 (same 3pt increase)?
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2076305
05/19/16 02:25 AM
05/19/16 02:25 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not sure on that..............I`ll ask him.......... thumbs
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2076352
05/19/16 09:59 AM
05/19/16 09:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You normally see a bigger increase in power from lower compression
vs the higher starting point when you jump up 3 points
wave
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2077245
05/20/16 07:14 PM
05/20/16 07:14 PM
Its a TRAP!
Its a TRAP!
Good to know. I'm gonna forgo on the Indy route and take a new direction: W2's. Operation coyote trap. Haha.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2077295
05/20/16 08:44 PM
05/20/16 08:44 PM
Washington
Washington
My W2 stuff is out there under the bench, waiting for my fat self to do guides and valve job and then the port work.
I'm getting old and slow.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2077503
05/21/16 01:51 AM
05/21/16 01:51 AM
Its a TRAP!
Its a TRAP!
Well hopefully I'll get a PM about some W2's smile
