Page 6 of 6 1 2 3 4 5 6
Re: FINALLY got me a 360.. [Re: poboyengineering] #2081689
05/28/16 04:47 AM
05/28/16 04:47 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Originally Posted By poboyengineering
Quick Dan, what size valve did you use to get 280cfm out of the pass car heads?
2.055"
Re: FINALLY got me a 360.. [Re: slantzilla] #2081869
05/28/16 03:58 PM
05/28/16 03:58 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
Originally Posted By slantzilla
Are those heads the same as J heads?
There all 'smogger' heads. What I noticed so far if that there is plenty
of meat to get rid of the pushrod pinch completely. Always thought that was a T/A only deal.
587 production heads
4" bore @ 28" stock port w/ 1.88" valve
Lift--------Intake cfm
0.150------91
0.200-----124
0.250-----157
0.300-----182
0.350-----199
0.400-----206
0.450-----212
0.500-----214
0.550-----211
0.600-----206
So right there you can get 400hp from bone stock heads
This is from Chrysler Power magazine:
2.02 intake, hog out ports (pinch removed) blended guides, bowl
0.150-----110
0.200-----149
0.250-----183
0.300-----210
0.350-----232
0.400-----250
0.450-----267
0.500-----281
0.550-----277
0.600-----270
potential 550-600hp heads
W2 stock port
.050------30
.100-----61
.200-----120
.300-----166
.400-----210
.500-----236
.600-----244
.700-----234
Stock 587 heads beat the stock W2 up to .350ish lift, after that game over.
Ported 587 heads smokes the stock W2. But it's alot of work.. that
could be applied to the W2 lol.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081918
05/28/16 05:42 PM
05/28/16 05:42 PM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
What a head flows and what you get out of them for power are to totally different things!
Brian Hafliger
Re: FINALLY got me a 360.. [Re: Brian Hafliger] #2081942
05/28/16 06:47 PM
05/28/16 06:47 PM
Its a TRAP!
Its a TRAP!
Roger that. Best flow with the smallest cross section. Unless it's supercharged, then turn em into sewer pipes.
So looking at these heads, it seems that the exhaust springs only have a damper spring in them, none on the intake. Is that normal? Thanks.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081950
05/28/16 07:19 PM
05/28/16 07:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did they have the rotators on them.. that makes
them heavy
wave
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2081952
05/28/16 07:24 PM
05/28/16 07:24 PM
Its a TRAP!
Its a TRAP!
them heavy
wave
Dunno. Whats it look like? That round thing under the retainer?
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081962
05/28/16 07:55 PM
05/28/16 07:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
them heavy
wave
Dunno. Whats it look like? But spring, keepers, retainer, valve weighed 239 grams.
They are a bearing that allowed the valve to
turn easier.. usually on heavy duty truck engines
I dont have a pic of them.. but they were about a
1/4" to 5/16" thick... took the place of the retainer..
you would know if they were on there.. someone could
have puled them off.. I always trashed them
wave
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081968
05/28/16 08:22 PM
05/28/16 08:22 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
them heavy
wave
the valve on the left side of the pic has the rotator usually on the exhaust valve from my experience.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081985
05/28/16 08:51 PM
05/28/16 08:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If I remember the numbers right, back in the late 90s Ritter-Webers Daytona went some 7.70s with the 360-W2s and a single four in comp. I was impressed with how fast and loud that small block car was! I bought a set of 15-33 Goodyears with two passes from them for $100 that day, nice guys
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2082020
05/28/16 09:45 PM
05/28/16 09:45 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
them heavy
wave
The spring on the left has a rotater. They were on exh valves on truck engines. If you were building a mild engine and wanted 340 springs you could not do it. The valves are made for a shorter spring. For what you are doing you will end up with .100 long sb chevy valves or maybe magnum valves. Don't try LS valves, I just did a set with LS valves, and what a PITA
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2082035
05/28/16 10:14 PM
05/28/16 10:14 PM
P
Porter67 Offline
Porter67  Offline
P
If you have not yet, before you go buying this and that, get a plan on paper and stick to it.
You could end up thousands ahead in the end, or be like alot of us and just be sitting on alot of parts you might get 1/2 of what you paid.
Even thin pushrod walls will crack with alot of heat cycles, and with little trouble the K&S metals #8139 1/2x.014 tubes fit the pushrod tubes.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2082061
05/28/16 11:06 PM
05/28/16 11:06 PM
Its a TRAP!
Its a TRAP!
Yep. Parts. All in the guys apartment lol.
1974 360 .030 over
1973 360 Std bore
1976 360 Std bore
Game plan is the same. Cept going with W2's.
