Page 5 of 6 1 2 3 4 5 6
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080314
05/25/16 10:45 PM
05/25/16 10:45 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
Scored 3 more 360 blocks. 1973,74, & 76. Picking them up this weekend.
Life is grand..
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080321
05/25/16 10:54 PM
05/25/16 10:54 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Sweet! I traded 2 Slants for 3 360's a few weeks ago. They're everywhere!
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080367
05/25/16 11:41 PM
05/25/16 11:41 PM
Its a TRAP!
Its a TRAP!
Nice!
Anyways I was bored so I decided to open the 587 ports @ the pinch. Half hour of grinding later, gone(ish).
Gave it the old hit it with a brass drift to see if it'll bust through, didn't. Then again that was just
one port. What's it worth CFM wise outta curiosity?
Re: FINALLY got me a 360.. [Re: slantzilla] #2080392
05/25/16 11:59 PM
05/25/16 11:59 PM
Washington
madscientist Offline
Washington
[quote=slantzilla]Sweet! I traded 2 Slants for 3 360's a few weeks ago. They're everywhere! [/
A slant is worth more than a 360. As it should be.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080515
05/26/16 08:40 AM
05/26/16 08:40 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I know I'm only one unique example but my 1990 block and stock 360 cast crank have amazed me with what abuse it's taken.
1/2 fill, girdle, low timing , 6500 rpm max... but I'm sure it makes in the 800hp range with the boost turned up around 18-19psi.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080561
05/26/16 11:05 AM
05/26/16 11:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Life is grand..
I wish they started out with a bigger bore and
would take more boring than they do.. thats why I
still run 340 blocks.. but they are getting hard to
find.. I only have 2 left that are stand by.. plus
I have the one in the Rampage and 1 on the stand that
was the back up for the race car
wave
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080753
05/26/16 04:03 PM
05/26/16 04:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
That 1990 block should have the extra reinforcement in the pan area like a magnum block, with sufficent meat left in the walls it should take a lot of crap
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080821
05/26/16 06:22 PM
05/26/16 06:22 PM
Its a TRAP!
Its a TRAP!
@ dizuster; thats some crazy horsepower for a 2-bolt main cast crank engine. Try that with a SBC: BOOM. New low earth orbit Satellite.
@ Mr P; your a 340 guy, I like the 360. (stock) 1550 gram bob weight smile
@ HotRodDave; they say the same about early 400's.. the strength added is negligible.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080853
05/26/16 07:13 PM
05/26/16 07:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The simple reason that I like the 340s.. the
bigger bore helps unshroud the valve and the
small main journals and will turn more RPM
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080893
05/26/16 08:24 PM
05/26/16 08:24 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
1.02" is maxed out without a tube. To get 1.02 you will have to spend another 1/2 hour+ on the common wall.
Re: FINALLY got me a 360.. [Re: qwkmopardan] #2080933
05/26/16 09:48 PM
05/26/16 09:48 PM
Its a TRAP!
Its a TRAP!
Another 1/2 hour & 1.02"(+/-).
I'm really digging porting these heads. More satisfying the porting BB's. What kind of CFM gain is there removing the pinch?
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2080944
05/26/16 10:08 PM
05/26/16 10:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Everyone wants to attach the pinch but the big dividends are on the shortside turn.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: FINALLY got me a 360.. [Re: pittsburghracer] #2080952
05/26/16 10:32 PM
05/26/16 10:32 PM
Its a TRAP!
Its a TRAP!
Short side radius I'm not worried about. Blend + bowl work & pinch removal will shine.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081317
05/27/16 03:28 PM
05/27/16 03:28 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
You need to get rid of guide fat, lots of it. The intake pair without the long bolt will need a plug and an extra long bolt. Order an ARP W2 head bolt get and you get the 2 extra-long bolts. You will be cutting the pair of ports with the long bolt the same it just won't break through.
The ones I port flow close to 280 cfm. Heads on Demon flowed 273. My engine in the Demon runs on 110 octane race fuel, 13 to 1 CR. I have ran 60% 110 and 40% 93 a few times when I couldn't get any 110 out of town racing. My 300 engine, 11.8 to 1 CR 442 c.i. small block, I mix 60% 93 and 40% 110. On Dragweek I cut it to about 80/20 for the drives and added enough 110 when I got to the track to get it back to 60/40.
442c.i. sm block--587 production heads--4150lbs--11.35 at 117 1/4 mile--7.22 at 97 1/8th mile--1.56 60 ft.
There is more in it. I just got it back from body shop and will give it a tune up. Factory air cleaner a suspect problem
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081435
05/27/16 06:57 PM
05/27/16 06:57 PM
Its a TRAP!
Its a TRAP!
Roger that on the heads. I'll do just the one intake port, flow it, if I get 260+ I'll continue on, otherwise I'll get the iron W2's.
Race gas however that's a big negative. Gotta be 100% pump. Cid will be in the 408 range. I don't have the big bore block.
Love that 300 setup. People walk by it without a second thought about the engine. Exactly what I want.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081447
05/27/16 07:19 PM
05/27/16 07:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On the W-2s.. you can get over 300.. on mine
the one set is 302.. the set on my 416 flow 310..
I did have to tube one intake port where I cut through
but they are on the car now... I have heard of some
W-2s going as high as 320.. but I dont know that for fact
but mine were flowed on 2 benches.. the one at Chrysler
and another local to me.. they were within 3 cfm .. but
if I were to port another set I wouldnt go that far.. the
issue is core shift
wave
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081471
05/27/16 08:01 PM
05/27/16 08:01 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
4.07 bore production 1974 block. 4.25 BPE crankshaft. Very little work to block to get it to swing full circle. A notch in the bottom of each cylinder and a little work on the pick-up tube. Pistons were supposed to be 4.06" but Wiseco made both sets I ordered at the same time 4.07", one set was for a .03 O.S. 340 block. Block was super thick so I went ahead and used the 4.07 pistons. Would of never went .06 except formula for 440 S.B. is 4.25 x 4.06
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081483
05/27/16 08:28 PM
05/27/16 08:28 PM
Washington
Washington
You could get 260 out of the Pcar head, and 260 out of the W2 and the W2 will KILL that Pcar head every single time.
There is more to heads than flow. Volume is just as important, and I don't care what you do, you won't get W2 volume from a Pcar head. If you have W2's or can get them, don't waste one more second on that Pcar crap.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081563
05/27/16 10:54 PM
05/27/16 10:54 PM
pennsylvania
poboyengineering Offline
pennsylvania
Quick Dan, what size valve did you use to get 280cfm out of the pass car heads?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2081584
05/27/16 11:41 PM
05/27/16 11:41 PM
Park Forest, IL
Park Forest, IL
Are those heads the same as J heads?
