Page 1 of 6 1 2 3 4 5 6
FINALLY got me a 360.. #2074113
05/15/16 09:20 PM
05/15/16 09:20 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
.. I had to pull it, $50. Lol. Now lets see how much horsepower that stock block can handle. smile
Ok seriously though, after working 20 years with big blocks, this will be my first serious N/A small block build.
please excuse the noob questions..
This is a run of the mill 74 360, no windage tray, etc. Is there enough meat on the block for a 4-bolt main conversion (if even available)? Or would it make that area weaker on a stock block?
Is a stock mains and stud kit plenty for say 6500-6700 rpm (will be a 4" stroke crank)?
I'm sure I'll have more questions later on, thanks.
And got this for 10 bucks, cause nothing short of a dominator will do wink but that's way down the road.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074121
05/15/16 09:29 PM
05/15/16 09:29 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I wouldn't do a four bolt main, weakens block. I ran stock 340 blocks harder then that with arp studs. I would also do a short fill to give it a little more stability.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074128
05/15/16 09:36 PM
05/15/16 09:36 PM
Washington
madscientist Offline
Washington
There are guys who put 4 bolt caps on Pcar blocks but it is a waste of time and WILL make the block weaker.
BTW with that stroke and those mains, I would have no less that .0036-.0038 main clearance. The block will flex and eat up the clearance.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074190
05/15/16 10:39 PM
05/15/16 10:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not sure how fast you are lookin to go but I beat the snot out of a stock stroke iron headed truck 360 w/a clean up and GOOD valve job from Pettis, a solid Isky flat tappet cam and it went 11.80`s at L.A.C.R`s altitude track and was my daily driver............not stellar but fun..........
Re: FINALLY got me a 360.. [Re: madscientist] #2074222
05/15/16 11:23 PM
05/15/16 11:23 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Not only the mains, mine was flexing enough the cam bearings had grooves in them.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074228
05/15/16 11:32 PM
05/15/16 11:32 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
sheesh! we went from R blocks and Ritter blocks to this??? at least we know you are sane now!! laugh2 We had a nice 340 block build that went a best of 9.8's. Only had a roll bar so my dad was shifting at like 5800 with a 4.3 gear. Bumped it up to 6800 it really got with it... I'm betting more gear and some tuning we would have been able to get some 9.6's out of it.... unfortunately it met a leaky W5 untimely death. If those heads would have been worth a krap I'm betting we'd still be wheeling that mill.
4" stroke, 2 bolt main, 13.5 to 1 compression, Indy intake with 4500 adapter.
life was so much simpler then.....
Re: FINALLY got me a 360.. [Re: J_BODY] #2074284
05/16/16 01:05 AM
05/16/16 01:05 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Looks it a fun build. Im in the process of building one myself for my sister... Eagle rods K1 crank SRP Pistons 4in stroke. Solid flat tappet and Edelbrock heads. I ran a 408 built on a 1999 block with 360-1 . It was a 2 bolt Main...man put a ton of passes on thing.good luck
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074329
05/16/16 02:51 AM
05/16/16 02:51 AM
Its a TRAP!
Its a TRAP!
@ Thumperdart - looking for high 9's @ 3100#. Going tomorrow to buy a used 1050 Dominator, will be sending it to you when I'm ready wink
@ 1967dartgt & madscientest - roger that, no 4-bolt mains. ARP mains studs on stock or aftermarket caps?
@ J-Body R's are out there, but suddenly the prices went Sky High, guess cause now when they are no longer being produced. Talked with a few people about the Ritter block,
machine costs alone would be quadruple to a very well machined/prepped stock block. So had to go with plan 'c'.. the 50 dollar engine lol.
Indy 360-1's are still the plan.
Now the short fill question. Necessary for a street driven engine that'll only see the track twice a year @ the ET i'm gunning for?
I'm not fond of filled blocks, however if it makes it more stable, I guess I'll have to be open to the idea.
@ whitedart good to know the 2-bolt mains held up, thanks.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074330
05/16/16 02:58 AM
05/16/16 02:58 AM
Washington
Washington
Studs and a short fill. Good to go.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074348
05/16/16 04:19 AM
05/16/16 04:19 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Looks like it has 587 heads. You have block and heads to run high 9s at 3100lbs. Even if they are 596 head castings they are fine. Sonic test block. Reject it and find another if major thrust will be less than .187 and .160 minor after boring. No fill needed, just makes the block a heavy pig. Restrictor tubes and oil pathway mods a good idea. A QMD port job and good guide and valve job and of course good valves and hardware. Program 2 bolt caps on middle 3. A steel 4" or 4.125" crank, a set of 6.25 rods and flat top pistons about .08 above deck, like a factory 340, just taller. A racer Brown STX22 solid flat tappet cam. Victor intake. Basically a copy of engine in my Demon. Passed 2100 runs this weekend at Beacon Dragway. Pistons never removed from the block and no valve job since original assembly . Went 6.22 at 108.50 Saturday night, and made a near perfect run first round today with no time run. .0000 on the tree and 6.2410 on 6.24 dial. Best engine I ever had! And in the 1980s everybody told me 360s were junk, don't waste your time and money on them. Runs best with 28* timing, crank trigger.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074477
05/16/16 12:56 PM
05/16/16 12:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Oh, more smallblocks whoopin on big blocks...........I get it.......... biggrin I`ve got blocks, boosters and bowls lookin for a good home............ thumbs
Re: FINALLY got me a 360.. [Re: qwkmopardan] #2074594
05/16/16 04:38 PM
05/16/16 04:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Can you tell me the specs on the STX22.. I
couldnt find them on line.... I'm looking to
change cams... thanks
wave
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2074595
05/16/16 04:45 PM
05/16/16 04:45 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
wave
its on this list.
http://www.4secondsflat.com/RB%20Cam%20Specs.htm
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074600
05/16/16 04:54 PM
05/16/16 04:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
STX-21M 306 272@.050 .560 .597
Re: FINALLY got me a 360.. [Re: krautrock] #2074609
05/16/16 05:11 PM
05/16/16 05:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks..... what LSA are the STX22 ground on.. and I assume
its a solid FT cam
wave
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2074636
05/16/16 05:56 PM
05/16/16 05:56 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
its a solid FT cam
wave
SSH -Super Street Hydraulic
STH Super Tork Hydraulic
SS Super Street Mechanical
ST- Super Tork Mechanical
STX and STR Roller cam grinds
EH Mild Hydraulic and economy grinds
http://www.4secondsflat.com/Racer_Brown_Cam_Specs.html
Re: FINALLY got me a 360.. [Re: krautrock] #2074660
05/16/16 06:47 PM
05/16/16 06:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks... I'll look for something else
wave
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2074677
05/16/16 07:13 PM
05/16/16 07:13 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
wave
STX-22 310 276 .590
It's on this page:
Re: FINALLY got me a 360.. [Re: MR_P_BODY] #2074859
05/17/16 12:08 AM
05/17/16 12:08 AM
Washington
Washington
its a solid FT cam
wave
Jim will pretty much grind his lobes on the LSA you want. He also has lobes not on that web site. You just have to call him.
I'm using a lobe not on Dons site.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074876
05/17/16 12:48 AM
05/17/16 12:48 AM
Its a TRAP!
Its a TRAP!
@ qwkmopardan ~ thanks for the info. Didn't think those "smogger" heads had enough flow for a 9 second pass. Nice combo BTW.
@ thumperdart you bet buddy :thumb: & duly noted wink expect a package later on smile
Solid rollers question: I know they are spendy, but PITA to install & clearance or pretty straight forward? Thanks.
