Re: E-body front suspension question
[Re: 340swing]
#1530971
11/11/13 04:52 PM
11/11/13 04:52 PM
RapidRobert
There was something way back about some years of B/E kmembers or boxes that had a different tilt than OE. I dont remember the particulars but that sure seems like a severe rake on the adj sleeve angle tho I know pics can be misleading. Stay on it & holler how it goes. EDIT k.i.s.s. It would appear (just from the pic) that the pitman does not drop down far enough
[Re: 340swing]
#1530974
11/11/13 06:29 PM
11/11/13 06:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Brian,
The pic of the idler arm side, looks good...the drivers side not so good!...I'm gonna say pitman arm, regardless of the fact you put the old arm back on, it may be off another vehicle/body line, and a lot of the aftermarket kits have issues with either the wrong idler or pitman, or both....so I measured the drop of the pitman arm in my 71 Cuda, it's 3 1/2" from the top flat of the spline end to the bottom flat of the arm (rod end) casting, I used a straight edge on the flats to measure so there would be no "eyeballin"....see what drop dem. you have?
Mike
[Re: DAYCLONA]
#1530975
11/11/13 06:54 PM
11/11/13 06:54 PM
Posts: 313 Ct, Oxford
340swing
Ct, Oxford
new one is 3 1/4 the original or old one is 3 1/8 using your method ill post a pic in a few miniutes
[Re: 340swing]
#1530977
11/12/13 08:44 AM
11/12/13 08:44 AM
Posts: 8,848 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Was told long ago there was three strearing box,s c body a.b.e body and truck I know b/e body box are the same so...
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: dan9]
#1530980
11/12/13 12:24 PM
11/12/13 12:24 PM
Posts: 4,051 Connecticut
jeff968
Connecticut
Brian, Is there a part number on the center link?
1970 Dodge Challenger T/A
