I bought both pitman and idler from Rich Erenberg. The grease fitting hits the torsion bar. The one I took off seemed original and you could see where it had been rubbing the torsion bar also. I will grease then replace grease fitting with a plug. As i recall some cars from long ago came with plugs instead of grease fitting. We always had a box of various fitting to do an initial grease job.
