Dayclona if those numbers are right then the box is wrong. A body by your numbers. So John (biginchmotor) if you have so extra manual boxes for an E-body I will be calling you. See if any have the number Dayclona put in his reply. Also I have not tried shimming it it's way off like a half inch. Thanks for all the help.
