Page 2 of 4 1 2 3 4
Re: E-body front suspension question [Re: 340swing] #1530970
11/11/13 04:35 PM
11/11/13 04:35 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
6th
Re: E-body front suspension question [Re: 340swing] #1530971
11/11/13 04:52 PM
11/11/13 04:52 PM
There was something way back about some years of B/E kmembers or boxes that had a different tilt than OE. I dont remember the particulars but that sure seems like a severe rake on the adj sleeve angle tho I know pics can be misleading. Stay on it & holler how it goes. EDIT k.i.s.s. It would appear (just from the pic) that the pitman does not drop down far enough
Re: E-body front suspension question [Re: RapidRobert] #1530972
11/11/13 05:58 PM
11/11/13 05:58 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
This may get a little lengthy, Here is my thought process. The steering box is bolted to the K frame no adjustment, the lower control arm goes through the K frame no adjustment up or down. The torsion bar goes into the lower control arm. In other words it's all fixed. So looking at it its either the steering box is wrong or the pitman angle or drop is wrong. Or the center link could be wrong. First question is any way to tell if the center link is correct for the car? 2nd are there different manual steering boxes ie longer shaft.
Re: E-body front suspension question [Re: 340swing] #1530973
11/11/13 06:23 PM
11/11/13 06:23 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Keep in mind anything could be wrong. This is how I got the car. Although it's numbers matching and pretty complete anything could have been replaced/misplaced substituted ect.
Re: E-body front suspension question [Re: 340swing] #1530974
11/11/13 06:29 PM
11/11/13 06:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Brian,
The pic of the idler arm side, looks good...the drivers side not so good!...I'm gonna say pitman arm, regardless of the fact you put the old arm back on, it may be off another vehicle/body line, and a lot of the aftermarket kits have issues with either the wrong idler or pitman, or both....so I measured the drop of the pitman arm in my 71 Cuda, it's 3 1/2" from the top flat of the spline end to the bottom flat of the arm (rod end) casting, I used a straight edge on the flats to measure so there would be no "eyeballin"....see what drop dem. you have?
Mike
Re: E-body front suspension question [Re: DAYCLONA] #1530975
11/11/13 06:54 PM
11/11/13 06:54 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
new one is 3 1/4 the original or old one is 3 1/8 using your method ill post a pic in a few miniutes
Re: E-body front suspension question [Re: 340swing] #1530976
11/11/13 09:57 PM
11/11/13 09:57 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Any Ideas on the steering box and center link? Any way to tell if they are correct. Are there more than one manual steering box that looks like mine.
Re: E-body front suspension question [Re: 340swing] #1530977
11/12/13 08:44 AM
11/12/13 08:44 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Was told long ago there was three strearing box,s
c body a.b.e body and truck
I know b/e body box are the same so...
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: E-body front suspension question [Re: 340swing] #1530978
11/12/13 09:56 AM
11/12/13 09:56 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
You could do this, but something is wrong? Either the mount on the k-frame is bent/wrong. Or the steering box or idler and pitman arm?
Re: E-body front suspension question [Re: 340swing] #1530979
11/12/13 11:33 AM
11/12/13 11:33 AM
pa.
dan9 Offline
dan9  Offline
pa.
I bought both pitman and idler from Rich Erenberg. The grease fitting hits the torsion bar. The one I took off seemed original and you could see where it had been rubbing the torsion bar also. I will grease then replace grease fitting with a plug. As i recall some cars from long ago came with plugs instead of grease fitting. We always had a box of various fitting to do an initial grease job.
Re: E-body front suspension question [Re: dan9] #1530980
11/12/13 12:24 PM
11/12/13 12:24 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
Brian,
Is there a part number on the center link?
1970 Dodge Challenger T/A
Re: E-body front suspension question [Re: jeff968] #1530981
11/12/13 07:57 PM
11/12/13 07:57 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
No part number on center link. But there is a number on the steering box. I have to take it out to read it.
Re: E-body front suspension question [Re: brads70] #1530982
11/12/13 08:08 PM
11/12/13 08:08 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Brad the drawing you showed is interesting. I can tell the left side is higher. The K frame appears to be straight no signs of damage. The right side clears nicely. It appears to be related to the steering box or pitman arm. Jeff has an extra center link that I will try. If that doesn't work i need to after the steering box of pitman arm. I will get the number off the box and some measurements.
i
Re: E-body front suspension question [Re: 340swing] #1530983
11/12/13 09:08 PM
11/12/13 09:08 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Here is the number on the steering box 2537349-2 there is a KCP with an oval around it also. From the bottom of the case to the end of the shaft is 2 5/16 inches. From the bottom bolt hole (center) to the end of the shaft is 3 5/16. If anybody can cross that number over to what it belongs to or has a box out that they know is from a 70 cuda manual steering and could measure the same. Thanks
Re: E-body front suspension question [Re: 340swing] #1530984
11/12/13 09:09 PM
11/12/13 09:09 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
2nd
Re: E-body front suspension question [Re: 340swing] #1530985
11/13/13 12:38 AM
11/13/13 12:38 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Brian,
I don't know what steering box your part number is.....however, manual boxes, 2537349-1 is 70 A body, and 2537350-6 is 70/1 E body, when it comes to manual boxes I don't follow the interchange (if any?) between the ABEF bodies
Mike
Re: E-body front suspension question [Re: DAYCLONA] #1530986
11/13/13 01:07 AM
11/13/13 01:07 AM
Connecticut
biginchmotor Offline
Connecticut
Hi Brian, I have several manual boxes if you need to look at them or take some measurements. John.
Re: E-body front suspension question [Re: brads70] #1530987
11/13/13 04:44 AM
11/13/13 04:44 AM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Have you tried the shims as shown in the lower drawing? This is how the factory adjusted clearance torsion bar to tie rod end. Driver side is easier than the passenger side. Just a thought.
Digger73
I live with fear everyday but, sometimes she lets me race!
Re: E-body front suspension question [Re: DAYCLONA] #1530988
11/13/13 08:40 AM
11/13/13 08:40 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Dayclona if those numbers are right then the box is wrong. A body by your numbers. So John (biginchmotor) if you have so extra manual boxes for an E-body I will be calling you. See if any have the number Dayclona put in his reply. Also I have not tried shimming it it's way off like a half inch. Thanks for all the help.
Re: E-body front suspension question [Re: 340swing] #1530989
11/13/13 11:47 AM
11/13/13 11:47 AM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
Hey John, I'm meeting Brian for lunch on Friday to give him the center link. If you are free join us. We'll get him straightened out
Page 2 of 4 1 2 3 4
