Borked another 904 tail
#148196
11/10/08 12:00 PM
11/10/08 12:00 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Yesterday I had another 904 tail housing crack. It did it on Memorial day and I simply swapped the housing hoping it was a fluke. Guess it wasn't.
I plan to have the alum shaft checked for balance but I also want to check slip yoke engagement. What is the ideal distance from the end of the tail to shoulder of the slip yoke?? Could the slip yoke not be inserted enough cause my problem??
Anything else I should be looking into. The engine is on stock rubber biscuit mounts that aren't torn and has a stock rubber tranny mount.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Borked another 904 tail
[Re: CJK440]
#148200
11/10/08 09:56 PM
11/10/08 09:56 PM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The last tail shaft I broke was due to excessive run-out on the tranny output shaft. Broke 2 tail shafts and could not figure out why, until I checked the tranny's output shaft with a dial indicator. Changed the output shaft and no more problems. To this day I don't know how the shaft got bent.
Master, again and still
[Re: CJK440]
#148201
11/10/08 10:01 PM
11/10/08 10:01 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Couple of causes:
Output shaft bend drive shaft bent drive shaft out of balance U joint not located properly, incorrectly installed, or moving withing the yoke. excessive front u joint angle.
[Re: turner]
#148203
11/11/08 08:42 AM
11/11/08 08:42 AM
Posts: 722 Hampstead, MD.
Troublemaker427
Hampstead, MD.
I broke several C4 tailhousings years ago because of a bent pinion. It doesn't take much!!!
Jody Aberts
1966 Fairlane 427
Troublemaker2
AA/NSS
1964 Galaxie 500XL
390-4spd.
1966 F-100
390-C6
1967 Plymouth VIP
383-TF
2003 Roadking
[Re: Troublemaker427]
#148204
11/11/08 05:07 PM
11/11/08 05:07 PM
CJK440
Ansonia, CT
Suspension is all stock with repop 340 springs. I am running the factory snubber. With the stock springs there is not enough room for an adjustable snubber and the way the car squats on launch I am not sure the pinion can rotate up much.
My housing broke thru the speedo hole, forward of the tranny mount, not like the pic above.
The tranny is coming out over the winter to get freshened up so I'll get the mainshaft out and indicate it.
I'll check the D-shaft too.
[Re: CJK440]
#148205
11/11/08 05:08 PM
11/11/08 05:08 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
What are you using for engine and tranny mounts?
RIP Monte Smith
[Re: CompWedgeEngines]
#148206
11/11/08 05:53 PM
11/11/08 05:53 PM
Posts: 189 Newark, OH
springers340dart
Newark, OH
i had this problem but with the 727 2 years ago, brand new driveshaft and it was just .018 out of balance. broke in the same place as yours turner
#148207
11/11/08 06:23 PM
11/11/08 06:23 PM
CJK440
Ansonia, CT
Stock rubber biscuit mounts in the front and stock rubber rear.
[Re: CJK440]
#148210
11/12/08 09:51 AM
11/12/08 09:51 AM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
put a truck housing on as they are stronger
WAXER
[Re: QWK_ENUF]
#148211
11/12/08 10:42 AM
11/12/08 10:42 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
is there such a thing for a 904 ?
[Re: QWK_ENUF]
#148214
11/12/08 01:34 PM
11/12/08 01:34 PM
dartman366
Mt. Vernon, Ohio
Good question, if there is then I never knew about it.
sorry , got 727 on the brain
That's ok, you are forgiven.
[Re: Quicktree]
#148218
11/13/08 10:42 AM
11/13/08 10:42 AM
CJK440
Ansonia, CT
I checked the pinion angle relative to the tranny mainshaft centerline when I first broke it.
[Re: CJK440]
#148219
11/16/08 03:10 PM
11/16/08 03:10 PM
CJK440
Ansonia, CT
Hmm, this looks less than ideal. Jackstands under rear axle.
[Re: 5126brl No more]
#148221
11/16/08 04:25 PM
11/16/08 04:25 PM
dartman366
Mt. Vernon, Ohio
I wouldn't want the shaft any shorter than that, mine the boot is about a 1/4 inch away from the very beginning of the radius, from the point you are showing how far will the yoke slip into the housing till it bottom's out?
[Re: dartman366]
#148222
11/23/08 11:30 AM
11/23/08 11:30 AM
CJK440
Ansonia, CT
Got a chance to play in the garage today. Unbolted the shaft and drove it all the way in. Looks like I am 1.5" from bottomed out.
[Re: CJK440]
#148223
11/24/08 09:51 AM
11/24/08 09:51 AM
CJK440
Ansonia, CT
The shaft is definately going in to check balance, think I should lengthen it .5-.75" while I'm there?
[Re: JohnRR]
#148225
11/24/08 10:06 AM
11/24/08 10:06 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
it looks to me like it is sticking out too far though
I agree
[Re: CJK440]
#148228
11/24/08 11:41 AM
11/24/08 11:41 AM
DJVCuda
Atco NJ
how will they LENGTHEN it ???
I think they talk dirty to it.
I figure they would cut the ends off and weld them to an new tube?? Perhaps its better to just make a new one....
[Re: CJK440]
#148229
11/24/08 12:18 PM
11/24/08 12:18 PM
JohnRR
U.S.S.A.
Not very impressive if it will only GROW a 1/2 "
as long as the yokes are good they can just put them on a new tube
[Re: JohnRR]
#148230
03/23/09 02:06 PM
03/23/09 02:06 PM
CJK440
Ansonia, CT
Let me wake this thread from the dead now that I got the rebuilt tranny/engine back in the car.
First off, the 2" measurement above is actually a little bit more. Maybe 2-1/8th. Its 2" when it was broken and must have had a gap.
Secondly, I verified the output shaft is straight on v blocks.
Third, I did find a truck tail and its very beefy but I still think I have a bad situation going on.
One thing that was really eating at me was why did I make a shaft that short?? I'm not that dumb, I wouldn't have ordered it like that. And why did it end up to be the OE length for my application but still be that far out??
One thing popped in my head. When I first ordered it I had an A body A833 in the car and now it has a 904. While the OAL of a 4 speed and a 904 is practically the same, I did have to buy a new slip yoke for the smaller 904 output.
Perhaps the aftermarket yoke is different than others???
[Re: Dodgem]
#148232
03/26/09 07:52 PM
03/26/09 07:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Probably too late
In a drag car there is no way I would go to that diamention, thats basically going 1.6" out, that number is based on a production car that was ment to have a ton of travel.... 3/4" - 1" is fine
[Re: MR_P_BODY]
#148233
03/26/09 08:05 PM
03/26/09 08:05 PM
CJK440
Ansonia, CT
New shaft on its way. Should yeild 3/4-1" of pullout when all set.
I guess the stackup of differences of the 904 vs A833 coupled with the change in 29 to 26 spline yokes, plus swapping a stock mopar 7260 pinion yoke for a 1330 spicer yoke just didn't work in my favor.
[Re: turner]
#148235
03/26/09 08:47 PM
03/26/09 08:47 PM
Quicktree
Mine was due to an incorrect pinion angle
there you have it
[Re: Quicktree]
#148236
03/27/09 12:51 PM
03/27/09 12:51 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
Another possible scenerio: IF the C-C dimensions for the shaft were stock length, and IF the replacement yoke was the same dimensions, and IF the Engine/Trans is in the stock location, then basically you only have 2 possible culprits for the shaft to be too short. The first would be the "stacking" of factory tolerances, the second would be that the rearend housing is not in stock location- perhaps the locating pin in the leaf springs has sheared. In the "olden days", we often redrilled the front spring hanger to shorten the wheelbase slightly, and flipped the front brackets upside down to lower the rear of the car and move the instant center up.
Be a Rebel- Break the Laws of Physics!
[Re: mbogina]
#148237
03/27/09 07:37 PM
03/27/09 07:37 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Also if the body is bent even slightly it will change the length between the trans and diff. If it is bowed down like a smiley face the way it would be inclined to do after sitting on the wheels for almost 40 years then it would need a longer driveshaft.
Production tollerances could stack up quite a bit, think about the perches could be a hair off the body seams could be a hair off.
