Borked another 904 tail
#148196
11/10/08 12:00 PM
11/10/08 12:00 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Yesterday I had another 904 tail housing crack. It did it on Memorial day and I simply swapped the housing hoping it was a fluke. Guess it wasn't.
I plan to have the alum shaft checked for balance but I also want to check slip yoke engagement. What is the ideal distance from the end of the tail to shoulder of the slip yoke?? Could the slip yoke not be inserted enough cause my problem??
Anything else I should be looking into. The engine is on stock rubber biscuit mounts that aren't torn and has a stock rubber tranny mount.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Borked another 904 tail
[Re: CJK440]
#148200
11/10/08 09:56 PM
11/10/08 09:56 PM
Posts: 12,256 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The last tail shaft I broke was due to excessive run-out on the tranny output shaft. Broke 2 tail shafts and could not figure out why, until I checked the tranny's output shaft with a dial indicator. Changed the output shaft and no more problems. To this day I don't know how the shaft got bent.
Master, again and still
[Re: CJK440]
#148201
11/10/08 10:01 PM
11/10/08 10:01 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Couple of causes:
Output shaft bend drive shaft bent drive shaft out of balance U joint not located properly, incorrectly installed, or moving withing the yoke. excessive front u joint angle.
[Re: turner]
#148203
11/11/08 08:42 AM
11/11/08 08:42 AM
Posts: 722 Hampstead, MD.
Troublemaker427
Hampstead, MD.
I broke several C4 tailhousings years ago because of a bent pinion. It doesn't take much!!!
Jody Aberts
1966 Fairlane 427
Troublemaker2
AA/NSS
1964 Galaxie 500XL
390-4spd.
1966 F-100
390-C6
1967 Plymouth VIP
383-TF
2003 Roadking
[Re: Troublemaker427]
#148204
11/11/08 05:07 PM
11/11/08 05:07 PM
CJK440
Ansonia, CT
Suspension is all stock with repop 340 springs. I am running the factory snubber. With the stock springs there is not enough room for an adjustable snubber and the way the car squats on launch I am not sure the pinion can rotate up much.
My housing broke thru the speedo hole, forward of the tranny mount, not like the pic above.
The tranny is coming out over the winter to get freshened up so I'll get the mainshaft out and indicate it.
I'll check the D-shaft too.
[Re: CJK440]
#148205
11/11/08 05:08 PM
11/11/08 05:08 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
What are you using for engine and tranny mounts?
RIP Monte Smith
[Re: CompWedgeEngines]
#148206
11/11/08 05:53 PM
11/11/08 05:53 PM
Posts: 189 Newark, OH
springers340dart
Newark, OH
i had this problem but with the 727 2 years ago, brand new driveshaft and it was just .018 out of balance. broke in the same place as yours turner
#148207
11/11/08 06:23 PM
11/11/08 06:23 PM
CJK440
Ansonia, CT
Stock rubber biscuit mounts in the front and stock rubber rear.
[Re: CJK440]
#148210
11/12/08 09:51 AM
11/12/08 09:51 AM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
put a truck housing on as they are stronger
WAXER
[Re: QWK_ENUF]
#148214
11/12/08 01:34 PM
11/12/08 01:34 PM
dartman366
Mt. Vernon, Ohio
is there such a thing for a 904 ?
Good question, if there is then I never knew about it.
sorry , got 727 on the brain
That's ok, you are forgiven.
