Page 1 of 3 1 2 3
Borked another 904 tail #148196
11/10/08 12:00 PM
11/10/08 12:00 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Yesterday I had another 904 tail housing crack. It did it on Memorial day and I simply swapped the housing hoping it was a fluke. Guess it wasn't.
I plan to have the alum shaft checked for balance but I also want to check slip yoke engagement. What is the ideal distance from the end of the tail to shoulder of the slip yoke?? Could the slip yoke not be inserted enough cause my problem??
Anything else I should be looking into. The engine is on stock rubber biscuit mounts that aren't torn and has a stock rubber tranny mount.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Borked another 904 tail [Re: CJK440] #148197
11/10/08 12:29 PM
11/10/08 12:29 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I had a 11.90's duster start breaking tailshafts before all of the sudden. Turns out the pinion snubber was broke, and it was letting the axle wind up an pull the yoke out. Fixed the pinion snubber and never had another tailshaft break...
Ideally the yoke should be pulled out 3/4"~1" from bottomed out in the trans...
Re: Borked another 904 tail [Re: CJK440] #148198
11/10/08 08:56 PM
11/10/08 08:56 PM
I measure the length of the splines inside the yoke and then slide the yoke in all the way and pull it out half the length of the splines and measure to the center of the pinion yoke to get the proper driveshaft length, that is with the car sitting on the ground or on four jack stands so the weight is on the suspension just like it will be when I drive it. Some yokes are longer inside than others on the spline lengths
Re: Borked another 904 tail [Re: CJK440] #148199
11/10/08 09:17 PM
11/10/08 09:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
3/4" is usually fine BUT it depends on the type
of rear suspension
Re: Borked another 904 tail [Re: CJK440] #148200
11/10/08 09:56 PM
11/10/08 09:56 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
The last tail shaft I broke was due to excessive run-out on the tranny output shaft. Broke 2 tail shafts and could not figure out why, until I checked the tranny's output shaft with a dial indicator. Changed the output shaft and no more problems. To this day I don't know how the shaft got bent.
Master, again and still
Re: Borked another 904 tail [Re: CJK440] #148201
11/10/08 10:01 PM
11/10/08 10:01 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Couple of causes:
Output shaft bend
drive shaft bent
drive shaft out of balance
U joint not located properly, incorrectly installed, or moving withing the yoke.
excessive front u joint angle.
Re: Borked another 904 tail [Re: torkrules] #148202
11/11/08 07:08 AM
11/11/08 07:08 AM
metro detroit
turner Offline
turner  Offline
metro detroit
Mine was due to an incorrect pinion angle
Re: Borked another 904 tail [Re: turner] #148203
11/11/08 08:42 AM
11/11/08 08:42 AM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
I broke several C4 tailhousings years ago because of a bent pinion. It doesn't take much!!!
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
Re: Borked another 904 tail [Re: Troublemaker427] #148204
11/11/08 05:07 PM
11/11/08 05:07 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Suspension is all stock with repop 340 springs. I am running the factory snubber. With the stock springs there is not enough room for an adjustable snubber and the way the car squats on launch I am not sure the pinion can rotate up much.
My housing broke thru the speedo hole, forward of the tranny mount, not like the pic above.
The tranny is coming out over the winter to get freshened up so I'll get the mainshaft out and indicate it.
I'll check the D-shaft too.
Re: Borked another 904 tail [Re: CJK440] #148205
11/11/08 05:08 PM
11/11/08 05:08 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
What are you using for engine and tranny mounts?
RIP Monte Smith
Re: Borked another 904 tail [Re: CompWedgeEngines] #148206
11/11/08 05:53 PM
11/11/08 05:53 PM
Newark, OH
springers340dart Offline
Newark, OH
i had this problem but with the 727 2 years ago, brand new driveshaft and it was just .018 out of balance. broke in the same place as yours turner
Re: Borked another 904 tail [Re: CompWedgeEngines] #148207
11/11/08 06:23 PM
11/11/08 06:23 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Stock rubber biscuit mounts in the front and stock rubber rear.
Re: Borked another 904 tail [Re: CJK440] #148208
11/11/08 07:49 PM
11/11/08 07:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
are you posative they aren't torn or broke? I had one in a 68 coronet that I could of sworn was ok untill I jacked the motor up and it seperated, looked good while the motor weight was on it.
Re: Borked another 904 tail [Re: dartman366] #148209
11/12/08 09:21 AM
11/12/08 09:21 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I'll be double checking them when the motor is out this winter. I'll probably switch to the Mity mounts to be safe.
Re: Borked another 904 tail [Re: CJK440] #148210
11/12/08 09:51 AM
11/12/08 09:51 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
put a truck housing on as they are stronger
WAXER
Re: Borked another 904 tail [Re: QWK_ENUF] #148211
11/12/08 10:42 AM
11/12/08 10:42 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
is there such a thing for a 904 ?
Re: Borked another 904 tail [Re: JohnRR] #148212
11/12/08 12:43 PM
11/12/08 12:43 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Good question, if there is then I never knew about it.
Re: Borked another 904 tail [Re: dartman366] #148213
11/12/08 01:29 PM
11/12/08 01:29 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
sorry , got 727 on the brain
WAXER
Re: Borked another 904 tail [Re: QWK_ENUF] #148214
11/12/08 01:34 PM
11/12/08 01:34 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
That's ok, you are forgiven.
Re: Borked another 904 tail [Re: dartman366] #148215
11/12/08 05:33 PM
11/12/08 05:33 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
There is a 904 truck tail housing. And they appear to be beefier. Have one in my dart. May have another if you need it? Mel
Page 1 of 3 1 2 3
