Re: Borked another 904 tail
[Re: Quicktree]
#148218
11/13/08 10:42 AM
11/13/08 10:42 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I checked the pinion angle relative to the tranny mainshaft centerline when I first broke it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#148219
11/16/08 03:10 PM
11/16/08 03:10 PM
CJK440
Ansonia, CT
Hmm, this looks less than ideal. Jackstands under rear axle.
[Re: 5126brl No more]
#148221
11/16/08 04:25 PM
11/16/08 04:25 PM
dartman366
Mt. Vernon, Ohio
I wouldn't want the shaft any shorter than that, mine the boot is about a 1/4 inch away from the very beginning of the radius, from the point you are showing how far will the yoke slip into the housing till it bottom's out?
[Re: dartman366]
#148222
11/23/08 11:30 AM
11/23/08 11:30 AM
CJK440
Ansonia, CT
Got a chance to play in the garage today. Unbolted the shaft and drove it all the way in. Looks like I am 1.5" from bottomed out.
[Re: CJK440]
#148223
11/24/08 09:51 AM
11/24/08 09:51 AM
CJK440
Ansonia, CT
The shaft is definately going in to check balance, think I should lengthen it .5-.75" while I'm there?
[Re: JohnRR]
#148225
11/24/08 10:06 AM
11/24/08 10:06 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
it looks to me like it is sticking out too far though
I agree
[Re: CJK440]
#148228
11/24/08 11:41 AM
11/24/08 11:41 AM
DJVCuda
Atco NJ
how will they LENGTHEN it ???
I think they talk dirty to it.
I figure they would cut the ends off and weld them to an new tube?? Perhaps its better to just make a new one....
[Re: CJK440]
#148229
11/24/08 12:18 PM
11/24/08 12:18 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Not very impressive if it will only GROW a 1/2 "
as long as the yokes are good they can just put them on a new tube
[Re: JohnRR]
#148230
03/23/09 02:06 PM
03/23/09 02:06 PM
CJK440
Ansonia, CT
Let me wake this thread from the dead now that I got the rebuilt tranny/engine back in the car.
First off, the 2" measurement above is actually a little bit more. Maybe 2-1/8th. Its 2" when it was broken and must have had a gap.
Secondly, I verified the output shaft is straight on v blocks.
Third, I did find a truck tail and its very beefy but I still think I have a bad situation going on.
One thing that was really eating at me was why did I make a shaft that short?? I'm not that dumb, I wouldn't have ordered it like that. And why did it end up to be the OE length for my application but still be that far out??
One thing popped in my head. When I first ordered it I had an A body A833 in the car and now it has a 904. While the OAL of a 4 speed and a 904 is practically the same, I did have to buy a new slip yoke for the smaller 904 output.
Perhaps the aftermarket yoke is different than others???
[Re: Dodgem]
#148232
03/26/09 07:52 PM
03/26/09 07:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Probably too late
In a drag car there is no way I would go to that diamention, thats basically going 1.6" out, that number is based on a production car that was ment to have a ton of travel.... 3/4" - 1" is fine
[Re: MR_P_BODY]
#148233
03/26/09 08:05 PM
03/26/09 08:05 PM
CJK440
Ansonia, CT
New shaft on its way. Should yeild 3/4-1" of pullout when all set.
I guess the stackup of differences of the 904 vs A833 coupled with the change in 29 to 26 spline yokes, plus swapping a stock mopar 7260 pinion yoke for a 1330 spicer yoke just didn't work in my favor.
[Re: turner]
#148235
03/26/09 08:47 PM
03/26/09 08:47 PM
Quicktree
Mine was due to an incorrect pinion angle
there you have it
