Page 2 of 3 1 2 3
Re: Borked another 904 tail [Re: 727builder] #148216
11/12/08 07:26 PM
11/12/08 07:26 PM
CT
turbocolt2.4L Offline
CT
get one off a full size van has the snapring cover on side.
Re: Borked another 904 tail [Re: dartman366] #148217
11/12/08 07:37 PM
11/12/08 07:37 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Pinion Angle
Tired of breaking cases and drive shafts? There are many books that misled you on setting the pinion angle. For Drag Racing this is simple. You are trying to set the pinion angle to be parallel with the centerline of the engine & transmission on hard acceleration. To achieve this you must first figure out the parallel setting of the rear end to correspond to the angle of the engine & transmission, then add the proper amount of pinion angle. Add 1 deg. for 4-Link vehicles, 2 to 3 deg. for ladder-bar vehicles. Place stands under suspension to duplicate vehicle at ride height. Caution do not remove drive shaft without securing vehicle first. Take measurement with drive shaft removed.
Re: Borked another 904 tail [Re: Quicktree] #148218
11/13/08 10:42 AM
11/13/08 10:42 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I checked the pinion angle relative to the tranny mainshaft centerline when I first broke it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Borked another 904 tail [Re: CJK440] #148219
11/16/08 03:10 PM
11/16/08 03:10 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Hmm, this looks less than ideal. Jackstands under rear axle.
Re: Borked another 904 tail [Re: CJK440] #148220
11/16/08 03:13 PM
11/16/08 03:13 PM
Connecticut
5126brl No more Offline
Connecticut
I think thats ok.
The shaft ends at the seal boot and you want 1" of room so it does not bottom out in yoke.
Re: Borked another 904 tail [Re: 5126brl No more] #148221
11/16/08 04:25 PM
11/16/08 04:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I wouldn't want the shaft any shorter than that, mine the boot is about a 1/4 inch away from the very beginning of the radius, from the point you are showing how far will the yoke slip into the housing till it bottom's out?
Re: Borked another 904 tail [Re: dartman366] #148222
11/23/08 11:30 AM
11/23/08 11:30 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Got a chance to play in the garage today. Unbolted the shaft and drove it all the way in.
Looks like I am 1.5" from bottomed out.
Re: Borked another 904 tail [Re: CJK440] #148223
11/24/08 09:51 AM
11/24/08 09:51 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
The shaft is definately going in to check balance, think I should lengthen it .5-.75" while I'm there?
Re: Borked another 904 tail [Re: CJK440] #148224
11/24/08 10:02 AM
11/24/08 10:02 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
how will they LENGTHEN it ???
it looks to me like it is sticking out too far though
Re: Borked another 904 tail [Re: JohnRR] #148225
11/24/08 10:06 AM
11/24/08 10:06 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I agree
Re: Borked another 904 tail [Re: DJVCuda] #148226
11/24/08 10:20 AM
11/24/08 10:20 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Something you may want to consider doing, since the car is up on jack stands.
Measure the angles:
-Get car as level as you can supported by suspension
-Use a plumb bob and masking tape on the floor to find the centerline of the CAR
-Now find the centerline of the Crankshaft / Transmission shafts. Use a plumb bob off the front pulley and off the trans yoke. Very easy to find where the engine / trans is POINTED relative to the CAR.
-Now find where the rear end is pointed. You can do this with a laser level on the rear axles / wheels,.....
-Everything should be lined up and parrallel to the car centerline.
If you have the rear pointed to the right and the engine / trans pointed to the left,....then you drive shaft is going to be at a crazy angle and want to swing like a hammock.....this can break stuff!!!!!!
I just went through this when setting up my Dana. I've got it all spot on!!!!!!
Re: Borked another 904 tail [Re: JohnRR] #148227
11/24/08 11:21 AM
11/24/08 11:21 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I think they talk dirty to it.
I figure they would cut the ends off and weld them to an new tube?? Perhaps its better to just make a new one....
Re: Borked another 904 tail [Re: CJK440] #148228
11/24/08 11:41 AM
11/24/08 11:41 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Re: Borked another 904 tail [Re: CJK440] #148229
11/24/08 12:18 PM
11/24/08 12:18 PM
JohnRR Offline
JohnRR  Offline
Not very impressive if it will only GROW a 1/2 "
as long as the yokes are good they can just put them on a new tube
Re: Borked another 904 tail [Re: JohnRR] #148230
03/23/09 02:06 PM
03/23/09 02:06 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Let me wake this thread from the dead now that I got the rebuilt tranny/engine back in the car.
First off, the 2" measurement above is actually a little bit more. Maybe 2-1/8th. Its 2" when it was broken and must have had a gap.
Secondly, I verified the output shaft is straight on v blocks.
Third, I did find a truck tail and its very beefy but I still think I have a bad situation going on.
One thing that was really eating at me was why did I make a shaft that short?? I'm not that dumb, I wouldn't have ordered it like that. And why did it end up to be the OE length for my application but still be that far out??
One thing popped in my head. When I first ordered it I had an A body A833 in the car and now it has a 904. While the OAL of a 4 speed and a 904 is practically the same, I did have to buy a new slip yoke for the smaller 904 output.
Perhaps the aftermarket yoke is different than others???
Re: Borked another 904 tail [Re: CJK440] #148231
03/26/09 06:26 PM
03/26/09 06:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Probably too late
Re: Borked another 904 tail [Re: Dodgem] #148232
03/26/09 07:52 PM
03/26/09 07:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Probably too late
In a drag car there is no way I would go to that
diamention, thats basically going 1.6" out, that
number is based on a production car that was ment
to have a ton of travel.... 3/4" - 1" is fine
Re: Borked another 904 tail [Re: MR_P_BODY] #148233
03/26/09 08:05 PM
03/26/09 08:05 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
New shaft on its way. Should yeild 3/4-1" of pullout when all set.
I guess the stackup of differences of the 904 vs A833 coupled with the change in 29 to 26 spline yokes, plus swapping a stock mopar 7260 pinion yoke for a 1330 spicer yoke just didn't work in my favor.
Re: Borked another 904 tail [Re: CJK440] #148234
03/26/09 08:20 PM
03/26/09 08:20 PM
Connecticut
Connecticut
I called mark williams after my new shaft came in. It has a 1.125 of room till it bottoms out. I thought it was a bit short. They said they like 3/4 to 1" on race cars. I was told not to sweat the extra 1/8th.
I know that they make different length pinion yokes so make sure you use all the parts that will be in place when racing.
Re: Borked another 904 tail [Re: turner] #148235
03/26/09 08:47 PM
03/26/09 08:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Mine was due to an incorrect pinion angle
there you have it
Page 2 of 3 1 2 3
