Re: 10 sec stock stroke 360 combos
[Re: sshemi]
#1307761
11/16/12 12:16 PM
11/16/12 12:16 PM
Posts: 3,415 Toronto
mshred
Toronto
Ditching the 4 speed???!!!! Are you gonna buy a new skirt also with flowers on???
Its already on my Christmas list
I wanted to put a Jerico Dr-4 in the car, but could barely afford the trans and shifter- the clutch was going to be close to another thousand bucks, and I just couldn't afford it. My 4 speed stuff was worth more in one peice then it was scattered
[Re: Bad340fish]
#1307762
11/16/12 12:17 PM
11/16/12 12:17 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
My 360 is .030 over with kb-107's, unported eddy heads, cast crank, stock rods, .525 solid cam, m-1 intake with 2" spacer, 750hp on e-85. Trans is 727 with cheetah manual vb, turbo action "J" converter. Rear is 8 3/4" with 4.30 gears, 29"x9" slicks. I footbrake it launching at 2500 and shifting at 6400. My car weighs 2850 with me in it.
[Re: moparguy7074]
#1307763
11/16/12 12:19 PM
11/16/12 12:19 PM
mshred
Toronto
What compression? That sounds like a super quick running combo
Some of you guys have some damn light cars...makes me feel like mine is a sherman tank lol
[Re: mshred]
#1307764
11/16/12 07:05 PM
11/16/12 07:05 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Mines a turd lol I'm 3340lbs with me in it and all steel and full interior. STREET car as all get out though, in a few ways
[Re: SpareParts]
#1307765
11/17/12 01:59 AM
11/17/12 01:59 AM
mshred
Toronto
whats your combo like?
[Re: Bad340fish]
#1307766
11/17/12 03:37 AM
11/17/12 03:37 AM
ScatPackNick
70AARCuda over on FABO posted up his combo. Runs strong! Nice light car, weighs around 2750+driver. http://www.forabodiesonly.com/mopar/showthread.php?t=194137&highlight=360
10.911 @ 121.58 60ft 1.497
Las Vegas, Temperature over 100 degrees - DA over 5000 ft...
73 360 .060 with Wiseco flattop pistons...11 to 1 compression (pistons have MP part number on them got them for 200 bucks)
stock 360 crank with H beam rods (630 grams) no brand name... Hughes 260/264 solid cam with 1.6 crane rockers Hughes CnC eddy heads with 1111 springs..(bought them from someone on FABO) Weiand X-Celerator intake cause it fit the milled heads and block (wanted to use Eddy Victor) Holley 950 carb....brand new at 250 bucks.. Hooker 5204 1 3/4 headers MP electronic race distributor with MSD 7AL-2..
904 trans by tony with Tranzact transbrake non-LBA Turbo Action 4400 series converter..flashes to 5200 rpm 10x29" tires 4.56 gears
http://www.youtube.com/watch?feature=player_embedded&v=YMvqpxF1mfU
That wieght would be nice!
+1
[Re: ScatPackNick]
#1307767
11/17/12 03:39 AM
11/17/12 03:39 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
+1
Weighs right at 3000# IIRC
[Re: mshred]
#1307768
11/17/12 04:50 AM
11/17/12 04:50 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
72 demon--367c.i.--stock stroke factory cast crank--eagle rods--flat top pistons .04 out of hole--10.75 to 1--587 cast iron heads,[nicely prepped]--victor 340 intake--Racer brown STX-21 flat tappet cam--995cfm carb-shop carb--727 trans w/tranz-act brake-dana 60 w/4.56 gears--13x31 slicks--3100lbs--was run on 50% 110 race gas and 50% 93 oct. pump gas. Motor lasted for years and aprox. 1400 passes before the crankshaft split into 3 pieces. Car went as quick as 10.35 at 127.xx in mine shaft air and as slow as 10.60s in nasty air with that 367. A very similar stock stroke 367 c.i. engine with dome pistons, [12 to 1] on same mixed gas only went a tenth quicker, 10.25 at 129.99. Same car with a 587 cast iron headed 13 to 1 418, [360 stroker], and a Racer Brown STX-22 cam went 9.68 at 136.xx, but on straight 110 race gas.
[Re: 70AARcuda]
#1307770
11/17/12 04:01 PM
11/17/12 04:01 PM
RobX4406
+1
Rob, I going to tell Tonya, you think she weights 250 lbs...LOL
71 Dart on Vegas scales weight 2745, with her 2875...car in process of losing another 50+lbs with light weight disc brakes.
For some reason I thought this was about the Demon.
[Re: qwkmopardan]
#1307771
11/17/12 06:26 PM
11/17/12 06:26 PM
mshred
Toronto
Thats an AWESOME running demon man! And getting it done with 587 heads to boot! Given me some hope, thats for sure...too bad I cant get this street car much lighter then it already is, that would definitely help I think.
[Re: mshred]
#1307772
11/18/12 12:14 AM
11/18/12 12:14 AM
moparguy7074
Rudolph, Ohio
It figures out to be somewhere around 10.5. It doesnt run to bad for what it is.
[Re: mshred]
#1307773
11/18/12 11:25 AM
11/18/12 11:25 AM
Posts: 9,847 MI, usa
dvw
MI, usa
Anywhere you can take weight out of the car?
Radials are faster, period.
Not really... I weighed the backseat that I never use, and its close to 50 pounds. But then im adding more weight by having to cage it. Thinking of pulling the heater as well, though not sure how much im going to save there. Already has no ps, glass hood, aluminum wheels, installing kirkeys, going to a 904 trans to try and save weight there.
Would more gear do the trick? I am not opposed to it, but I don't want more than a 4.56 or I think it will be a little much
I just weighed the stock windows and regulators from my Belvedere, 124lbs. Lexan weight minus the windshield was 13 lbs total for sides and back . I reused the glass windshield so I kept 31 of the 124. Doug
[Re: dustyswinger]
#1307775
11/19/12 07:22 AM
11/19/12 07:22 AM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
10's with a pump gas 360 is a cake walk these days...... Factory Cast crank....... no worries 750 Holley............ Big enough Air gap is Good..........A single plane with a big plenum much better Get a 4 hole tapered carb spacer 1 3/4 headers for sure If you have the engine apart there are lot's of little things u can do........
