Page 5 of 5 1 2 3 4 5
Re: 10 sec stock stroke 360 combos [Re: sshemi] #1307761
11/16/12 12:16 PM
11/16/12 12:16 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Ditching the 4 speed???!!!!
Are you gonna buy a new skirt also with flowers on???
Its already on my Christmas list
I wanted to put a Jerico Dr-4 in the car, but could barely afford the trans and shifter- the clutch was going to be close to another thousand bucks, and I just couldn't afford it. My 4 speed stuff was worth more in one peice then it was scattered
Re: 10 sec stock stroke 360 combos [Re: Bad340fish] #1307762
11/16/12 12:17 PM
11/16/12 12:17 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
My 360 is .030 over with kb-107's, unported eddy heads, cast crank, stock rods, .525 solid cam, m-1 intake with 2" spacer, 750hp on e-85. Trans is 727 with cheetah manual vb, turbo action "J" converter. Rear is 8 3/4" with 4.30 gears, 29"x9" slicks.
I footbrake it launching at 2500 and shifting at 6400. My car weighs 2850 with me in it.
Re: 10 sec stock stroke 360 combos [Re: moparguy7074] #1307763
11/16/12 12:19 PM
11/16/12 12:19 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
What compression? That sounds like a super quick running combo
Some of you guys have some damn light cars...makes me feel like mine is a sherman tank lol
Re: 10 sec stock stroke 360 combos [Re: mshred] #1307764
11/16/12 07:05 PM
11/16/12 07:05 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Mines a turd lol I'm 3340lbs with me in it and all steel and full interior. STREET car as all get out though, in a few ways
Re: 10 sec stock stroke 360 combos [Re: SpareParts] #1307765
11/17/12 01:59 AM
11/17/12 01:59 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
whats your combo like?
Re: 10 sec stock stroke 360 combos [Re: Bad340fish] #1307766
11/17/12 03:37 AM
11/17/12 03:37 AM
ScatPackNick Offline
70AARCuda over on FABO posted up his combo. Runs strong! Nice light car, weighs around 2750+driver.
http://www.forabodiesonly.com/mopar/showthread.php?t=194137&highlight=360
10.911 @ 121.58 60ft 1.497
Las Vegas, Temperature over 100 degrees
- DA over 5000 ft...
73 360 .060 with Wiseco flattop pistons...11 to 1 compression (pistons have MP part number on them got them for 200 bucks)
stock 360 crank with H beam rods (630 grams) no brand name...
Hughes 260/264 solid cam with 1.6 crane rockers
Hughes CnC eddy heads with 1111 springs..(bought them from someone on FABO)
Weiand X-Celerator intake cause it fit the milled heads and block (wanted to use Eddy Victor)
Holley 950 carb....brand new at 250 bucks..
Hooker 5204 1 3/4 headers
MP electronic race distributor with MSD 7AL-2..
904 trans by tony with Tranzact transbrake non-LBA
Turbo Action 4400 series converter..flashes to 5200 rpm
10x29" tires
4.56 gears
http://www.youtube.com/watch?feature=player_embedded&v=YMvqpxF1mfU
That wieght would be nice!
+1
Re: 10 sec stock stroke 360 combos [Re: ScatPackNick] #1307767
11/17/12 03:39 AM
11/17/12 03:39 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
10x29" tires
4.56 gears
+1
Weighs right at 3000# IIRC
Re: 10 sec stock stroke 360 combos [Re: mshred] #1307768
11/17/12 04:50 AM
11/17/12 04:50 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
72 demon--367c.i.--stock stroke factory cast crank--eagle rods--flat top pistons .04 out of hole--10.75 to 1--587 cast iron heads,[nicely prepped]--victor 340 intake--Racer brown STX-21 flat tappet cam--995cfm carb-shop carb--727 trans w/tranz-act brake-dana 60 w/4.56 gears--13x31 slicks--3100lbs--was run on 50% 110 race gas and 50% 93 oct. pump gas. Motor lasted for years and aprox. 1400 passes before the crankshaft split into 3 pieces.
Car went as quick as 10.35 at 127.xx in mine shaft air and as slow as 10.60s in nasty air with that 367.
A very similar stock stroke 367 c.i. engine with dome pistons, [12 to 1] on same mixed gas only went a tenth quicker, 10.25 at 129.99.
Same car with a 587 cast iron headed 13 to 1 418, [360 stroker], and a Racer Brown STX-22 cam went 9.68 at 136.xx, but on straight 110 race gas.
Re: 10 sec stock stroke 360 combos [Re: RobX4406] #1307769
11/17/12 03:41 PM
11/17/12 03:41 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
10x29" tires
4.56 gears
+1
Rob, I going to tell Tonya, you think she weights 250 lbs...LOL
71 Dart on Vegas scales weight 2745, with her 2875...car in process of losing another 50+lbs with light weight disc brakes.
Tony
70 AARCuda Vitamin C
Re: 10 sec stock stroke 360 combos [Re: 70AARcuda] #1307770
11/17/12 04:01 PM
11/17/12 04:01 PM
RobX4406 Offline
RobX4406  Offline
10x29" tires
4.56 gears
+1
For some reason I thought this was about the Demon.
Re: 10 sec stock stroke 360 combos [Re: qwkmopardan] #1307771
11/17/12 06:26 PM
11/17/12 06:26 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thats an AWESOME running demon man! And getting it done with 587 heads to boot! Given me some hope, thats for sure...too bad I cant get this street car much lighter then it already is, that would definitely help I think.
Re: 10 sec stock stroke 360 combos [Re: mshred] #1307772
11/18/12 12:14 AM
11/18/12 12:14 AM
Rudolph, Ohio
Rudolph, Ohio
It figures out to be somewhere around 10.5. It doesnt run to bad for what it is.
Re: 10 sec stock stroke 360 combos [Re: mshred] #1307773
11/18/12 11:25 AM
11/18/12 11:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Anywhere you can take weight out of the car?
Radials are faster, period.
Not really... I weighed the backseat that I never use, and its close to 50 pounds. But then im adding more weight by having to cage it. Thinking of pulling the heater as well, though not sure how much im going to save there. Already has no ps, glass hood, aluminum wheels, installing kirkeys, going to a 904 trans to try and save weight there.
Would more gear do the trick? I am not opposed to it, but I don't want more than a 4.56 or I think it will be a little much
I just weighed the stock windows and regulators from my Belvedere, 124lbs. Lexan weight minus the windshield was 13 lbs total for sides and back . I reused the glass windshield so I kept 31 of the 124.
Doug
Re: 10 sec stock stroke 360 combos [Re: mshred] #1307774
11/18/12 10:28 PM
11/18/12 10:28 PM
MN
dustyswinger Offline
MN
My old 360 motor
11.25 compression
528 mopar cam
1.6 rockers
ported 987 smogger heads
950 hp carb
victor intake
1 7/8 hedman headers
low gear set 904
9.5 convertor
4.56 gears
Ran 11.0 at 123
Re: 10 sec stock stroke 360 combos [Re: dustyswinger] #1307775
11/19/12 07:22 AM
11/19/12 07:22 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
10's with a pump gas 360 is a cake walk these days......
Factory Cast crank....... no worries
750 Holley............ Big enough
Air gap is Good..........A single plane with a big plenum much better
Get a 4 hole tapered carb spacer
1 3/4 headers for sure
If you have the engine apart there are lot's of little things u can do........
