Las Vegas, Temperature over 100 degrees - DA over 5000 ft...
73 360 .060 with Wiseco flattop pistons...11 to 1 compression (pistons have MP part number on them got them for 200 bucks)
stock 360 crank with H beam rods (630 grams) no brand name... Hughes 260/264 solid cam with 1.6 crane rockers Hughes CnC eddy heads with 1111 springs..(bought them from someone on FABO) Weiand X-Celerator intake cause it fit the milled heads and block (wanted to use Eddy Victor) Holley 950 carb....brand new at 250 bucks.. Hooker 5204 1 3/4 headers MP electronic race distributor with MSD 7AL-2..
904 trans by tony with Tranzact transbrake non-LBA Turbo Action 4400 series converter..flashes to 5200 rpm 10x29" tires 4.56 gears
