Re: Tore into the engine tonight....
[Re: dartman366]
#1162298
01/21/12 11:46 PM
01/21/12 11:46 PM
Posts: 3,456 Out West
408strokerdart
Out West
Check that the ball end on the pushrod and the lifter/rocker adjuster to make sure the radius matches and also check that the adjuster hasn't pushed the threads in the rocker.
Will take a good look at those items tomorrow.
[Re: 00snake530]
#1162301
01/22/12 12:00 AM
01/22/12 12:00 AM
408strokerdart
Out West
last time i had a loose rocker like that the cam lobe went flat
Cam is getting re-ground anyway...
[Re: supercomp]
#1162302
01/22/12 12:01 AM
01/22/12 12:01 AM
408strokerdart
Out West
Do you run rollers?
Yes. Crane ultra pro.
[Re: 408strokerdart]
#1162305
01/22/12 10:26 AM
01/22/12 10:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Brian I forget what rockers you are running but some of the adjusters are junk and will pull the threads out and were soft so the push rods beat the cups... also as said check the dia of the cup to the PR ball... 3/8 balls DONT FIT on any of the cups
[Re: MR_P_BODY]
#1162306
01/22/12 10:31 AM
01/22/12 10:31 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Can't believe it ran as well as it did. As mentioned before, you're going to Pick up substantial gains.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ChrgrCuda]
#1162307
01/22/12 10:36 AM
01/22/12 10:36 AM
MR_P_BODY
I really doubt it will pick up much at all... JMO
[Re: MR_P_BODY]
#1162308
01/22/12 11:11 AM
01/22/12 11:11 AM
dartman366
Mt. Vernon, Ohio
I agree,,if it picks up at all it will be negligable.
[Re: hemi-itis]
#1162312
01/22/12 01:07 PM
01/22/12 01:07 PM
MR_P_BODY
How could it NOT pick up when these issues are corrected???
If he were to just correct the problem it wouldnt change much at all... I've been there... but he is regrinding the cam so we wont know for sure
[Re: Ari440]
#1162315
01/22/12 02:13 PM
01/22/12 02:13 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Sounds like it is time to junk it and get something with more power Seriously as has been said already check everything over very well. Leave no stone unturned..
[Re: MR_P_BODY]
#1162316
01/22/12 02:51 PM
01/22/12 02:51 PM
dartman366
Mt. Vernon, Ohio
if the heads are a restriction then no amount of more valve lift is going to make a profound improvement, my present heads are just that, I installed a cam with more lift and duration and didn't pick up anything, so I went back to the origional grind.
[Re: dartman366]
#1162317
01/22/12 03:49 PM
01/22/12 03:49 PM
Posts: 3,395 Pa
Hot 340
Pa
But he's running a W8 head, they are not dead at .600+ like most smallblock heads. Just the contrary.
#1162319
01/22/12 04:54 PM
01/22/12 04:54 PM
Posts: 3,695 nc
emarine01
nc
Found three rockers with so much lash that I am surprised I didn't loose the push rods or lash caps. I stopped with the feeler gauges when I was around .085" so they were real loose. I knew something was wrong when I pulled the intake and found three ports dark when the other five were clean. All three were intake rockers on those "dark" cylinders. I was well past the point where I should have run the valves, but this was a surprise since there was nothing to indicate anything was wrong. No noise, misfire, popping....nothing. I will be replacing the lifters anyway, but what else could have suffered? Can't believe this just went a mid 5.8 in this condition.
What is the definition of < dark cyls > & what would cause this from too much intake lash?
[Re: pittsburghracer]
#1162320
01/22/12 05:13 PM
01/22/12 05:13 PM
408strokerdart
Out West
"Usually" anything on to intake side will hurt the performance more than it will on the exhaust side. A friend of mine bent 8 exhaust pushrods in a stocker on a run a few years ago and the car still made a good pass. He loaded up took the car home to get and early start on repairs. He was so excited to see what it would run after the repairs. Well guess what, it ran almost the same. The only thing that baffles me is how someone didn't hear Brian's and say something. That had to be clicking pretty loud.
I am pretty in tune with hearing any changes to the engine and there was just nothing to indicate what I found. Everything still sounded very good. Response was good, etc..
I would have expected it to pick up a little with corrected lash, but not a big change....maybe .05 to .07 in the 1/8th?
There will be alot of changes made on this round. Heads are getting new ports that make them viable to 8400 RPM (current "original" Coleman port is all done at about 7300 RPM with my displacement). I am also only opening the intake valve a net amount after lash and deflection of just over .700". Cam will be re-ground to take the net lift over .800". Jim is right, there should be a sizable gain from these changes and I am putting alot of faith into the work being done.
[Re: emarine01]
#1162321
01/22/12 05:17 PM
01/22/12 05:17 PM
408strokerdart
Out West
The cylinders with the loose intake valve lash all had intake ports that were dark in color....I assume from being overly rich or fuel pooling in the port from nowhere to go? The other ports were as clean as a new build.
[Re: MR_P_BODY]
#1162322
01/22/12 05:21 PM
01/22/12 05:21 PM
408strokerdart
Out West
Running 1.7 ratio Jesel.Never heard many bad stories about their adjusters.
#1162323
01/22/12 07:08 PM
01/22/12 07:08 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
You going to do any racing this year? Didn't see you at all in 2011.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
#1162325
01/22/12 08:09 PM
01/22/12 08:09 PM
Posts: 2,027 Trumbull,CT.
jim sciortino
Trumbull,CT.
Now we're talkin'.
[Re: Jacob Pitt]
#1162326
01/22/12 11:28 PM
01/22/12 11:28 PM
408strokerdart
Out West
As soon as I get pieces back and the engine back together we will be out there. I hope to run a bunch this year. You are right though, only went out once last year for a quick test that resulted in some new bests but no data for the logger.
[Re: jim sciortino]
#1162327
01/22/12 11:29 PM
01/22/12 11:29 PM
408strokerdart
Out West
Now we're talkin'.
Gonna be radically different for sure.
[Re: emarine01]
#1162328
01/22/12 11:34 PM
01/22/12 11:34 PM
408strokerdart
Out West
Overly rich... fuel pooling in the port... I think this is a interesting observation but not sure its the cause of a dark intake port... JMO... Dark intake tracts are usually from exhaust gasses , yes?... I am not trying to bust your chops on this one just trying to learn
I'm only taking guesses at the cause since they concided with the loose valve lash.I'm not sure what the actual cause is. I am open to suggestions as to the cause.
#1162329
01/23/12 12:26 AM
01/23/12 12:26 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Check your rocker arms. May be a broke bearing or more than likely your adjuster backed off. If you run the proper pushrod length you can only back the adjuster off 1/2 to 3/4 a turn and they bottom out in the rocker arm.
Then again maybe you have some bent valves. That would explain the black in the intake runners.
Leon
[Re: Leon441]
#1162330
01/23/12 12:41 AM
01/23/12 12:41 AM
408strokerdart
Out West
Leon
We will check the valves when everything else is checked, but that would make sense.
The adjusters were still tight and they were only able to be backed off the amount you suggested.
[Re: LA360]
#1162333
01/23/12 10:35 AM
01/23/12 10:35 AM
408strokerdart
Out West
When did you check the lash prior to discovering this?
About 40 passes ago.
Re: Tore into the engine tonight....**UPDATE**
#1162335
01/26/12 11:08 PM
01/26/12 11:08 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sorry to hear that Brian. I hope you caught it before it did major damage.
#1162336
01/26/12 11:53 PM
01/26/12 11:53 PM
408strokerdart
Out West
Will know more when I get the engine out and on the stand where I can tear the rest down.
#1162337
01/27/12 12:00 AM
01/27/12 12:00 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Sorry to hear about the damage. We have issues as well. I'm about to the point of selling it all.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#1162339
01/27/12 12:22 AM
01/27/12 12:22 AM
408strokerdart
Out West
We must be on the same page....it crossed my mind.
#1162342
01/27/12 01:22 AM
01/27/12 01:22 AM
MR_P_BODY
The culprit of the loose valves was destroyed lifters. One completely gone roller....found three pieces of it, no shaft and only five needle bearings up top. Number 1 cylinder is scored and I need to see how bad it is. I am dreading having to re-bore this and buy new pistons for an engine with so few passes.
I think I have a bad lifter on my W-2 engine... I havent looked yet to see what the problem is... that'll wait till I get that engine on the stand... I'll put the W-9 back in
[Re: MR_P_BODY]
#1162343
01/27/12 02:05 AM
01/27/12 02:05 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
That sucks but now you know the importance of checking valve lash after every pass. if its loose its a pushrod or lifter or rocker, if its tight the valve is pulling through.
Don't get depressed if it was easy to go fast everybody would be!
BB, TT5,Procharged 3300lb Street Car 4.79/154
#1162344
01/27/12 03:59 AM
01/27/12 03:59 AM
Al_Alguire
Las Vegas
Brian sorry to hear about the problem. Hopefully you caught it before any of those little needles did any real damage to things. I am pretty religous about lash. Even once it is stable we still chack it at every race. That does not guarantee no problems but we rarely let it go more than 10 passes without checking it out.
Believe me I feel your pain. Checking mine at a race after it was not running the number it should, and we are talking a few thou off is how we found the bad LSM cam. Cam apparently lost its heat treat and was peeling material off, found it by lash on two cylinders being off. Caught it before it did much damage but I always check it over if it falls off for any reason.
[Re: Al_Alguire]
#1162345
01/27/12 07:47 AM
01/27/12 07:47 AM
Posts: 6,145 Melbourne , Australia
LA360
Sorry to hear of the damage Brian! Hope it's nothing too serious! What lifters are you thinking about dropping into there to replace these ones? You were running Crane Ultra Pro's?
Alan Jones
[Re: LA360]
#1162347
01/27/12 10:10 AM
01/27/12 10:10 AM
408strokerdart
Out West
They were Crane Ultra Pro's. Don't know what I will use next. Possibly Morel since they have a direct replacement for the Crane with the offset that I need. The offset narrows down my selection and I know the oil holes in the bushings work with the crane (pushrod oiled).
As far as serious, probably nothing $3-$4K won't fix.
[Re: Al_Alguire]
#1162348
01/27/12 10:13 AM
01/27/12 10:13 AM
408strokerdart
Out West
Strange thing Al is that it ran the quickest/fastest it ever has on the last pass. I just can't believe that nothing could be heard. But, yes I did fall off of my normal maintenance routine. That won't happen again.
#1162349
01/27/12 01:00 PM
01/27/12 01:00 PM
Al_Alguire
Las Vegas
FWIW I have been running Isky EZ Rolls and have had zero isues with the lifters. Plus no needle bearings The fact that it picked up might say something about the engine combo and camshaft selection Less lift and less duration and you went faster. Then again the few engines I have had that went BOOM, usually ran thier best the previous pass
#1162353
02/23/12 10:12 AM
02/23/12 10:12 AM
jim sciortino
Trumbull,CT.
Highly disappointed in the findings from tearing down this engine. Seems there are problems at every turn so far.
The heads are at a professional shop to get checked out. If you are reading this and missed the first part, the easy thing to check for me was the valve springs were set up with a installed height that was over .200" from coil bind. Further inspection is finding the following: wrong length valves for the heads, tips of intake valves beat up, intake valves with less than acceptable margin, valve guides with up to .007" clearance, several exhaust valves not even sealing to the seats, etc..
Remember this engine has only about 60 passes on it. I don't think it would have stayed together much longer (in the valvetrain) and it seems that it is a good thing that the improper spring set-up caused the lifter failure or I might have run this until a catastrophic failure occured. These problems didn't just happen in 60 passes....they were there from the start.
It will be put together right this time and should finally run to it's potential.
Wow.....
Lucky that thing didn't really hurt itself.
[Re: stevet340]
#1162356
02/23/12 11:05 AM
02/23/12 11:05 AM
Plumb Wired
Blue Ridge, VA
Brian, If it helps any I feel your pain and frustration. As you probably know we have issues with our heads as well. I haven't even touched the shortblock yet. Mike Gray
RIP Monte Smith
[Re: stevet340]
#1162357
02/23/12 02:04 PM
02/23/12 02:04 PM
408strokerdart
Out West
I was wondering how long of a valve do you run? What is the installed height? And, you should check you lash more frequently, after every time out, don't be lazy and assume everything is ok.
I don't know exact length of valve, but I do know they are longer than normal for this head. Spring installed height was around 2.100 (from the build sheet), but actual measurement was around 2.065. This was for a cam that had .737" lift before the .026" lash and rocker arm/push rod deflection, so you can do the math. It was a comp triple spring with about 330# on the seat.
I run lash about every 20 passes. This could easily be one race weekend. I ran lash more often when I ran Harland Sharp rockers. The Jesel's should be better.
[Re: Plumb Wired]
#1162358
02/23/12 02:06 PM
02/23/12 02:06 PM
408strokerdart
Out West
Brian,
Mike Gray
Yes. I know you are feeling the same pains. I didn't get the "complete" low down on your issues, but I got the jist of it.
We might be able to put our heads together and make one "good" set.
#1162359
02/23/12 02:13 PM
02/23/12 02:13 PM
dartman366
Mt. Vernon, Ohio
Is that seat pressure really necessary? I am running only .688 lift and mine are set at 240# with a 2.00 installed height.
#1162361
02/23/12 03:13 PM
02/23/12 03:13 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
What about just sleeving that one hole if the piston is still ok ?
[Re: JohnRR]
#1162362
02/23/12 03:21 PM
02/23/12 03:21 PM
408strokerdart
Out West
Waiting on the machine shop....hopefully they will tell me 95% will hone out. If it will, that's what I will do. I have a couple of other lower cost options if required.
[Re: dartman366]
#1162363
02/23/12 03:25 PM
02/23/12 03:25 PM
408strokerdart
Out West
I expect the new spring package to be in that range. Probably about 250 to 275 on the seat, installed at 2.00". New cam lobe is undecided at this point, but will probably be somewhere between .765 and .800 lift. Installed height will be set to get somewhere around .070 from coil bind (give or take).
[Re: tboomer]
#1162365
02/23/12 05:20 PM
02/23/12 05:20 PM
408strokerdart
Out West
No help to ya,Brian...But I wish ya the best of luck!
Thanks Ted. From what I'm finding and is being corrected, I have no doubt that we will find the 8 second zone this year. It might take near perfect conditions though.
[Re: all spooled up]
#1162368
02/23/12 06:07 PM
02/23/12 06:07 PM
408strokerdart
Out West
hey that s--ks sorry to her that hows your short block..
We will see when I find the rest of the schrapnel. I think it is going to be ok though.
[Re: LA360]
#1162373
02/23/12 10:13 PM
02/23/12 10:13 PM
jim sciortino
Trumbull,CT.
If it's in the budget to spintron, do it.
I'll never do another engine without it again.
What has time on a spintron set you back?? It would be great info for those reading this post
We haven't used a spintron on any of our previous builds, but after talking with guys about valvetrain reliability when everything is happy, it will be incorporated into our next build.
Like anything else, there is a cost/benefit, but IMO, for engines that see 8000rpm and up it's beneficial.
