Page 1 of 4 1 2 3 4
Tore into the engine tonight....**UPDATE 2** #1162296
01/21/12 11:13 PM
01/21/12 11:13 PM
Out West
408strokerdart Offline OP
Out West
Found three rockers with so much lash that I am surprised I didn't loose the push rods or lash caps. I stopped with the feeler gauges when I was around .085" so they were real loose. I knew something was wrong when I pulled the intake and found three ports dark when the other five were clean. All three were intake rockers on those "dark" cylinders. I was well past the point where I should have run the valves, but this was a surprise since there was nothing to indicate anything was wrong. No noise, misfire, popping....nothing. I will be replacing the lifters anyway, but what else could have suffered? Can't believe this just went a mid 5.8 in this condition.
Re: Tore into the engine tonight.... [Re: 408strokerdart] #1162297
01/21/12 11:28 PM
01/21/12 11:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Check that the ball end on the pushrod and the lifter/rocker adjuster to make sure the radius matches and also check that the adjuster hasn't pushed the threads in the rocker.
Re: Tore into the engine tonight.... [Re: dartman366] #1162298
01/21/12 11:46 PM
01/21/12 11:46 PM
Out West
Out West
Will take a good look at those items tomorrow.
Re: Tore into the engine tonight.... [Re: 408strokerdart] #1162299
01/21/12 11:53 PM
01/21/12 11:53 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
last time i had a loose rocker like that the cam lobe went flat
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
Re: Tore into the engine tonight.... [Re: 408strokerdart] #1162300
01/21/12 11:55 PM
01/21/12 11:55 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Do you run rollers?
Re: Tore into the engine tonight.... [Re: 00snake530] #1162301
01/22/12 12:00 AM
01/22/12 12:00 AM
Out West
Out West
Cam is getting re-ground anyway...
Re: Tore into the engine tonight.... [Re: supercomp] #1162302
01/22/12 12:01 AM
01/22/12 12:01 AM
Out West
Out West
Do you run rollers?
Yes. Crane ultra pro.
Re: Tore into the engine tonight.... [Re: 408strokerdart] #1162303
01/22/12 12:28 AM
01/22/12 12:28 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I would check the rollers.
Re: Tore into the engine tonight.... [Re: supercomp] #1162304
01/22/12 10:06 AM
01/22/12 10:06 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Check every single thing....leave no stone unturned.
You are going to pick up quite nicely when you square it all away.
Re: Tore into the engine tonight.... [Re: 408strokerdart] #1162305
01/22/12 10:26 AM
01/22/12 10:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Brian I forget what rockers you are running but some
of the adjusters are junk and will pull the threads
out and were soft so the push rods beat the cups...
also as said check the dia of the cup to the PR ball...
3/8 balls DONT FIT on any of the cups
Re: Tore into the engine tonight.... [Re: MR_P_BODY] #1162306
01/22/12 10:31 AM
01/22/12 10:31 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Can't believe it ran as well as it did. As mentioned before, you're going to
Pick up substantial gains.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Tore into the engine tonight.... [Re: ChrgrCuda] #1162307
01/22/12 10:36 AM
01/22/12 10:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I really doubt it will pick up much at all... JMO
Re: Tore into the engine tonight.... [Re: MR_P_BODY] #1162308
01/22/12 11:11 AM
01/22/12 11:11 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I agree,,if it picks up at all it will be negligable.
Re: Tore into the engine tonight.... [Re: MR_P_BODY] #1162309
01/22/12 12:13 PM
01/22/12 12:13 PM
Trumbull,CT.
Trumbull,CT.
When he gets a representative camshaft in that thing, along with a couple other "things", it will pick up accordingly.
Re: Tore into the engine tonight.... [Re: dartman366] #1162310
01/22/12 12:49 PM
01/22/12 12:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How could it NOT pick up when these issues are corrected???
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Tore into the engine tonight.... [Re: 408strokerdart] #1162311
01/22/12 01:06 PM
01/22/12 01:06 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
there goes the answer to when u said it ran piggish,,,that 75hp those 3 rockers being out that far
Re: Tore into the engine tonight.... [Re: hemi-itis] #1162312
01/22/12 01:07 PM
01/22/12 01:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If he were to just correct the problem it wouldnt
change much at all... I've been there... but he is
regrinding the cam so we wont know for sure
Re: Tore into the engine tonight.... [Re: 408strokerdart] #1162313
01/22/12 01:16 PM
01/22/12 01:16 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
my dad(73yrs old)at the time, had a j headed headed 340 built,the @%#$ who built it,did dyno it and gave my pop 2 dyno sheets 1st was 459 2nd was 22hp less..i was pissed,he did it with us not there we live 2 miles away..put motor in the car heard some knocking under the stock valve covers and found pushrod tip broke and the cup on the rocker... there was the 20 or so hp! dont know why he the builder was never curiouse to know where the power went..well the guy who did it is close to workin for advanced auto parts now...shame his dad was a great machinist and builder.
Re: Tore into the engine tonight.... [Re: fishy340] #1162314
01/22/12 02:00 PM
01/22/12 02:00 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
is this B&B ???
1.39 9.85 - 137 mph
Re: Tore into the engine tonight.... [Re: Ari440] #1162315
01/22/12 02:13 PM
01/22/12 02:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sounds like it is time to junk it and get something with more power
Seriously as has been said already check everything over very well. Leave no stone unturned..
Page 1 of 4 1 2 3 4
