Page 4 of 4 1 2 3 4
Re: Tore into the engine tonight....**UPDATE** [Re: stevet340] #1162356
02/23/12 11:05 AM
02/23/12 11:05 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Brian,
If it helps any I feel your pain and frustration. As you probably know we have issues with our heads as well. I haven't even touched the shortblock yet.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Tore into the engine tonight....**UPDATE** [Re: stevet340] #1162357
02/23/12 02:04 PM
02/23/12 02:04 PM
Out West
408strokerdart Offline OP
Out West
I was wondering how long of a valve do you run? What is the installed height? And, you should check you lash more frequently, after every time out, don't be lazy and assume everything is ok.
I don't know exact length of valve, but I do know they are longer than normal for this head. Spring installed height was around 2.100 (from the build sheet), but actual measurement was around 2.065. This was for a cam that had .737" lift before the .026" lash and rocker arm/push rod deflection, so you can do the math. It was a comp triple spring with about 330# on the seat.
I run lash about every 20 passes. This could easily be one race weekend. I ran lash more often when I ran Harland Sharp rockers. The Jesel's should be better.
Re: Tore into the engine tonight....**UPDATE** [Re: Plumb Wired] #1162358
02/23/12 02:06 PM
02/23/12 02:06 PM
Out West
Out West
Brian,
Mike Gray
Yes. I know you are feeling the same pains. I didn't get the "complete" low down on your issues, but I got the jist of it.
We might be able to put our heads together and make one "good" set.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162359
02/23/12 02:13 PM
02/23/12 02:13 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Is that seat pressure really necessary? I am running only .688 lift and mine are set at 240# with a 2.00 installed height.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162360
02/23/12 02:21 PM
02/23/12 02:21 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162361
02/23/12 03:13 PM
02/23/12 03:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Number 1 cylinder is scored and I need to see how bad it is. I am dreading having to re-bore this and buy new pistons for an engine with so few passes.
What about just sleeving that one hole if the piston is still ok ?
Re: Tore into the engine tonight....**UPDATE** [Re: JohnRR] #1162362
02/23/12 03:21 PM
02/23/12 03:21 PM
Out West
Out West
Waiting on the machine shop....hopefully they will tell me 95% will hone out. If it will, that's what I will do. I have a couple of other lower cost options if required.
Re: Tore into the engine tonight....**UPDATE** [Re: dartman366] #1162363
02/23/12 03:25 PM
02/23/12 03:25 PM
Out West
Out West
I expect the new spring package to be in that range. Probably about 250 to 275 on the seat, installed at 2.00". New cam lobe is undecided at this point, but will probably be somewhere between .765 and .800 lift. Installed height will be set to get somewhere around .070 from coil bind (give or take).
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162364
02/23/12 03:48 PM
02/23/12 03:48 PM
tboomer Offline
tboomer  Offline
No help to ya,Brian...But I wish ya the best of luck!
Re: Tore into the engine tonight....**UPDATE** [Re: tboomer] #1162365
02/23/12 05:20 PM
02/23/12 05:20 PM
Out West
Out West
Thanks Ted. From what I'm finding and is being corrected, I have no doubt that we will find the 8 second zone this year. It might take near perfect conditions though.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162366
02/23/12 05:34 PM
02/23/12 05:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Who is responsible to that stellar work on the heads before ?
Re: Tore into the engine tonight....**UPDATE** [Re: JohnRR] #1162367
02/23/12 05:38 PM
02/23/12 05:38 PM
ohio
all spooled up Offline
ohio
hey that s--ks sorry to her that hows your short block..
Re: Tore into the engine tonight....**UPDATE** [Re: all spooled up] #1162368
02/23/12 06:07 PM
02/23/12 06:07 PM
Out West
Out West
We will see when I find the rest of the schrapnel. I think it is going to be ok though.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162369
02/23/12 06:34 PM
02/23/12 06:34 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
If it's in the budget to spintron, do it.
I'll never do another engine without it again.
Re: Tore into the engine tonight....**UPDATE 2** [Re: 408strokerdart] #1162370
02/23/12 07:19 PM
02/23/12 07:19 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I have been following this saga and all I can say besides sorry for the situation is I hope it doesn't derail your return this year. At least you'll pick-up in performance when you do return. Did you buy this engine used? If you can say, I think alot of people might want to know. Anyway again best wishes for your return.
Re: Tore into the engine tonight....**UPDATE** [Re: jim sciortino] #1162371
02/23/12 08:32 PM
02/23/12 08:32 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
What has time on a spintron set you back?? It would be great info for those reading this post
Alan Jones
Re: Tore into the engine tonight....**UPDATE** [Re: LA360] #1162372
02/23/12 10:08 PM
02/23/12 10:08 PM
Out West
Out West
The only point of my post was to point out things that I am finding that are not what I would have done. Maybe this is how some builders put things together. Not really for me to judge....thats why I am just laying out the facts.
To be fair, I should add some information about the original build. These heads were located for me (used). I was told that they had valves, but I paid for new springs, spring cups, titanium retainers, locks and push rods. This tear down is the first time I have seen and inspected these parts in depth. The short block though, everything was new and very expensive.
Re: Tore into the engine tonight....**UPDATE** [Re: LA360] #1162373
02/23/12 10:13 PM
02/23/12 10:13 PM
Trumbull,CT.
Trumbull,CT.
We haven't used a spintron on any of our previous builds, but after talking with guys about valvetrain reliability when everything is happy, it will be incorporated into our next build.
Like anything else, there is a cost/benefit, but IMO, for engines that see 8000rpm and up it's beneficial.
Re: Tore into the engine tonight....**UPDATE** [Re: jim sciortino] #1162374
02/24/12 05:13 PM
02/24/12 05:13 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Flow #s right off engine (Brian's W8s) Not so good start to go bad at .600" lots of noise in port.
CCFM
Lift No. 1
0.0500
0.1000 0.0
0.1500 0.0
0.2000 137.5
0.2500 168.4
0.3000 203.2
0.3500 237.2
0.4000 269.6
0.4500 300.3
0.5000 326.8
0.5500 346.4
0.6000 365.2
0.6500 369.5
0.7000 367.3
0.7500 368.0
0.8000 360.9
0.8500 361.7
0.9000 363.6
0.9500 361.8
1.0000 360.3
Re: Tore into the engine tonight....**UPDATE** [Re: W5DART66] #1162375
02/24/12 06:57 PM
02/24/12 06:57 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Can't wait to see the flow numbers "after"
Page 4 of 4 1 2 3 4
