Page 3 of 4 1 2 3 4
Re: Tore into the engine tonight....**UPDATE** [Re: pittsburghracer] #1162336
01/26/12 11:53 PM
01/26/12 11:53 PM
Out West
408strokerdart Offline OP
Out West
Sorry to hear that Brian. I hope you caught it before it did major damage.
Will know more when I get the engine out and on the stand where I can tear the rest down.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162337
01/27/12 12:00 AM
01/27/12 12:00 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Sorry to hear about the damage. We have issues as well. I'm about to the point of selling it all.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Tore into the engine tonight....**UPDATE** [Re: Plumb Wired] #1162338
01/27/12 12:13 AM
01/27/12 12:13 AM
oregon
greendart408 Offline
oregon
Always something, that blows
Re: Tore into the engine tonight....**UPDATE** [Re: Plumb Wired] #1162339
01/27/12 12:22 AM
01/27/12 12:22 AM
Out West
Out West
We must be on the same page....it crossed my mind.
Re: Tore into the engine tonight....**UPDATE** [Re: greendart408] #1162340
01/27/12 12:23 AM
01/27/12 12:23 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
If it's not one thing, it's another....
Good luck with the fix.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162341
01/27/12 12:53 AM
01/27/12 12:53 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
The culprit of the loose valves was destroyed lifters. One completely gone roller....found three pieces of it, no shaft and only five needle bearings up top. Number 1 cylinder is scored and I need to see how bad it is. I am dreading having to re-bore this and buy new pistons for an engine with so few passes.
I'm going through a complete rebuild right now because of a trashed lifter. The oil pump driveshaft was cracked. If that would have went it woulda been far worse.
It amazes me how well they'll run with something going wrong. From now on I'll check things closer if it slows down a tenth or so.
Good luck with it.
Yeah, it's got a smallblock.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162342
01/27/12 01:22 AM
01/27/12 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think I have a bad lifter on my W-2 engine... I
havent looked yet to see what the problem is... that'll
wait till I get that engine on the stand... I'll
put the W-9 back in
Re: Tore into the engine tonight....**UPDATE** [Re: MR_P_BODY] #1162343
01/27/12 02:05 AM
01/27/12 02:05 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
That sucks but now you know the importance of checking valve lash after every pass. if its loose its a pushrod or lifter or rocker, if its tight the valve is pulling through.
Don't get depressed if it was easy to go fast everybody would be!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162344
01/27/12 03:59 AM
01/27/12 03:59 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Brian sorry to hear about the problem. Hopefully you caught it before any of those little needles did any real damage to things. I am pretty religous about lash. Even once it is stable we still chack it at every race. That does not guarantee no problems but we rarely let it go more than 10 passes without checking it out.
Believe me I feel your pain. Checking mine at a race after it was not running the number it should, and we are talking a few thou off is how we found the bad LSM cam. Cam apparently lost its heat treat and was peeling material off, found it by lash on two cylinders being off. Caught it before it did much damage but I always check it over if it falls off for any reason.
Re: Tore into the engine tonight....**UPDATE** [Re: Al_Alguire] #1162345
01/27/12 07:47 AM
01/27/12 07:47 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Sorry to hear of the damage Brian! Hope it's nothing too serious!
What lifters are you thinking about dropping into there to replace these ones? You were running Crane Ultra Pro's?
Alan Jones
Re: Tore into the engine tonight....**UPDATE** [Re: LA360] #1162346
01/27/12 09:39 AM
01/27/12 09:39 AM
tboomer Offline
tboomer  Offline
Sorry to see that,Brian!! I know that needle bearings are all the rage but I don't care for them...I thought someone said Harland Sharp was coming out with one that did not have needles on the wheel but I have not seen one yet....Good luck,man!!
Re: Tore into the engine tonight....**UPDATE** [Re: LA360] #1162347
01/27/12 10:10 AM
01/27/12 10:10 AM
Out West
Out West
They were Crane Ultra Pro's. Don't know what I will use next. Possibly Morel since they have a direct replacement for the Crane with the offset that I need. The offset narrows down my selection and I know the oil holes in the bushings work with the crane (pushrod oiled).
As far as serious, probably nothing $3-$4K won't fix.
Re: Tore into the engine tonight....**UPDATE** [Re: Al_Alguire] #1162348
01/27/12 10:13 AM
01/27/12 10:13 AM
Out West
Out West
Strange thing Al is that it ran the quickest/fastest it ever has on the last pass. I just can't believe that nothing could be heard. But, yes I did fall off of my normal maintenance routine. That won't happen again.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162349
01/27/12 01:00 PM
01/27/12 01:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I have been running Isky EZ Rolls and have had zero isues with the lifters. Plus no needle bearings
The fact that it picked up might say something about the engine combo and camshaft selection Less lift and less duration and you went faster. Then again the few engines I have had that went BOOM, usually ran thier best the previous pass
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162350
01/27/12 06:54 PM
01/27/12 06:54 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Sorry about the problem. Those rollers can sneek up and bite you right in the butt.
Re: Tore into the engine tonight....**UPDATE** [Re: supercomp] #1162351
01/27/12 07:17 PM
01/27/12 07:17 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
Its good you found the problems before it cost alot of $$$$, its easy to understand how some things can run well but still have issues.
Take tractor pulling for instance, everytime we brought home first we would find the most damage on post evenet inspections. Or the top fuel guy who wins but burns two pistons doing it
Re: Tore into the engine tonight....**UPDATE** [Re: A57_RT ] #1162352
02/23/12 02:02 AM
02/23/12 02:02 AM
Out West
Out West
Highly disappointed in the findings from tearing down this engine. Seems there are problems at every turn so far.
The heads are at a professional shop to get checked out. If you are reading this and missed the first part, the easy thing to check for me was the valve springs were set up with a installed height that was over .200" from coil bind. Further inspection is finding the following: wrong length valves for the heads, tips of intake valves beat up, intake valves with less than acceptable margin, valve guides with up to .007" clearance, several exhaust valves not even sealing to the seats, etc..
Remember this engine has only about 60 passes on it. I don't think it would have stayed together much longer (in the valvetrain) and it seems that it is a good thing that the improper spring set-up caused the lifter failure or I might have run this until a catastrophic failure occured. These problems didn't just happen in 60 passes....they were there from the start.
It will be put together right this time and should finally run to it's potential.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162353
02/23/12 10:12 AM
02/23/12 10:12 AM
Trumbull,CT.
Trumbull,CT.
Wow.....
Lucky that thing didn't really hurt itself.
Re: Tore into the engine tonight....**UPDATE** [Re: 408strokerdart] #1162354
02/23/12 10:40 AM
02/23/12 10:40 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
sorry to hear of your loss. I definately know what you're going through as our latest W5 combo banged in two passes. Question for the engine guys watching this: So you are at the track, pull the covers after a few passes and find a rocker that is loose. How "loose" would it take to pull the plug on the day and tear it down hoping to possibly find something?
Re: Tore into the engine tonight....**UPDATE** [Re: J_BODY] #1162355
02/23/12 10:49 AM
02/23/12 10:49 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
I was wondering how long of a valve do you run? What is the installed height? And, you should check you lash more frequently, after every time out, don't be lazy and assume everything is ok.
Page 3 of 4 1 2 3 4
