Re: BB Oil line pics [Re: Stanton] #1142932
12/26/11 10:33 PM
12/26/11 10:33 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Needing a guard on a table saw is a myth too, as is wearing safety goggles when grinding! Having used neither for years I'd say I'd say I'm just lucky. For the sake of a couple extra feet of line, is it worth the risk?
i've checked the bearings in my Hemi twice in the last 4 years, and have put them back in every time. doesn't look like it runs dry to me. so yea, in my case myth..
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: BB Oil line pics [Re: ProSport] #1142933
12/26/11 11:00 PM
12/26/11 11:00 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: BB Oil line pics [Re: Ari440] #1142934
12/27/11 01:34 PM
12/27/11 01:34 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
This is an engine I put together around 1985 it had a Milidon system. I never had an issue with losing oil pressure on startup. The engine was a turd and broke a 6 pack rod after about 120 passes but the bearings still looked good when it came apart.
Re: BB Oil line pics [Re: JCCuda] #1142935
12/28/11 02:08 AM
12/28/11 02:08 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
seems a lot of people have had problems losing prime so i can't say it's a myth but it's a problem i've never encountered. this is a home brew pump cover, i never cared for the milodon.
Re: BB Oil line pics [Re: jamesc] #1142936
12/28/11 02:53 AM
12/28/11 02:53 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
I take it with the dual pick ups, most people are using a swinging pick up?
Alan Jones
Re: BB Oil line pics [Re: LA360] #1142937
12/28/11 03:04 AM
12/28/11 03:04 AM
jamesc Offline
jamesc  Offline
yes, there are static pick ups available but i would steer clear of them. though i never personally used one a reputable engine builder had told me they were damaging bearings in the shutdown with a static pick up, a swinging pick up solved the problem. i guess pan design has a lot to do with it as well.
Re: BB Oil line pics [Re: jamesc] #1142938
12/28/11 03:12 AM
12/28/11 03:12 AM
LA360 Offline OP
LA360  Offline OP
Personally, on anything that would be considered a race engine i'd run a properly baffled and trap doored pan. It amazes me as to how many engines I see where oil control isn't emphasized, where more capacity and a windage tray tends to be all that is used. Most of the BB pans I have come across don't have all the bells and whistles, I have often wondered why.
Alan Jones
Re: BB Oil line pics [Re: LA360] #1142939
12/28/11 03:22 AM
12/28/11 03:22 AM
jamesc Offline
jamesc  Offline
i use the milodon pans which have trap doors, windage tray and swinging pick up. i've never experienced any oil pressure problems.
Re: BB Oil line pics [Re: jamesc] #1142940
12/28/11 04:26 AM
12/28/11 04:26 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hey Here is a picture of my 496 with a Charlies race pan
Re: BB Oil line pics [Re: mosweethemi] #1142941
12/28/11 12:54 PM
12/28/11 12:54 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Here is mine:
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: BB Oil line pics [Re: jamesc] #1142942
12/28/11 01:34 PM
12/28/11 01:34 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Ok what is your pump cover? Who made it? Can you get another?
Re: BB Oil line pics [Re: astjp2] #1142943
12/28/11 02:05 PM
12/28/11 02:05 PM
jamesc Offline
jamesc  Offline
it's a modified stock cover, i got the idea from a very old mopar performance tip publication. if you look at the fluid flow of the pump you'll see that the cavity where any oil released from the relief valve spills back into the suction. if you're careful you can drill into this cavity and use that for your second pickup. the performance tip said to use 1" but i used a piece of 3/4" 4130 and brazed it into the cover. on the end of that i silver soldered a steel AN fitting that can be obtained from a hydraulics supplier. it does require some careful whittling to do it but imho it works out better than most of what is out there. i was never really fond of aluminum oil pumps and really don't care for an aluminum cover at all. muscle motors was/is making a cover that will help most guys but i don't know if they're still available. there was another machine shop making a really trick cover but afaik they ceased production which is a shame cause it was a slick setup.
Re: BB Oil line pics [Re: jamesc] #1142944
12/28/11 04:17 PM
12/28/11 04:17 PM
Your cover lokks exactly what I remember seeing on a old Petty Engr. prepared NASCAR motor I had the opportunity to work on Can you say I had the opportunity to do some reverse Engr. after that
