Re: BB Oil line pics
[Re: LA360]
#1142937
12/28/11 03:04 AM
12/28/11 03:04 AM
Posts: 5,875 communist bloc of new jersey
jamesc
I take it with the dual pick ups, most people are using a swinging pick up?
yes, there are static pick ups available but i would steer clear of them. though i never personally used one a reputable engine builder had told me they were damaging bearings in the shutdown with a static pick up, a swinging pick up solved the problem. i guess pan design has a lot to do with it as well.
[Re: jamesc]
#1142938
12/28/11 03:12 AM
12/28/11 03:12 AM
Posts: 6,146 Melbourne , Australia
LA360
Personally, on anything that would be considered a race engine i'd run a properly baffled and trap doored pan. It amazes me as to how many engines I see where oil control isn't emphasized, where more capacity and a windage tray tends to be all that is used. Most of the BB pans I have come across don't have all the bells and whistles, I have often wondered why.
Alan Jones
[Re: jamesc]
#1142944
12/28/11 04:17 PM
12/28/11 04:17 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Your cover lokks exactly what I remember seeing on a old Petty Engr. prepared NASCAR motor I had the opportunity to work on Can you say I had the opportunity to do some reverse Engr. after that
