Page 7 of 8 1 2 3 4 5 6 7 8
Re: Wheel Stands [Re: Guitar Jones] #1116716
11/22/11 11:09 PM
11/22/11 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hmm, my car still has all the factory glass in it, steel doors and the windows still roll up and down. Door locks work too.
I sure would raise the tire pressure
Re: Wheel Stands [Re: moparguy7074] #1116717
11/22/11 11:10 PM
11/22/11 11:10 PM
Guitar Jones Offline
There's actually 8 pounds in there but you know how that goes. Hurry up to the lanes and wait for two hours while they clean up the last Chevy oil down.
Re: Wheel Stands [Re: Guitar Jones] #1116718
11/22/11 11:17 PM
11/22/11 11:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I air up the tires about a 1/4# to 1/2# high then set
them in the lanes as the lane starts to move... but
I run tubes so they tend to build pressure in the sun
Re: Wheel Stands [Re: MR_P_BODY] #1116719
11/22/11 11:32 PM
11/22/11 11:32 PM
Yeah I don't run tubes so they tend to leak down. I had no crew with me that year and the trailer was too far away so you get what you get. The car will still work fine from 9 to 7.5 psi so it's not that big of a deal.
Re: Wheel Stands [Re: WheelsUp73] #1116720
11/23/11 02:34 PM
11/23/11 02:34 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Are the tubular upper arms demensionally differt from stock? I end up pulling my hair out trying to accomodate toe and camber movements through out range. I just get it close and give up.
Yes they allow for alot more adjustment.I now have 6 degrees of caster and I am able to set camber anywhere I want it.Its good money spent.
Thanks for the info.......
Re: Wheel Stands [Re: MR_P_BODY] #1116721
11/23/11 05:07 PM
11/23/11 05:07 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i agree,i also run 12 lbs in my slicks,which after a good burn out is about 15.
Re: Wheel Stands [Re: Guitar Jones] #1116722
11/23/11 06:21 PM
11/23/11 06:21 PM
Locomotion Offline
Locomotion  Offline
I carry a little foot pump that goes for under $10.00. It's about 8" long, 3" wide and less than 2" high. I pump by hand, but it's easy at low pressures. It might take a while to get a big tire up 1/2 - 1 lb, but it's good to have in an emergency.
Different rear pressures can steer the car as well as have a little affect on RT's because lower pressures wad up more before actually moving!
Eliminate any variable that you can.
Re: Wheel Stands [Re: Locomotion] #1116723
11/23/11 07:12 PM
11/23/11 07:12 PM
north west, IN
larry890 Offline
larry890  Offline
north west, IN
http://youtu.be/YX4GyaHHD2U my best attempt so far.
Re: Wheel Stands [Re: Hot 340] #1116724
11/23/11 09:08 PM
11/23/11 09:08 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Most people forgot what drag racing is about.
Last I checked, it was about going the FASTEST, not the HIGHEST.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Wheel Stands [Re: Evil Spirit] #1116725
11/23/11 09:20 PM
11/23/11 09:20 PM
organ
maximum entropy Offline
organ
i'm a bracket racer, so it's about being the most consistent driver in the most consistent car.
Re: Wheel Stands [Re: maximum entropy] #1116726
11/23/11 09:55 PM
11/23/11 09:55 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
You're both wrong. Its about having a good time.
Re: Wheel Stands [Re: Hot 340] #1116727
11/23/11 10:50 PM
11/23/11 10:50 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I guess I missed it. Did Eddie move to Californa and have a sex change? j/k
Re: Wheel Stands [Re: justinp61] #1116728
11/23/11 11:03 PM
11/23/11 11:03 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Each car, and the track(s) racers attend, are different. The setup to hook, and produce killer package numbers, vary greatly. Of course, I'm referring to et racers. The heads up folks will have a different need. To try and state an absolute, will always have both benefactors, and detractors.
Re: Wheel Stands [Re: Hot 340] #1116729
11/23/11 11:03 PM
11/23/11 11:03 PM
Locomotion Offline
Locomotion  Offline
Nope, you are ALL wrong.
The correct answer is "D" - All of the above.....and then some!
Re: Wheel Stands [Re: Locomotion] #1116730
11/24/11 01:14 AM
11/24/11 01:14 AM
Emmett, Idaho
SuperStockWagon Offline
Emmett, Idaho
Ya...nothing more boring than a couple of big block 4spd Stock Eliminator cars wasting time(and et)putting those frontrunners so high in the air! Sheesh,nothing disgusts fans and drivers more than this kind of unsavory behavior!! Ever wonder why Super Stock is voted the most popular sportsman class in drag racing year in and year out by the fans?? Hmmmm, I say hang em high!!!
Re: Wheel Stands [Re: SuperStockWagon] #1116731
11/24/11 01:26 AM
11/24/11 01:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah those stands look full to me.... dont worry, I
like them also
Re: Wheel Stands [Re: MR_P_BODY] #1116732
11/24/11 01:48 AM
11/24/11 01:48 AM
Emmett, Idaho
Emmett, Idaho
like them also
Class eliminations during the week tend to look that way..a lot of great racing missed by the masses!
Re: Wheel Stands [Re: SuperStockWagon] #1116733
11/24/11 02:20 AM
11/24/11 02:20 AM
S.W.Conn.
1968beepbeep Offline
S.W.Conn.
Nothin' like Frank Lupo's Hemi Dodge ridin' the rear bumper! (The Fairbanks Racing Automatics car)
Re: Wheel Stands [Re: 1968beepbeep] #1116734
11/24/11 11:47 AM
11/24/11 11:47 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
The nice slow motion ones, about 3 feet high, carried to the 1-2 shift, make my Dart deadly on the dial in. More than that, and the bounce starts to mess with the dial.
Re: Wheel Stands [Re: 1968beepbeep] #1116735
11/24/11 11:48 AM
11/24/11 11:48 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
If the front tires are off the ground you have 100% weight transfer,doesn't matter if it's 1" or a foot.
Nautilus Racing-
